Technical Data 4330
Effective August 2017
Supersedes October 2011
SD7030
Low profile shielded drum core power inductors
Applications
Product features
Low profile 7.0 mm x 7.0 mm x 3.0 mm surface
mount package
Ferrite material shielded drum core
Inductance range from 1.5 µH to 680 µH
Current range from 0.21A to 5.5 A
Frequency range up to 1 MHz
Notebook, laptop computers
Digital cameras
LED Drivers
TFT LCD Bias supplies
Wireless handsets
Handheld instruments
Gaming consoles
GPS devices
Battery power, Li-lon, 2-cell
Environmental data
Storage temperature range (component):
-40 °C to +125 °C
Operating temperature range: -40 °C to +125 °C
(ambient plus self-temperature rise)
Solder reflow temperature:
J-STD-020 (latest revision) compliant
Pb HF
FREE
HALOGEN
Technical Data 4330
Product specifications
Part Number5
SD7030-1R5-R
SD7030-3R3-R
SD7030-3R9-R
SD7030-5R0-R
SD7030-6R0-R
SD7030-7R3-R
SD7030-8R0-R
SD7030-100-R
SD7030-120-R
SD7030-150-R
SD7030-180-R
SD7030-220-R
SD7030-260-R
SD7030-300-R
SD7030-390-R
SD7030-440-R
SD7030-560-R
SD7030-680-R
SD7030-820-R
SD7030-101-R
SD7030-121-R
SD7030-151-R
SD7030-181-R
SD7030-221-R
SD7030-271-R
SD7030-331-R
SD7030-391-R
SD7030-471-R
SD7030-561-R
SD7030-681-R
OCL1 μH ± 30%
1.5
3.3
4.1
4.9
5.8
7.0
7.8
10.0
11.5
14.6
17.3
21.0
24.9
30.0
39.7
43.4
54.4
66.6
81.4
95.5
115.2
145
174
211
264
317
381
460
561.0
677.2
Irms2 (A)
5.5
3.7
3.4
3.2
2.8
2.3
2.2
2.1
1.9
1.7
1.7
1.4
1.3
1.2
1.1
1.1
0.99
0.85
0.82
0.70
0.67
0.57
0.54
0.51
0.44
0.38
0.36
0.34
0.29
0.28
1 Open Circuit Inductance Test Parameters: 100 kHz, 0.1 Vrms, 0.0 Adc.
2 Irms: DC current for an approximate ΔT of 40 °C without core loss. Derating is necessary for AC
currents. PCB layout, trace thickness and width, air-flow, and proximity of other heat generating
components will affect the temperature rise. It is recommended that the temperature of the part not
exceed +125 °C under worst case operating conditions verified in the end application.
3 Isat Amps peak for approximately 35% rolloff (@ +25 °C)
Typ. DCR mΩ @ +25 °C
10
26
29
45
48
54
58
70
79
107
118
138
175
198
231
253
325
446
629
715
805
1102
1259
1438
1857
2150
2857
3206
Isat3 (A)
4.5
3.00
2.60
2.40
2.25
2.10
1.85
1.70
1.55
1.40
1.32
1.20
1.05
0.97
0.86
0.80
0.73
0.65
0.60
0.54
0.50
0.44
0.40
0.36
0.33
0.30
0.27
0.25
0.23
0.21
Max DCR mΩ @ +25 °C
12
24
27
31
35
54
58
65
70
84
95
128
142
165
210
238
277
304
390
535
755
858
966
1322
1475
1725
2228
2581
3428
3847
K-factor 4
32
22
19
17
16
13
12
11
10
9.3
8.8
7.6
6.9
6.4
5.7
5.3
4.9
4.3
4.0
3.6
3.3
2.9
2.7
2.4
2.2
2.0
1.8
1.7
1.5
1.4
4 K-factor: Used to determine Bp-p for core loss (see graph). Bp-p = K*L*ΔI, Bp-p(mT), K: (K factor from
table), L: (Inductance in μH), ΔI (Peak-to-peak ripple current in Amps).
5 Part Number Definition: SD7030-xxx-R
SD7030 = Product code and size; -xxx = Inductance
R = decimal point; If no R is present, third character equals number of zeros.
-R suffix = RoHS compliant
value
in
μH;
Dimensions-mm
Top View
Bottom View
Front View
Recommended Pad Layout
Schematic
Left View
Part Marking: xxx = inductance value in μH. R = decimal point. If no “R” is present, third character = # of zeros. wwlly or wwllyy = date code. R = revision level
Do not route traces or vias underneath the inductor
Packaging information-mm
Supplied in tape-and-reel packaging, 1500 parts per reel, 13” diameter reel.
2
www.eaton.com/electronics
SD7030
Technical Data 4330
Core loss vs Bp-p
1MHz
500kHz
300kHz
200kHz
100kHz
Temperature rise vs total loss
Inductance characteristics
-40°C
+25°C
+85°C
3
SD7030
Technical Data 4330
Solder Reflow Profile
TP
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
25°C
Preheat
A
T smax
t
TC -5°C
Table 1 - Standard SnPb Solder (Tc)
Volume
mm3
220°C
220°C
Table 2 - Lead (Pb) Free Solder (T c)
Tsmin
ts
Package
Thickness
2.5mm
Time 25°C to Peak
Volume
mm3
2000
260°C
245°C
245°C
Time
Reference JDEC J-STD-020
Profile Feature
Preheat and Soak
• Temperature min. (Tsmin)
• Temperature max. (Tsmax)
• Time (Tsmin to Tsmax) (ts)
Average ramp up rate Tsmax to Tp
Liquidous temperature (TL)
Time at liquidous (tL)
Peak package body temperature (TP)*
Time (tp)** within 5 °C of the specified classification temperature (Tc)
Average ramp-down rate (Tp to Tsmax)
Time 25°C to Peak Temperature
100°C
150°C
150°C
200°C
60-120 Seconds
60-120 Seconds
3°C/ Second Max.
3°C/ Second Max.
183°C
60-150 Seconds
217°C
60-150 Seconds
Table 1
Table 2
20 Seconds**
30 Seconds**
6°C/ Second Max.
6°C/ Second Max.
6 Minutes Max.
8 Minutes Max.
* Tolerance for peak profile temperature (Tp) is defined as a supplier minimum and a user maximum.
** Tolerance for time at peak profile temperature (tp) is defined as a supplier minimum and a user maximum.
Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written
approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly
used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user.
Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also
reserves the right to change or update, without notice, any technical information contained in this bulletin.
Eaton
Electronics Division
1000 Eaton Boulevard
Cleveland, OH 44122
United States
© 2017 Eaton
All Rights Reserved
Printed in USA
Publication No. 4330 BU-SB111167
August 2017
Eaton is a registered trademark.
All other trademarks are property
of their respective owners.
很抱歉,暂时无法提供与“SD7030-100-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1500+9.087811500+1.17719
- 3000+8.571403000+1.11030
- 4500+8.283454500+1.07300
- 7500+8.072357500+1.04566
