BMQADY1010404R7MA1
BMQADY1010404R7MA1
    CHILISIN(奇力新)
    固定电感器 Nonstandard 4.7µH ±20%
BMQADY1010404R7MA1 数据手册
Form No.: QF-1274 Edition: 2 RoHS & Halogen Free & REACH Compliance. SPECIFICATION FOR APPROVAL Customer: TI Customer P/N: Drawing No: Quantity: 0 Pcs. Chilisin P/N: Date : 2020/03/24 BMQADY1010404R7MA1 SPECIFICATION ACCEPTED BY: COMPONENT ENGINEER ELECTRICAL ENGINEER MECHANICAL ENGINEER APPROVED REJECTED 奇力新電子股份有限公司 東莞奇力新電子(東莞廠)有限公司 Chilisin Electronics Corp No. 29, Alley 301, Tehhsin Rd., Hukou,Hsinchu 303, Taiwan TEL:+886-3- 599-2646 FAX:+886-3- 599-9176 E-mail:sales@chilisin.com http://www.chilisin.com Chilisin Electronics (Dongguan) Co., Ltd. No. 78, Puxing Rd., Yuliangwei Administration Area, Qingxi Town, Dongguan City, Guangdong,China TEL:+86-769-8773-0251~3 FAX: +86-769-8773-0232 E-mail:cect@chilisin.com 奇力新電子(越南廠)有限公司 Chilisin Electronics (Vietnam) Limited No 143 - 145, Road No 10, VSIP Hai Phong, Lap Le Commune, Thuy Nguyen Dist, Haiphong City, Vietnam Tel:84-316 255 688 Fax:84-316 255 689 E-mail:sales@chilisin.com Drawn by 李思穎 sherry.lee 奇力新電子(湖南廠)有限公司 HuNan Chilisin Electronics Technology Co., Ltd No. 8, Shaziao Liangshuijing Town, Yuanling County, Huaihua City, Hunan Province 419601, China Tel:86-745-867-5882 E-mail:cect@chilisin.com Checked by 吳韋邑 wayne.wu Approved by 葉信賢 Ben.Yeh YG20301733 BMQADY101040 Series Specification 1 Scope: This specification applies to large current and low loss SMD shielding power inductor. 2 Part Numbering: 3 Rating: Operating Temperature: -55℃ ~ 125℃(Including self - temperature rise) Storage Temperature: (on tape & reel): -20°C to +40°C; 75% RH max. 4 Marking: 5 Standard Testing Condition Temperature Humidity Unless otherwise specified Ordinary Temperature(15 to 35℃) Ordinary Humidity(25 to 85% RH) In case of doubt 20 to 30℃ 50 to 80 %RH BMQADY101040 Series Specification 6 Configuration and Dimensions: 7 Electrical Characteristics: Part No. Inductance (uH) Tolerance (±%) Test Freq. Irms (A)Typ. Isat (A)Typ. RDC(mΩ) Max.(Typ) Marking BMQADY101040R22MD1 0.22 20 100kHz,0.5 40(42) 55(60) 0.54(0.45) R22 BMQADY101040R33MD1 0.33 20 100kHz,0.5 32(35) 45(50) 0.68(0.62) R33 BMQADY1010401R0MD1 1 20 100kHz,0.5V 23(25) 26(30) 2.4(2.2) 1R0 BMQADY1010402R2MD1 2.2 20 100kHz,0.5V 15(15.6) 17(20) 4.7(4.3) 2R2 BMQADY1010404R7MA1 4.7 20 100kHz,0.5V 10.5(11) 13(14) 10.5(9.5) 4R7 ` Note: 1.Operating temperature range -55℃~125℃(Including self - temperature rise) 2.Isat for Inductance drop 30% from its value without current. 3.Irms for a 40℃ temperature rise from 25℃ ambient. 4.The part temperature (ambient + temp rise) should not exceed 125°C under worst case operating conditions. Circuit design 125°C under worst case operating conditions. Component placement, PWB trace size and thickness, airflow and other cooling provisions all affect the part temperature. Part temperature should be verified in the end application. 5.Absolute maximum voltage 30VDC BMQADY101040 Series Specification 8 BMQADY101040 Series 8.1 Construction: 8.2 Material List: BMQADY101040 Series Specification 9 Packaging: 9.1 Packaging -Cover Tape The force for tearing off cover tape is 10 to 130 grams in the arrow direction. 9.2 Packaging Quantity 9.3 Reel Dimensions BMQADY101040 Series Specification 9 Packaging: 9.4 Tape Dimensions in mm 10 Recommended Land Pattern: 11 Note: 1. Please make sure that your product has been evaluated and confirmed against your specifications when our product is mounted to your product. 2. Do not knock nor drop. 3. All the items and parameters in this product specification have been prescribed on the premise that our product is used for the purpose,under the condition and in the environment agreed upon between you and us. You are requested not to use our product deviating from such agreement. 4. Please keep the distance between transformer/coil and other components (refer to the standard IEC 950) 5. The moisture sensitivity level (MSL) of products is classified as level 1. BMQADY101040 Series Specification 12 Graph: BMQADY1010404R7MA1
BMQADY1010404R7MA1 价格&库存
很抱歉,暂时无法提供与“BMQADY1010404R7MA1”相匹配的价格&库存,您可以联系我们找货
