Technical Data 4451
Effective September 2017
Supersedes Marchl 2015
FPT705
Dual conductor, high current power inductors
Applications
Compatible with Picor® Cool-Power®
ZVS Buck and Buck-Boost Regulator Families
(Picor part number series PI33xx and PI34xx)
Environmental Data
Product features
Dual conductor, two-turn construction
Magnetically shielded
8.3 mm x 7.5 mm footprint surface mount package in a 5.35 mm height
Ferrite core material
Storage temperature range (component):
-55 °C to +125 °C
Operating temperature range: -55 °C to +125 °C
(ambient plus self-temperature rise)
Solder reflow temperature:
J-STD-020 (latest revision) compliant
HALOGEN
Pb HF
FREE
Picor® and Cool-Power® are trademarks of Vicor Corporation.
FPT705
Technical Data 4451
Product Specifications
Part Number5
OCL1
(nH) ±10%
Irms2
(A)
Isat3
(A)
DCR (mΩ)
@ +20 °C
±0.15 mΩ
FPT705-170-R
170 (±12%)
13
31
0.65
FPT705-190-R
190
13
28
0.65
FPT705-200-R
200
13
25
0.65
FPT705-230-R
230
13
23
0.65
FPT705-270-R
270
13
19
0.65
FPT705-300-R
300
13
17
0.65
1. Open Circuit Inductance (OCL) Test Parameters: 1.0 MHz, 0.1 Vrms, 0.0 Adc, +25 °C
2. Irms: DC current for an approximate temperature rise of 40 °C without core loss. Derating is necessary for AC currents.
PCB layout, trace thickness and width, air-flow, and proximity of other heat generating components will affect the
temperature rise. It is recommended that the temperature of the part not exceed +125 °C under worst case operating
conditions verified in the end application.
3. Isat Peak current for approximately 2% rolloff @ +25 °C
4. DCR tested from pins (1-2) and pins (4-3)
5. Part Number Definition: FPT705-xxx-R
FPT705 = Product code and size
xxx= Inductance value in nH,
-R suffix = RoHS compliant
Dimensions (mm)
Recommended Pad Layout
7.8
±0.5
5.35
max
0.60
±0.20
7.9
1.65
1.0
7.2
±0.3
1.25
±0.1
7.0
±0.3
3.7
B
0.40
1.7
1.5
±0.25
0.1
typ
A
Resist area
Part marking: FPT705, xxx=inductance value in nH, wwllyy= date code R= revision level
Soldering surfaces to be coplanar within 0.10 millimeters
DCR is measured from point “a” to point “b”
Pins 2 and 4 are connected through the PCB trace
Do not route traces or vias underneath the inductor
Packaging information (mm)
Supplied in tape and reel packaging, 1,000 parts per 13” diameter reel
4.0
1.5 dia
1.5 dia
2.0
A
1.75
7.5
8.2
5.55
A
7.4
12.0
Section A–A
Direction of Feed
2
www.eaton.com/electronics
Schematic
16.0
±0.3
FPT705
Technical Data 4451
Inductance characteristics
FPT705-170-R
110%
90%
90%
80%
80%
% of OCL
100%
% of OCL
100%
70%
60%
70%
60%
50%
50%
40%
40%
30%
10
15
30
35
FPT705-190-R
110%
40
45
50
30%
55
Idc (A)
10
110%
100%
100%
90%
90%
80%
80%
70%
60%
25
Idc (A)
30
35
40
45
50
70%
60%
50%
50%
10
15
FPT705-270-R
40%
FPT705-200-R
FPT705-230-R
40%
30%
FPT705-270-R, FPT705-300-R
110%
% of OCL
% of OCL
FPT705-200-R, FPT705-230-R
15
30%
Idc (A)
30
35
40
45
50
FPT705-300-R
10
15
30
35
40
Idc (A)
3
FPT705
Technical Data 4451
Solder reflow profile
TP
TC -5°C
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
Preheat
A
T smax
t
Table 1 - Standard SnPb Solder (Tc)
Package
Thickness
Volume
mm3
很抱歉,暂时无法提供与“FPT705-270-R”相匹配的价格&库存,您可以联系我们找货
