12/8/21, 1:54 AM
Heavy Current Chassis Mount (195-196 Series) - Hammond Mfg.
Quality Products. Service Excellence.
Heavy Current Chassis Mount 195-196 Series
Features
Open core & coil, 4-slot bracket mounting chokes.
Tolerance of 15% on both inductance & resistance.
Inductances measured at rated D.C. current.
The "195" series is single coil
The "196" series is dual coil - allowing more versatility
Recommended maximum operating voltage 600 VAC (winding to core).
Hipot tested at 2,500 VAC
Connections are made to a screw terminal or heavy copper tabs with holes
Perfect for high current power supply filtering.
For AC applications 60 Hz to 10,000 Hz try our 197 Series
195 Series
Inductance mH
D.C. Current
Resistance
Insulation
Part No.
(Millihenries)
(Amps)
(Ohms)
Class
A
B
C
D
E
195A200
0.3
200
0.0012
7.50
7.00
6.50
6.00
5.25
0.28
x
0.56
46
195B100
0.5
100
0.002
6.38
6.25
5.38
5.25
4.13
0.28
x
0.56
31
195B150
0.5
150
0.0018
B
5.25
5.50
4.47
4.38
4.13
0.28
x
0.56
26
195C20
1
A
3.00
3.06
2.50
2.50
2.25
0.20
x
0.38
3
195C30
1
30
0.009
A
3.75
3.85
3.13
3.13
2.50
0.20
x
0.38
6
195C50
1
50
0.005
A
4.50
5.25
3.75
3.75
3.50
0.20
x
0.38
14.5
195C75
1
75
0.004
A
5.25
6.00
4.47
4.38
4.63
0.28
x
0.56
23
195C100
1
100
0.0036
B
5.25
6.50
4.47
4.38
5.13
0.28
x
0.56
26
195D50
1.4
50
0.005
6.38
5.50
5.38
5.25
3.88
0.28
x
0.56
28
195E20
2.5
A
3.75
4.20
3.13
3.13
2.75
0.20
x
0.38
6.5
195E30
2.5
30
0.013
A
4.50
5.25
3.75
3.75
3.50
0.20
x
0.38
12.5
195E50
2.5
50
0.008
A
5.25
6.00
4.47
4.38
4.63
0.28
x
0.56
23.5
https://www.hammfg.com/electronics/transformers/choke/195-196
Dimensions
Mounting Slot
Weight
G
(lbs.)
1/3
12/8/21, 1:54 AM
Inductance mH
D.C. Current
Resistance
Insulation
Part No.
(Millihenries)
(Amps)
(Ohms)
Class
A
B
Dimensions
C
D
E
Mounting Slot
Weight
G
195E75
2.5
75
0.008
B
6.00
6.63
5.16
5.00
4.88
0.28
x
0.56
(lbs.)
32.5
195E100
88
2.5
100
0.006
B
9.00
9.75
7.50
7.00
6.00
0.44
x
0.75
195F30
4
30
0.018
6.38
5.00
5.38
5.25
3.25
0.28
x
0.56
23
195G10
5
10
0.04
A
3.75
3.60
3.13
3.13
2.25
0.20
x
0.38
5.5
195G20
5
A
4.50
4.75
3.75
3.75
3.00
0.20
x
0.38
10.5
195G25
5
25
0.014
5.25
6.00
4.44
4.38
3.63
0.28
x
0.56
18
195G30
5
30
0.023
A
5.25
5.00
4.47
4.38
3.63
0.28
x
0.56
16
195G50
5
50
0.021
B
7.50
6.50
6.25
6.00
4.50
0.38
x
0.63
38
195G75
5
75
0.01
B
9.00
9.50
7.76
7.00
7.00
0.44
x
0.75
87
195H20
7
5.25
6.00
4.44
4.38
3.63
0.28
x
0.56
17
195J10
10
10
0.07
A
3.75
4.35
3.13
3.13
3.00
0.20
x
0.38
8
195J12
10
12.5
0.072
B
4.12
3.25
3.44
3.44
2.34
0.20
x
0.38
195J20
10
A
5.25
5.00
4.47
4.38
3.63
0.28
x
0.56
17.5
195J30
10
30
0.037
A
6.00
7.50
5.00
5.00
5.88
0.31
x
0.50
36
195J50
10
50
0.023
B
9.00
9.75
7.50
7.00
6.25
0.44
x
0.75
79
195K12
15
12
0.062
5.25
5.50
4.44
4.38
3.13
0.28
x
0.56
14
195K16
15
16
0.062
5.25
6.00
4.44
4.38
3.63
0.28
x
0.56
17
195M10
0.013
A
4.50
4.75
3.75
3.75
3.00
0.20
x
0.38
10.2
195M20
A
6.00
7.50
5.00
5.00
5.88
0.31
x
0.50
34
195M30
0.045
B
6.00
7.63
5.16
5.00
5.88
0.28
x
0.56
41
195P5
30
5
0.23
A
3.75
4.20
3.13
3.13
2.75
0.20
x
0.38
6.5
195P8
30
8
0.3
4.12
3.75
3.50
3.43
3.00
0.20
x
0.38
195P10
30
10
0.17
A
4.50
5.25
3.75
3.75
3.50
0.20
x
0.38
16
195P20
30
B
5.25
6.91
4.47
4.38
5.54
0.28
x
0.56
28
195Q2
35
2
0.61
B
2.63
2.00
2.21
2.19
1.75
0.19
x
0.38
195Q6
40
6
0.4
3.75
3.62
3.25
3.12
3.00
0.20
x
0.38
195R10
50
10
0.165
A
5.25
5.50
4.47
4.38
4.13
0.28
x
0.56
26
195R20
50
B
9.00
8.25
7.50
7.00
5.75
0.44
x
0.75
72
195S2
70
2
0.9
3.37
2.75
2.87
2.81
2.12
0.20
x
0.38
195S4
70
4
0.6
3.75
3.25
3.13
3.13
2.50
0.20
x
0.38
195T1
100
1
1.5
3.00
2.50
2.50
2.50
2.00
0.20
x
0.38
195T5
100
5
0.64
A
4.50
5.25
3.75
3.75
3.50
0.20
x
0.38
14
195T10
100
10
0.42
B
7.50
6.00
6.25
6.00
4.25
0.38
x
0.63
35
196 Series - Dual Coil - Heavy Current Chokes
Parallel Connected
Series Connected
Resistance
Mounting
Inductance mH
D.C. Current
Inductance mH
Part No.
(Millihenries)
(Amps)
(Millihenries)
(Amps)
(Ohms)
Class
196B50
0.125
100
0.5
50
0.018
4.50 4.50 3.75 3.75 3.00 0.28 x 0.56
8.00
196D25
0.3
50
1.2
25
0.005
3.75 4.25 3.13 3.13 2.75 0.28 x 0.56
6.45
196G12
1.2
24
4.8
12
0.024
3.38 3.56 2.81 2.81 3.00 0.20 x 0.38
6
3
12
12
6
0.056
3.37 3.06 2.81 2.81 2.50 0.20 x 0.38
4.45
196M4
5
8
0.11
3.00 2.87 2.50 2.50 2.50 0.20 x 0.38
3.3
196Q2
10
4
40
2
0.24
3.12 2.12 2.75 2.81
0.19
1.85
196S1
18
2
72
1
0.553
2.00 2.00 2.31 2.38
0.19
1.4
196K6
D.C. Current (Each Winding) Insulation
Overall Dimensions
A
B
C
D
E
Slot
Weight
G
(lbs.)
Data subject to change without notice
© 2021. Hammond Manufacturing Ltd. All rights reserved.
2/3
12/8/21, 1:54 AM
3/3
很抱歉,暂时无法提供与“195T10”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+3908.083391+503.82734
- 10+3413.3541110+440.04719
