UP2-220-R
UP2-220-R
    EATON(伊顿)
    SMD,13.7x8.8mm
    固定电感器 Nonstandard 22µH ±20% 2.9A 64.4mΩ
UP2-220-R 数据手册
RECOMMENDED PCB PAD LAYOUT TOP VIEW SCHEMATIC FRONT VIEW Notes: Cooper Electronic Technologies 1) Tolerances +/- .005” unless otherwise specified. 2) Stamping: Stamp unit on top of core as shown Line 1 UP2 ; line 2 Inductance (per family table chart ). 3601 Quantum Boulevard, Boynton Beach FL. 33426 UnipAc 2 Data Sheet This Document Subject To Change Without Notice Uncontrolled Document SIZE A Drawing Number: Revision Level: J UP2 Inductor Line UniPac2 Family Table PN UP2-R47 UP2-1R0 UP2-1R5 UP2-2R2 UP2-3R3 UP2-4R7 UP2-6R8 UP2-8R2 UP2-100 UP2-150 UP2-220 UP2-330 UP2-470 UP2-680 UP2-820 UP2-101 UP2-151 UP2-221 UP2-331 UP2-471 Customer Information Rated OCL Inductance nominal +/-20% µH µH Note(1) .47 .595 1.0 1.00 1.5 1.46 2.2 2.39 3.3 3.3 4.7 4.77 6.8 6.63 8.2 8.71 10 9.73 15 15.43 22 22.50 33 33.13 47 48.65 68 68.17 82 85.60 100 102.60 150 152.70 220 230.00 330 338.00 471 471.8 I rms Amperes Note(2) 10.1 9.0 8.1 6.9 6.5 5.7 5.0 4.7 4.3 3.6 2.9 2.4 1.9 1.7 1.5 1.4 1.1 .93 .76 .55 Isat Amperes Note(3) DCR ohms (Ω) maximum. @ 20°C. 11.4 9.9 7.9 6.1 5.1 4.2 3.6 3.2 3.3 2.4 2.0 1.7 1.4 1.2 1.0 .95 .78 .62 .51 .44 .0049 .0081 .0103 .0115 .0138 .0173 .0230 .0245 .0299 .0449 .0644 .0989 .1461 .1898 .2473 .2772 .4244 .6360 .9775 1.31 Part number definition: First 3 characters = Product code and size. Last 3 characters = Inductance in µH. R=decimal point. If no R is present third character = # of zeros. THis Document Subject To Change Without Notice Uncontrolled Document Notes: Cooper Electronic Technologies (1) Test parameters: 0.250Vrms, 100KHz, and 0.0Adc. (2) Rms current for a ∆T of 40°C. at an ambient temeperature of 85°C.. (3) Peak current for approximateley a 10% rolloff. (4) Units supplied in tape and reel (600 units per 13” reel) packaging. EIA481 compliant. (5) OCL= Open circuit inductance . (6) Hipot: winding to core 300Vdc min. 3601 Quantum Boulevard,Boynton Boulevard,FL 33426 UniPAc 2 Data Sheet SIZE Drawing Number: A Revision Level: J UP2 Inductor Line
UP2-220-R
1. 物料型号:文档中列出了多种型号的UnipAc 2电感器,例如UP2-R47、UP2-1R0、UP2-1R5等,每个型号的最后三位数字代表电感值,例如“R47”表示0.47微亨。
2. 器件简介:UnipAc 2是一系列电感器,由Cooper Electronic Technologies生产,具有不同的额定电感值和电流承载能力。
3. 引脚分配:文档提供了电感器的PCB焊盘布局图,但未明确指出具体的引脚分配
4. 参数特性:列出了每个型号的额定电感值、OCL(开路电感)公差、Irms(有效值电流)、Isat(饱和电流)、DCR(直流电阻)等参数。
5. 功能详解:文档中提到了测试参数,例如在0.250Vrms、100KHz和0.0Adc条件下的测试,以及在85°C环境温度下40°C温度升高时的有效值电流。
6. 应用信息:文档中未明确提供应用信息,但电感器通常用于电源管理、信号过滤等电子电路中。
7. 封装信息:文档中提到了电感器的封装方式,单位以胶带和卷轴(每13英寸卷轴600个单位)供应,符合EIA481标准。
UP2-220-R 价格&库存
很抱歉,暂时无法提供与“UP2-220-R”相匹配的价格&库存,您可以联系我们找货
