Technical Data 4107
Effective January 2016
Supersedes March 2007
UP0.4C
Unshielded drum core power inductors
Applications
Handheld/portable devices
Computers and peripherals
Gaming machines/consoles
DC-DC converters
Power supplies
General purpose filtering
Environmental Data
Product description
Protective case over core and winding
Frequency range 1 kHz to 2 MHz
Inductance range from 1.2 µH to 100 µH
Current range from 0.35 A to 3.33 A
6.6 mm x 4.45 mm footprint surface mount
package in a 2.92 mm height
Ferrite core material
Lead free and RoHS compliant
Storage temperature range (component):
-40 °C to +125 °C
Operating temperature range: -40 °C to +125 °C
(ambient plus self-temperature rise)
Solder reflow temperature: J-STD-020D
compliant
Pb
UP0.4C
Technical Data 4107
Product Specifications
Part Number4
Ordering Code5
OCL1 (μH) ± 20%
Irms2 (A)
Isat3 (A)
DCR (Ω)
maximum @ 20 °C
UP0.4C-1R0-R
UP0-4C-1R0-R
1.16
2.88
3.33
0.030
UP0.4C-1R5-R
UP0-4C-1R5-R
1.49
2.58
2.94
0.034
UP0.4C-2R2-R
UP0-4C-2R2-R
2.27
2.15
2.38
0.050
UP0.4C-3R3-R
UP0-4C-3R3-R
3.22
1.89
2.00
0.060
UP0.4C-4R7-R
UP0-4C-4R7-R
4.95
1.55
1.61
0.088
UP0.4C-6R8-R
UP0-4C-6R8-R
7.06
1.30
1.35
0.128
UP0.4C-100-R
UP0-4C-100-R
9.53
1.16
1.16
0.156
UP0.4C-150-R
UP0-4C-150-R
14.5
0.95
0.94
0.250
UP0.4C-220-R
UP0-4C-220-R
21.8
0.76
0.77
0.360
UP0.4C-270-R
UP0-4C-270-R
27.5
0.69
0.68
0.480
UP0.4C-330-R
UP0-4C-330-R
32.2
0.64
0.63
0.560
UP0.4C-390-R
UP0-4C-390-R
39.0
0.59
0.57
0.650
UP0.4C-470-R
UP0-4C-470-R
46.5
0.53
0.53
0.820
UP0.4C-680-R
UP0-4C-680-R
68.2
0.45
0.43
1.10
UP0.4C-101-R
UP0-4C-101-R
102.5
0.37
0.35
1.58
1. Open Circuit Inductance (OCL) Test Parameters: 100 kHz, 0.250 Vrms, 0.0 Adc
2. Irms: DC current for an approximate temperature rise of 40 °C without core loss. Derating is necessary
for AC currents. PCB layout, trace thickness and width, air-flow, and proximity of other heat generating
components will affect the temperature rise. It is recommended that the temperature of the part
not exceed 125 °C under worst case operating conditions verified in the end application.
3. Peak current for approximately 30% roll-off @ 20 °C
4 Part Number Definition: UP0.4C-xxx-R
UP0.4C= Product code and size
xxx= Inductance value in μH, R= decimal point, if no R is present then last character equals number of zeros
-R suffix = RoHS compliant
5. Use ordering code when ordering parts.
1
yww
xxx
Dimensions (mm)
2
2.40 4.45
max max
2.92
max
1.00 ref
(2x)
6.60
max
4.45
ref
RECOMMENDED PCB LAYOUT
4.06
1.4 (2x)
2.9
(2x)
Part marking: yww= date code, xxx=inductance value in uH, R=decimal point,
if no R is present then last character equals number of zeros.
Supplied in tape and reel packaging 2,500 parts per reel
Do not route traces or vias underneath the inductor
% of Initial Inductance
Inductance characteristics
100%
80%
60%
40%
20%
0%
0%
20%
40%
60%
80% 100% 120% 140% 160%
% of Isat
2
www.eaton.com/elx
SCHEMATIC
1
2
UP0.4C
Technical Data 4107
Solder reflow profile
TP
TC -5°C
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
Preheat
A
T smax
t
Table 1 - Standard SnPb Solder (Tc)
Package
Thickness
Volume
mm3
很抱歉,暂时无法提供与“UP0.4C-2R2-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 2500+8.540042500+1.07094
- 国内价格 香港价格
- 2500+7.612332500+0.95460
