HCSK Series
Stackpole Electronics, Inc.
Kelvin Termination Metal Element Current Shunt Resistor
Resistive Product Solutions
Features:
Metal element current shunt resistor
5W permanent power
Inductance < 3nH
Internal heat resistance 15K/W
100% RoHS compliant and lead free without exemption
Halogen free
REACH compliant
Applications:
Power modules
Frequency converters
Current sensor for power hybrid sources
High current handling for automotive engine controls and power management
Electrical Specifications
Type / Code
Power Rating (W)
5
3
5
3
2
5
HCSK1216
HCSK2725
HCSK4026
Ohmic Range (Ω) and Tolerance
1% and 5%
0.0005
0.001
0.0005 - 0.002
0.003
0.004, 0.005
0.0002, 0.0005
0.0007
0.001
0.003
TCR (ppm/ºC)
± 50
± 50
4
± 50
3
Mechanical Specifications – 1216
Type / Code
HCSK1216
Type / Code
HCSK1216
L
B
C
H
0.150 ± 0.012
3.81 ± 0.30
F
0.118 ± 0.006
3.00 ± 0.15
G
0.037 ± 0.006
0.95 ± 0.15
0.071 ± 0.004
1.80 ± 0.10
D1
Unit
0.024 ± 0.006
0.60 ± 0.15
0.106 ± 0.004
2.70 ± 0.10
0.012 ± 0.004
0.30 ± 0.10
inches
mm
A
0.041
1.05
E
0.020 ± 0.004
0.50 ± 0.10
Unit
inches
mm
(*) Reference only.
Rev Date: 8/3/2021
This specification may be changed at any time without prior notice.
Please confirm technical specifications before you order and/or use.
1
www.seielect.com
marketing@seielect.com
HCSK Series
Mechanical Specifications – 2725
Type / Code
HCSK2725
(0.0005)
HCSK2725
(0.001)
HCSK2725
(0.002)
HCSK2725
(0.003)
HCSK2725
(0.004)
HCSK2725
(0.005)
Type / Code
HCSK2725
(0.0005)
HCSK2725
(0.001)
HCSK2725
(0.002)
HCSK2725
(0.003)
HCSK2725
(0.004)
HCSK2725
(0.005)
(*) Reference only.
0.260
6.60
0.260
6.60
0.260
6.60
0.260
6.60
0.260
6.60
0.260
6.60
0.039
1.00
0.039
1.00
0.039
1.00
0.039
1.00
0.039
1.00
0.039
1.00
L
F
B
0.272 ± 0.006
6.90 ± 0.15
0.272 ± 0.006
6.90 ± 0.15
0.272 ± 0.006
6.90 ± 0.15
0.272 ± 0.006
6.90 ± 0.15
0.272 ± 0.006
6.90 ± 0.15
0.272 ± 0.006
6.90 ± 0.15
G (*)
0.193
4.90
0.193
4.90
0.193
4.90
0.193
4.90
0.193
4.90
0.193
4.90
0.010
0.25
0.010
0.25
0.010
0.25
0.010
0.25
0.010
0.25
0.010
0.25
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
C
0.122
3.10
0.122
3.10
0.122
3.10
0.122
3.10
0.122
3.10
0.122
3.10
A
0.075 ± 0.008
1.90 ± 0.20
0.075 ± 0.008
1.90 ± 0.20
0.075 ± 0.008
1.90 ± 0.20
0.075 ± 0.008
1.90 ± 0.20
0.075 ± 0.008
1.90 ± 0.20
0.075 ± 0.008
1.90 ± 0.20
H
± 0.008
± 0.20
± 0.008
± 0.20
± 0.008
± 0.20
± 0.008
± 0.20
± 0.008
± 0.20
± 0.008
± 0.20
D1
0.016 ± 0.004
0.40 ± 0.10
0.016 ± 0.004
0.40 ± 0.10
0.016 ± 0.004
0.40 ± 0.10
0.016 ± 0.004
0.40 ± 0.10
0.016 ± 0.004
0.40 ± 0.10
0.016 ± 0.004
0.40 ± 0.10
0.094
2.40
0.094
2.40
0.094
2.40
0.094
2.40
0.094
2.40
0.094
2.40
E
± 0.008
± 0.20
± 0.008
± 0.20
± 0.008
± 0.20
± 0.008
± 0.20
± 0.008
± 0.20
± 0.008
± 0.20
D2
0.018 ± 0.004
0.45 ± 0.10
0.014 ± 0.004
0.35 ± 0.10
0.022 ± 0.004
0.55 ± 0.10
0.014 ± 0.004
0.35 ± 0.10
0.014 ± 0.004
0.35 ± 0.10
0.014 ± 0.004
0.35 ± 0.10
0.028
0.70
0.028
0.70
0.028
0.70
0.028
0.70
0.028
0.70
0.028
0.70
Unit
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
Unit
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
Mechanical Specifications – 4026
Type / Code
HCSK4026
(0.0002 Ω)
HCSK4026
(except 0.0002 Ω)
Type / Code
HCSK4026
(all Ω values)
A
B
C
E
0.055 ± 0.008
1.40 ± 0.20
0.272
6.90
0.024
0.60
0.008
0.20
G (max.)
0.028
0.70
I
0.028
0.70
J
0.039
1.00
K
0.193
4.90
Rev Date: 8/3/2021
2
H
L
0.398 ±
10.10 ±
0.148
3.75
0.104
2.65
0.008
0.20
0.008
0.20
0.006
0.15
T
F
0.017 ± 0.004
0.42 ± 0.10
0.197
5.00
Unit
inches
mm
inches
mm
W
Unit
0.260 ± 0.008 inches
6.60 ± 0.20
mm
www.seielect.com
HCSK Series
Environmental Performance Characteristics
Test
Test Method
Test Specification
Test Condition
Short Time Overload
Δ R: ± 1%
Temperature Coefficient
of Resistance (TCR)
(1216, 4026)
JIS-C5202-5.2
Refer to
Electrical
Specifications
5 times rated power for 5 seconds
+20°C/+125ºC
of Resistance (TCR)
(2725)
JIS-C5202-5.2
Refer to
Electrical
Specifications
Moisture Resistance
MIL-STD-202,
Method 106
Δ R: ± 1%
High Temperature
Exposure
JIS-C5202-7.2
Δ R: ± 1%
Load Life
JIS-C5202-7.10
Δ R: ± 1%
TCR (ppm/ºC ) =
ΔR
RxΔt
x 106
+25°C/+125ºC
TCR (ppm/ºC ) =
ΔR
RxΔt
x 106
The specimens shall be placed in a chamber and subjected to a relative
humidity of 90 ~ 98% and a temperature of 25ºC/65ºC, 10 cycles.
The chip (mounted on board) is exposed in the heat chamber,
125ºC for 1000 hours.
Apply rated power for 1000 hours with 1.5 hours ON and 0.5 hour OFF.
The chip (mounted on board) is exposed,
-55 ± 3ºC (30 minutes)/+125 ± 2ºC (30 minutes) for 5 cycles.
The following conditions shown in the figure below.
Rapid Change of
Temperature
JIS-C5202-7.4
Δ R: ± 1%
Note: The terminal electron temperature of component should be below 100°C.
Storage Conditions: Temperature of 22 ~ 28°C. Humidity: 40 ~ 75%.
Operating Temperature Range is - 55°C to + 170°C
Power Derating Curve:
100
-55 ºC
100 °C
110 °C
100
-55 ºC
70 °C
Percent Rated Power (%)
1216
2725, 4026
80
60
40
All
80
60
40
170 ºC
170 ºC
60
80
100
120
140
160
180
Rev Date: 8/3/2021
60
80
100
120
140
160
180
Ambient Temperature (ºC)
Terminal Temperature (ºC)
3
www.seielect.com
HCSK Series
Function Performance Characteristics
Test
Test Method
Test Specification
Test Condition
Mount the chip to test 90 mm (L) * 40 mm (W) FR4 printed circuit board substrate.
Apply pressure in direction of arrow unit band width reaches 2 mm (+0.2 / -0 mm)
illustrated in the figure below and hold for 10 ± 1 seconds.
Bending Strength
JIS-C5202-6.1
Δ R: ± 1%
The part shall be immersed into the flux specified in the solder bath
235ºC ± 5ºC for 2 seconds ± 0.5 seconds.
It shall be immersed to a point 10 mm from its root.
(Sn96.5/Ag3.0/Cu0.5)
Solderability
JIS-C5202-6.11
Solder shall cover
95% or more of
the electrode
area.
Taping Specifications – Embossed Plastic Tape
Type / Code
A
B
E
F
W
Unit
HCSK1216
0.130 ± 0.004
3.30 ± 0.10
P0
0.165 ± 0.004
4.20 ± 0.10
P1
0.104 ± 0.004
2.64 ± 0.10
P2
0.217 ± 0.004
5.50 ± 0.10
D0
0.472 ± 0.008
12.00 ± 0.20
T
inches
mm
Unit
Type / Code
0.157 ± 0.004
4.00 ± 0.10
A
0.315 ± 0.004
8.00 ± 0.10
B
0.079 ± 0.002
2.00 ± 0.05
E
0.059 ± 0.004
1.50 ± 0.10
F
0.083 ± 0.004
2.10 ± 0.10
W
inches
mm
Unit
HCSK2725
0.276 ± 0.004
7.00 ± 0.10
P0
0.276 ± 0.004
7.00 ± 0.10
P1
0.069 ± 0.004
1.75 ± 0.10
P2
0.295 ± 0.004
7.50 ± 0.10
D0
0.630 ± 0.008
16.00 ± 0.20
T
inches
mm
Unit
0.157 ± 0.004
4.00 ± 0.10
0.472 ± 0.004
12.00 ± 0.10
0.079 ± 0.004
2.00 ± 0.10
0.059 ± 0.004
1.50 ± 0.10
0.122 ± 0.004
3.10 ± 0.10
inches
mm
Rev Date: 8/3/2021
4
www.seielect.com
HCSK Series
Taping Specifications – Embossed Plastic Tape (cont.)
Type / Code
HCSK4026
(all Ω values)
Type / Code
HCSK4026
(0.0002 Ω)
HCSK4026
(except 0.0002 Ω)
A
0.272 ± 0.004
6.90 ± 0.10
P0
B
0.409 ± 0.004
10.40 ± 0.10
P1
E
0.069 ± 0.004
1.75 ± 0.10
P2
F
0.453 ± 0.004
11.50 ± 0.10
D0
0.157 ± 0.004
4.00 ± 0.10
0.472 ± 0.004
12.00 ± 0.10
0.079 ± 0.004
2.00 ± 0.10
0.059 ± 0.004
1.50 ± 0.10
W
0.945 ± 0.012
24.00 ± 0.30
T
0.165 ± 0.004
4.20 ± 0.10
0.126 ± 0.004
3.20 ± 0.10
Unit
inches
mm
Unit
inches
mm
inches
mm
Recommended Pad Layouts
Type / Code
HCSK1216
HCSK2725
HCSK4026
0.059
1.50
0.114
2.90
0.063
1.60
a
0.004
0.10
0.008
0.20
0.008
0.20
0.024
0.60
0.079
2.00
0.272
6.90
b
0.004
0.10
0.008
0.20
0.008
0.20
0.059
1.50
0.114
2.90
0.063
1.60
c
0.004
0.10
0.008
0.20
0.008
0.20
0.028
0.70
0.035
0.90
0.028
0.70
e
0.004
0.10
0.004
0.10
0.004
0.10
0.020
0.50
0.039
1.00
0.039
1.00
f
0.004
0.10
0.004
0.10
0.004
0.10
0.116
2.95
0.220
5.60
0.193
4.90
g
0.004
0.10
0.008
0.20
0.008
0.20
Unit
inches
mm
inches
mm
inches
mm
Soldering Recommendations:
Peak reflow temperatures and durations
▪ IR Reflow Peak = 260ºC max for 10 seconds
▪ Not suitable for wave soldering
Recommended IR reflow profile:
RoHS Compliance
Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various
regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances”
(RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our
compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as
amended by Directive (EU) 2015/863/EU as regards the list of restricted substances.
RoHS Compliance Status
Standard
Product
Series
Description
HCSK
Kelvin Termination Current Shunt Resistor
Package /
Standard
Termination Series RoHS
Type
Compliant
Rev Date: 8/3/2021
SMD
YES
5
Lead-Free
Termination
Composition
Lead-Free
Mfg. Effective Date
(Std Product Series)
Lead-Free
Effective Date
Code
(YY/WW)
100% Copper
Always
Always
www.seielect.com
HCSK Series
“Conflict Metals” Commitment
We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern
Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry
is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do
not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding
Conflict Minerals.
Compliance to “REACH”
We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and
compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of
Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List.
Environmental Policy
It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive
to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment
and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution.
How to Order
1
2
3
4
5
6
7
8
9
10
11
12
13
13
H
C
S
K
2
7
2
5
F
T
1
L
Product Series
HCSK
Size
1216
2725
4026
Tolerance
Code
Tol
F
1%
J
5%
Code
T
Packaging
Description
Resistance Value
Size
1216
2725, 4026
Quantity
3000
1400
Four characters with
"L" used as multiplier
of 10-3 for any value
under 0.1 ohm
0.0005 ohm = L500
0.001 ohm = 1L00
Rev Date: 8/3/2021
6
www.seielect.com
很抱歉,暂时无法提供与“HCSK4026FT1L00”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+10.448431+1.30118
- 10+8.7574210+1.09059
- 25+8.4929525+1.05766
- 50+7.7479950+0.96488
- 100+6.34703100+0.79042
- 250+5.66125250+0.70502
- 500+4.76743500+0.59371
- 国内价格 香港价格
- 1400+3.962941400+0.49352
- 2800+3.873532800+0.48239
- 7000+3.799057000+0.47311
- 14000+3.7096514000+0.46198
