Technical Data 4133
Effective July 2017
Supersedes March 2007
HCF1305
High frequency, high current power inductors
Applications
Next generation processors
High current DC-DC converters
VRM, multi-phase buck regulators
PC Workstations, Routers, Servers
Telecom soft switches
Base stations
Environmental data
Product features
12.5 mm x 12.5 mm x 5.0 mm surface mount
package
Ferrite core material
Inductors designed for higher speed switch
mode applications requiring low voltage and high
current
Design utilizes ferrite core with high DC bias
resistance and low core loss
Inductance range from 0.47 µH to 4.7 µH
Current range from 36.0 A to 10.4 A
Frequency range 100 kHz to 1 MHz
Storage temperature range (component):
-40 °C to +125 °C
Operating temperature range: -40 °C to +125 °C
(ambient plus self-temperature rise)
Solder reflow temperature:
J-STD-020 (latest revision) compliant
Pb HF
FREE
HALOGEN
Technical Data 4133
Effective July 2017
Product specifications
Part Number
Rated
Inductance
(µH)
0.47
0.56
1.00
1.20
1.80
2.20
3.00
3.30
4.00
4.70
HCF1305-R47-R
HCF1305-R56-R
HCF1305-1R0-R
HCF1305-1R2-R
HCF1305-1R8-R
HCF1305-2R2-R
HCF1305-3R0-R
HCF1305-3R3-R
HCF1305-4R0-R
HCF1305-4R7-R
OCL (1)
µH ± 20%
Irms (2)
Amperes
Isat (3)
Amperes
Isat2 (4)
Amperes
0.47
0.56
1.00
1.20
1.80
2.20
3.00
3.30
4.00
4.70
32.0
32.0
22.0
22.0
16.3
16.3
13.2
13.2
10.9
10.9
36.0
30.0
24.0
20.0
18.0
15.0
14.4
12.5
12.0
10.4
30.0
22.5
20.0
15.0
15.0
11.2
12.0
9.0
10.0
7.5
1) OCL: Open Circuit Inductance test parameters: 100 kHz, 0.1 Vrms, 0.0 Adc. OCL@-40 °C can
be lower than OCL@+20 °C by 15% max.
2) Irms: DC current for an approximate DT of 40 °C without core loss. Derating is necessary for
AC currents. PCB layout, trace thickness and width, air-flow, and proximity of other heat
generating components will affect the temperature rise. It is recommended that the
temperature of the part not exceed +125 °C under worst case operating conditions verified in
the end application.
3) Isat1: Amperes Peak for approximately 30% rolloff (@+25 °C)
4) Isat2: Amperes Peak for approximately 30% rolloff (@+125 °C)
DCR
mΩ@20°C
(Typical)
0.83
0.83
1.58
1.58
2.58
2.58
4.08
4.08
6.0
6.0
DCR
mΩ@20°C
(Maximum)
1.00
1.00
1.90
1.90
3.10
3.10
4.90
4.90
7.2
7.2
K-factor
(5)
21
21
14
14
10
10
8.3
8.3
6.9
6.9
5) K-factor: Used to determine B p-p for core loss (see graph). B p-p = K*L*∆I
B p-p:(mT), K: (K factor from table), L: (Inductance in µH), ∆I (Peak to peak ripple current in
Amps).
Part number definition:
HCF1305-XXX-R
HCF1305 = Product code and size
XXX = Inductance value in uH.
R = Decimal point. If no R is present, third character = #of zeros -R suffix
indicates RoHS compliant
Dimensions- mm
TOP V IEW
BOTTOM VI EW
A
DIMENSION TABLE
RECOMMENDED PCBLAYOU T
A: 12.5max
G: 4.00 Ref.
B: 12.5max
H: 5.40 Ref.
C: 5.0max
I: 3.00 Ref.
D: 2.00 ref
J: 4.00 Ref.
E: 2.40 +/- 0.10 K: 4.00 Ref.
F: 6.90 +/- 0.30 L: 3.4 Ref.
C
2
B
D
3
1
K
J
wwllyy=Date code, R=Revision Level
I
Do not route traces or vias underneath the inductor
Packaging information - mm
1.5 dia
+0.1/-0.0
4.0
1.5 dia
min
2.0
A
1.75
11.5
HCF 1305-X X X
wwlly y-R
B0
24.0
+/-0.3
K0
A0
A
16.00
SECTION A-A
A0= 12.60 mm
B0= 12.60 mm
K0= 5.50 mm
www.eaton.com/electronics
2
H
G
I
E
2
SCHEMAT IC
L
1
HCF1305-XXX
wwllyy R
FRONT VIEW
F
User direction of feed
Parts packaged on a 13" Diameter reel.
600 parts per reel.
HCF1305
Technical Data 4133
Effective July 2017
Temperature rise vs total loss
Temperature Rise (ºC)
100
80
60
40
0.8
1.2
1.6
2
Total Pow er Loss (W)
Core loss vs Bp-p
10
1 MHz
500 kHz
1
300 kHz
200 kHz
Core Loss (W)
100 kHz
0.1
0.01
0.001
0.0001
1
10
100
1000
Bp-p (m T)
Inductance characteristics
Normalized Rolloff Curves at 25 Deg. C
Normali
100.0%
90.0%
90.0%
80.0%
% of OCL
% of OC L
80.0%
70.0%
60.0%
R47, 1R0, 1R8, 3R0 and 4R0
R56, 1R2 and 2R2
3R3 and 4R7
70.0%
60.0%
50.0%
R47, 1R0, 1R8 , 3R0 and 4R0
R56, 1R2 and 2R2
3R3 and 4R7
40.0%
50.0%
40.0%
0.0%
Curves at 125 Deg. C
100.0%
30.0%
0.0%
20.0%
40.0%
60.0%
80.0%
% of I SAT1
100.0%
120.0%
140.0%
20.0%
40.0%
60.0%
80.0%
% of I SAT2
100.0%
120.0%
140.0%
3
HCF1305
Technical Data 4133
Effective July 2017
Solder Reflow Profile
TP
TC -5°C
Temperature
TL
25°C
Preheat
A
T smax
Table 1 - Standard SnPb Solder (Tc)
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
t
Volume
mm3
220°C
220°C
Table 2 - Lead (Pb) Free Solder (T c)
Tsmin
Package
Thickness
2.5mm
ts
Time 25°C to Peak
Volume
mm3
2000
260°C
245°C
245°C
Time
Reference JDEC J-STD-020
Profile Feature
Preheat and Soak
• Temperature min. (Tsmin)
• Temperature max. (Tsmax)
• Time (Tsmin to Tsmax) (ts)
Average ramp up rate Tsmax to Tp
Liquidous temperature (TL)
Time at liquidous (tL)
Peak package body temperature (TP)*
Time (tp)** within 5 °C of the specified classification temperature (Tc)
Average ramp-down rate (Tp to Tsmax)
Time 25°C to Peak Temperature
100°C
150°C
150°C
200°C
60-120 Seconds
60-120 Seconds
3°C/ Second Max.
3°C/ Second Max.
183°C
60-150 Seconds
217°C
60-150 Seconds
Table 1
Table 2
20 Seconds**
30 Seconds**
6°C/ Second Max.
6°C/ Second Max.
6 Minutes Max.
8 Minutes Max.
* Tolerance for peak profile temperature (Tp) is defined as a supplier minimum and a user maximum.
** Tolerance for time at peak profile temperature (tp) is defined as a supplier minimum and a user maximum.
Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written
approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly
used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user.
Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also
reserves the right to change or update, without notice, any technical information contained in this bulletin.
Eaton
Electronics Division
1000 Eaton Boulevard
Cleveland, OH 44122
United States
© 2017 Eaton
All Rights Reserved
Printed in USA
Publication No. 4133
July 2017
Eaton is a registered trademark.
All other trademarks are property
of their respective owners.
很抱歉,暂时无法提供与“HCF1305-4R0-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 600+21.67792600+2.71950
- 国内价格 香港价格
- 600+21.81865600+2.73716
