HCM1A1105V2-R72-R
HCM1A1105V2-R72-R
    EATON(伊顿)
    固定电感器 Nonstandard 720nH ±20% 23A 1.71mΩ 54MHz
HCM1A1105V2-R72-R 数据手册
Technical Data 10909 Effective April 2019 HCM1A1105V2 Automotive grade high current power inductors Applications • • Product features • AEC-Q200 qualified • High current carrying capacity • Body electronics • Central body control module • Headlamps, tail lamps and interior lighting and LED lighting • Heating ventilation and air conditioning controllers (HVAC) • Doors, window lift and seat control Advanced driver assistance systems • Adaptive cruise control (ACC) • Automatic parking control • Collision avoidance system/ Car black box system Infotainment and cluster electronics • Audio subsystem: head unit and trunk amp • Digital instrument cluster • In-vehicle infotainment (IVI) and navigation • Port power/USB HUB for front and rear passengers • Magnetically shielded, low EMI • DC-DC converter applications up to 1 MHz • Filtering applications up to Self Resonant Frequency (SRF) [See product specification table] • Inductance range from 0.68 μH to 68 μH • Electronic stability control system (ESC) • Current range from 2.3 A to 30 A • Electric parking brake • 11.2 mm x 10.3 mm footprint surface mount package in a 5.0 mm height • Moisture Sensitivity Level (MSL): 1 • Alloy powder core material • • Chassis and safety electronics • Airbag control unit Engine and Powertrain Systems • Electric pumps, motor control and auxiliaries • Powertrain control module (PCU)/ Engine Control unit (ECU) • Transmission Control Unit (TCU) Environmental data • Storage temperature range (Component): -55 °C to +155 °C • Operating temperature range: -55 °C to +155 °C (ambient plus self-temperature rise) • Solder reflow temperature: J-STD-020 (latest revision) compliant HALOGEN Pb HF FREE HCM1A1105V2 Automotive grade high current power inductors  Technical Data 10909 Effective April 2019 Product specifications Part number6 OCL1 (μH) ± 20% FLL2 (μH) minimum Irms3 (A) Isat4 (A) DCR (mΩ) typical @ +20 °C DCR (mΩ) maximum @ +20 °C SRF (MHz) typical K-factor5 HCM1A1105V2-R68-R 0.68 0.44 24.5 30 1.65 1.93 57 283 HCM1A1105V2-R72-R 0.72 0.46 23 24 1.55 1.71 54 298 HCM1A1105V2-R90-R 0.90 0.58 22 23 1.74 2.02 42 262 HCM1A1105V2-1R0-R 1.0 0.64 20 24 2.10 2.40 44 218 HCM1A1105V2-1R2-R 1.2 0.77 21 21 2.10 2.40 37 222 HCM1A1105V2-1R5-R 1.5 0.96 16.5 20 2.90 3.34 31 232 HCM1A1105V2-2R2-R 2.2 1.41 14.5 19 3.90 4.49 24 161 HCM1A1105V2-2R8-R 2.8 1.79 12 18 5.20 6.00 21 122 HCM1A1105V2-3R3-R 3.3 2.11 9.5 16 9.23 10.7 18 96 HCM1A1105V2-4R7-R 4.7 3.01 8.5 13 11.7 13.5 14 90 HCM1A1105V2-5R6-R 5.6 3.58 8.0 12 14.0 16.5 13 98 HCM1A1105V2-6R8-R 6.8 4.35 7.0 10 17.1 20.0 11 70 HCM1A1105V2-100-R 10 6.40 6.2 7.0 22.0 27.0 9 74 HCM1A1105V2-120-R 12 7.68 5.0 8.0 31.2 35.9 9 56 HCM1A1105V2-150-R 15 9.60 4.7 7.0 34.7 40.3 7 65 HCM1A1105V2-220-R 22 14.1 4.0 6.0 52.3 61.0 5 42 HCM1A1105V2-330-R 33 21.1 3.5 3.5 70.0 84.0 4 44 HCM1A1105V2-470-R 47 30.1 3.0 3.0 97.6 117 3 35 HCM1A1105V2-680-R 68 43.5 2.3 4.0 160 211 3 25 1. Open Circuit Inductance (OCL) Test Parameters: 100 kHz, 0.25 Vrms, 0.0 Adc, +25 °C 2. Full Load Inductance (FLL) Test Parameters: 100 kHz, 0.25 Vrms, Isat, , +25 °C 3. Irms: DC current for an approximate temperature rise of 30 °C without core loss. Derating is necessary for AC currents. PCB layout, trace thickness and width, air-flow, and proximity of other heat generating components will affect the temperature rise. It is recommended that the temperature of the part not exceed +155 °C under worst case operating conditions verified in the end application. 4. Isat: Peak current for approximately 20% rolloff @ +25 °C 5. K-factor: Used to determine Bp-p for core loss (see graph). Bp-p = K * L * ΔI. Bp-p: (Gauss), K: (K-factor from table), L: (Inductance in μH), ΔI (Peak to peak ripple current in Amps). 6. Part Number Definition: HCM1A1105V2-xxx-R HCM1A1105V2 = Product code and size xxx= inductance value in μH, R= decimal point, If no R is present then last character equals number of zeros -R suffix = RoHS compliant Dimensions (mm) Schematic 1 2 Part marking: 1AxxxV2, xxx=inductance value in uH, R=decimal point. If no R is present then last character equals number of zeros. xxxx=Lot code All soldering surfaces to be coplanar within 0.1 millimeters Tolerances are ±0.3 millimeters unless stated otherwise Pad layout tolerances are ±0.1 millimeters unless stated otherwise DCR measured from point “a” to point “b” Do not route traces or vias underneath the inductor 2 www.eaton.com/electronics Technical Data 10909 HCM1A1105V2 Automotive grade high current power inductors Effective April 2019  Packaging information (mm) Drawing not to scale Supplied in tape and reel packaging, 500 parts per 13” diameter reel Core loss vs Bp-p HCM1A1105V2-R72-R HCM1A1105V2-R68-R 10000 1000 700 kHz 500 kHz 300 kHz 1000 700 kHz 500 kHz 300 kHz 100 100 kHz 50 kHz 100 100 kHz 50 kHz 10 1 Core Loss (mW) Core Loss (mW) 10000 1 0.1 0.1 0.01 10 0.01 100 1000 Bp-p (Gauss) HCM1A1105V2-1R0-R HCM1A1105V2-R90-R 10000 1000 700 kHz 500 kHz 300 kHz 1000 100 100 kHz 50 kHz 100 10 1 Core Loss (mW) Core Loss (mW) 10000 700 kHz 500 kHz 300 kHz 100 kHz 50 kHz 10 1 0.1 0.1 0.01 1000 100 Bp-p (Gauss) 0.01 100 1000 Bp-p (Gauss) 1000 100 Bp-p (Gauss) www.eaton.com/electronics 3 HCM1A1105V2 Automotive grade high current power inductors  Technical Data 10909 Effective April 2019 Core loss vs Bp-p HCM1A1105V2-1R2-R HCM1A1105V2-1R5-R 10000 10000 100 700 kHz 500 kHz 300 kHz 1000 100 kHz 50 kHz 100 10 1 0.1 0.01 Core Loss (mW) Core Loss (mW) 1000 700 kHz 500 kHz 300 kHz 100 kHz 50 kHz 10 1 0.1 100 0.01 1000 Bp-p (Gauss) 1000 100 Bp-p (Gauss) HCM1A1105V2-2R2-R HCM1A1105V2-2R8-R 10000 1000 700 kHz 500 kHz 300 kHz 100 100 kHz 50 kHz 10 1 0.1 0.01 700 kHz 500 kHz 300 kHz 1000 Core Loss (mW) Core Loss (mW) 10000 100 kHz 100 50 kHz 10 1 0.1 100 0.01 1000 Bp-p (Gauss) Bp-p (Gauss) HCM1A1105V2-3R3-R HCM1A1105V2-4R7-R 10000 10000 700 kHz 500 kHz 300 kHz 100 kHz 50 kHz 100 10 1 0.1 100 kHz 50 kHz 100 10 1 0.1 100 1000 Bp-p (Gauss) 4 700 kHz 500 kHz 300 kHz 1000 Core Loss (mW) Core Loss (mW) 1000 0.01 1000 100 www.eaton.com/electronics 0.01 100 1000 Bp-p (Gauss) Technical Data 10909 HCM1A1105V2 Automotive grade high current power inductors Effective April 2019  Core loss vs Bp-p HCM1A1105V2-6R8-R HCM1A1105V2-5R6-R 10000 10000 Core Loss (mW) 100 10 1 100 10 1 0.1 0.1 0.01 700 kHz 500 kHz 300 kHz 100 kHz 50 kHz 1000 Core Loss (mW) 700 kHz 500 kHz 300 kHz 100 kHz 50 kHz 1000 0.01 100 1000 Bp-p (Gauss) HCM1A1105V2-100-R HCM1A1105V2-120-R 10000 10000 Core Loss (mW) 100 10 1 0.1 100 50 kHz 10 1 0.1 100 0.01 1000 Bp-p (Gauss) 1000 HCM1A1105V2-220-R HCM1A1105V2-150-R 10000 100 10 1 700 kHz 500 kHz 300 kHz 100 kHz 50 kHz 1000 Core Loss (mW) 700 kHz 500 kHz 300 kHz 100 kHz 50 kHz 1000 100 10 1 0.1 0.1 0.01 100 Bp-p (Gauss) 10000 Core Loss (mW) 700 kHz 500 kHz 300 kHz 100 kHz 1000 Core Loss (mW) 700 kHz 500 kHz 300 kHz 100 kHz 50 kHz 1000 0.01 1000 100 Bp-p (Gauss) 0.01 100 1000 Bp-p (Gauss) 1000 100 Bp-p (Gauss) www.eaton.com/electronics 5 HCM1A1105V2 Automotive grade high current power inductors  Technical Data 10909 Effective April 2019 Core loss vs Bp-p HCM1A1105V2-330-R HCM1A1105V2-470-R 10000 10000 100 700 kHz 500 kHz 300 kHz 1000 100 kHz 50 kHz 100 10 1 0.1 0.01 100 1 700 kHz 500 kHz 300 kHz 100 kHz 50 kHz 1000 100 10 1 0.1 100 1000 Bp-p (Gauss) www.eaton.com/electronics 100 1000 Bp-p (Gauss) HCM1A1105V2-680-R Core Loss (mW) 100 kHz 50 kHz 10 0.01 1000 10000 6 700 kHz 500 kHz 300 kHz 0.1 Bp-p (Gauss) 0.01 Core Loss (mW) Core Loss (mW) 1000 Technical Data 10909 HCM1A1105V2 Automotive grade high current power inductors Effective April 2019  Inductance and impedance vs. frequency HCM1A1105V2-R68-R HCM1A1105V2-R72-R 1000 Impedance 100 1 10 1 Inductance 0 0.1 1 10 100 Frequency (MHz) 1.5 Inductance 0.5 0.1 0 10 0.1 1 1 10 100 Frequency (MHz) 0.1 HCM1A1105V2-1R0-R 4 4 10000 10000 3.5 3.5 1000 2.5 100 Impedance 2 10 1.5 1 1 Inductance 0.5 0.1 1 10 100 Frequency (MHz) Inductance (uH) 3 Impedance (Ohm) 2.5 1 0 4 100 Impedance 10 2 1 Inductance 10 Frequency (MHz) 1 10 Frequency (MHz) 100 0.1 100 0.1 10000 7 Inductance (uH) Inductance (uH) 1000 1 0.1 8 10000 0.1 1 Inductance HCM1A1105V2-1R5-R 5 0 10 1.5 0.1 6 1 100 Impedance 2 HCM1A1105V2-1R2-R 3 1000 3 0.5 Impedance (Ohm) Inductance (uH) Impedance 1 HCM1A1105V2-R90-R 0 100 Impedance (Ohm) 0.5 1000 1000 6 Impedance 5 100 4 10 3 2 0 1 Inductance 1 0.1 1 10 Frequency (MHz) 100 www.eaton.com/electronics Impedance (Ohm) 1.5 10000 2 Inductance (uH) Inductance (uH) 2 2.5 Impedance (Ohm) 10000 Impedance (Ohm) 2.5 0.1 7 HCM1A1105V2 Automotive grade high current power inductors  Technical Data 10909 Effective April 2019 Inductance and impedance vs. frequency HCM1A1105V2-2R8-R HCM1A1105V2-2R2-R 100 Impedance 6 10 4 1 Inductance 0.1 1 10 100 Frequency (MHz) 1000 12 8 10 6 4 0 0.1 1 0.1 40 10000 10000 20 100 Impedance 15 10 10 1 5 Inductance 0.1 1 10 Frequency (MHz) 100 1000 30 Inductance (uH) 1000 Impedance (Ohm) 35 25 Inductance (uH) 100 HCM1A1105V2-4R7-R 30 25 Impedance 10 15 10 0 1 Inductance 0.1 HCM1A1105V2-5R6-R 10000 45 Impedance 30 100 25 20 10 15 10 1 5 0 Inductance 0.1 1 10 Frequency (MHz) www.eaton.com/electronics 100 0.1 10 Frequency (MHz) 100 0.1 HCM1A1105V2-6R8-R 60 10000 1000 Inductance (uH) Inductance (uH) 35 1 50 1000 Impedance (Ohm) 40 100 20 5 0.1 50 8 10 Frequency (MHz) HCM1A1105V2-3R3-R 0 1 Inductance 2 0.1 100 Impedance 10 Impedance (Ohm) 2 0 14 40 100 Impedance 30 10 20 1 10 0 Inductance 0.1 1 10 Frequency (MHz) 100 0.1 Impedance (Ohm) 8 1000 10000 16 Impedance (Ohm) 10 18 Inductance (uH) Inductance (uH) 12 10000 Impedance (Ohm) 14 Technical Data 10909 HCM1A1105V2 Automotive grade high current power inductors Effective April 2019  Inductance and impedance vs. frequency HCM1A1105V2-120-R HCM1A1105V2-100-R 60 Impedance 100 40 10 30 20 1 10 0 Inductance 0.1 1 10 100 10000 80 60 10 20 1 Inductance 0.1 1 100000 140 100 60 10 40 1 Inductance 0.1 1 10 100 1000 Impedance 100 10 1 Inductance 0.1 1 10 100 HCM1A1105V2-470-R 150 100 100 10 50 1 Inductance 1 10 Frequency (MHz) 100 0.1 100000 450 10000 400 Inductance (uH) 1000 Impedance 0.1 500 10000 0.1 10000 HCM1A1105V2-330-R 100000 200 0.1 100000 Frequency (MHz) 250 0 220 200 180 160 140 120 100 80 60 40 20 0 Frequency (MHz) 300 Inductance (uH) 0.1 Inductance (uH) Impedance Impedance (Ohm) Inductance (uH) 1000 100 Impedance (Ohm) 10000 120 0 100 HCM1A1105V2-220-R HCM1A1105V2-150-R 160 20 10 Frequency (MHz) Frequency (MHz) 80 100 40 0 0.1 1000 Impedance Impedance (Ohm) 50 100 Impedance (Ohm) 1000 100000 350 1000 Impedance 300 250 100 200 10 150 100 1 50 0 Impedance (Ohm) Inductance (uH) 70 120 Inductance (uH) 10000 Impedance (Ohm) 80 Inductance 0.1 1 10 100 0.1 Frequency (MHz) www.eaton.com/electronics 9 HCM1A1105V2 Automotive grade high current power inductors  Technical Data 10909 Effective April 2019 Inductance and impedance vs. frequency HCM1A1105V2-680-R 100000 10000 500 1000 Impedance 400 100 300 10 200 1 100 0 Impedance (Ohm) Inductance (uH) 600 Inductance 0.1 1 10 100 0.1 Frequency (MHz) Inductance and temperature rise vs. current HCM1A1105V2-R68-R HCM1A1105V2-R72-R 0.4 0.3 0.2 Temperature rise 0.1 0.0 0 10 20 30 40 50 Idc (A) 60 70 80 90 100 0.7 90 0.6 60 0.4 50 0.3 40 0.2 0.8 80 OCL (uH) 10 70 Inductance 60 0.5 50 0.4 40 0.3 30 0.2 20 0.0 Temperature rise 0 10 20 30 Idc (A) www.eaton.com/electronics 10 40 20 0.1 0.0 50 60 0 OCL (uH) 90 Temperature rise (℃ ) 100 0.9 0.1 30 Temperature rise 10 0.0 15.0 30.0 Idc (A) 45.0 0 60.0 HCM1A1105V2-1R0-R 1.0 0.6 70 0.5 HCM1A1105V2-R90-R 0.7 80 Inductance T emperature rise ( ℃) OCL (uH) 0.5 Temperature rise℃ ( ) Inductance 0.8 1.1 1.0 0.9 0.8 0.7 0.6 0.5 0.4 0.3 0.2 0.1 0.0 100 90 80 Inductance 70 60 50 40 30 20 Temperature rise 0 10 20 30 Idc (A) 10 40 50 60 0 Temperature rise (℃) 0.6 100 90 80 70 60 50 40 30 20 10 0 OCL (uH) 0.7 Technical Data 10909 HCM1A1105V2 Automotive grade high current power inductors Effective April 2019  Inductance and temperature rise vs. current 1.6 100 90 1.4 90 80 Inductance 70 60 50 40 30 Temperature rise 16 24 32 Idc (A) 40 48 60 0.8 50 0.6 40 0.4 10 0.2 0 0.0 0 5 10 15 60 50 40 30 Temperature rise 20 OCL (uH) 70 24 Idc (A) 30 36 42 48 1.5 40 50 30 Temperature rise 20 0.5 12 16 20 Idc (A) 24 80 70 60 50 40 30 Temperature rise 20 10 0 4 8 12 16 20 Idc (A) Idc (A) 24 28 32 0 36 28 32 36 100 4.5 90 Inductance 4.0 OCL (uH) OCL (uH) 2.0 60 Temperature rise (℃) 80 70 8 90 5.0 90 Inductance 4 0 55 1.0 0.0 100 0 50 HCM1A1105V2-4R7-R 2.5 0.0 45 1.5 0 3.5 1.0 Idc (A) 40 2.0 HCM1A1105V2-3R3-R 3.0 35 Inductance 0.5 10 18 30 100 2.5 Temperature rise (℃) OCL (uH) 80 Inductance 12 25 3.0 90 6 20 HCM1A1105V2-2R8-R 100 0 20 10 HCM1A1105V2-2R2-R 2.4 2.2 2.0 1.8 1.6 1.4 1.2 1.0 0.8 0.6 0.4 0.2 0.0 30 Temperature rise Temperature rise (℃) 8 70 1.0 80 3.5 70 3.0 60 2.5 50 2.0 40 1.5 10 1.0 0 0.5 0.0 30 Temperature rise 20 Temperature rise (℃) 0 20 80 Inductance 1.2 Temperature rise (℃) 100 OCL (uH) 1.3 1.2 1.1 1.0 0.9 0.8 0.7 0.6 0.5 0.4 0.3 0.2 0.1 0.0 HCM1A1105V2-1R5-R Temperature rise (℃) OCL (uH) HCM1A1105V2-1R2-R 10 0 5 10 15 20 25 30 www.eaton.com/electronics 0 11 HCM1A1105V2 Automotive grade high current power inductors  Technical Data 10909 Effective April 2019 Inductance and temperature rise vs. current HCM1A1105V2-5R6-R HCM1A1105V2-6R8-R 80 70 60 50 3 40 2 30 Temperature rise 2 4 6 8 10 12 14 16 18 20 22 24 26 4 60 3 40 50 0 2 4 6 HCM1A1105V2-100-R 8 10 100 10 90 60 6 50 5 40 4 30 3 20 Temperature rise 1 10 0 0 6 8 10 Idc (A) 12 14 16 18 20 12 60 10 50 8 40 6 30 4 Temperature rise 12 2 3 4 5 www.eaton.com/electronics 6 Idc (A) 7 8 70 60 6 40 50 30 20 Temperature rise 0 2 4 6 8 10 10 12 Idc (A) 14 16 18 0 9 10 11 12 90 80 Inductance 70 16 60 50 12 40 8 20 4 10 0 0 100 20 OCL (uH) OCL (uH) 70 1 80 Inductance 24 80 0 0 HCM1A1105V2-220-R 14 0 24 90 2 90 2 22 4 100 Inductance 16 20 8 0 HCM1A1105V2-150-R 18 18 100 10 OCL (uH) 70 7 4 Idc (A) 16 12 Temperatur e rise (eC) OCL (uH) 80 Inductance 2 14 14 Temperature rise (℃) 9 0 12 HCM1A1105V2-120-R 11 2 20 10 0 0 Idc (A) 8 30 Temperature rise 1 10 0 70 2 20 80 5 Temperature rise (℃) 1 90 Inductance 30 Temperature rise 20 10 0 1 2 3 4 5 6 Idc (A) 7 8 9 10 11 12 0 Temperature rise (℃) OCL (uH) 4 100 6 OCL (uH) Inductance Temperature rise (°C) 5 0 7 90 Temperature rise (℃) 100 6 Technical Data 10909 HCM1A1105V2 Automotive grade high current power inductors Effective April 2019  Inductance and temperature rise vs. current 90 80 Inductance 70 60 50 40 30 Temperature rise 20 10 0.0 1.0 2.0 3.0 4.0 5.0 6.0 7.0 8.0 9.0 10.0 11.0 48 100 42 90 80 Inductance 36 70 30 60 24 50 18 40 30 Temperature rise 12 20 6 0 0 Idc (A) Temperature rise (℃) 100 OCL (uH) 34 32 30 28 26 24 22 20 18 16 14 12 10 8 6 4 2 0 HCM1A1105V2-470-R Temperature rise (℃) OCL (uH) HCM1A1105V2-330-R 10 0.0 1.0 2.0 3.0 4.0 5.0 Idc (A) 6.0 7.0 8.0 9.0 0 HCM1A1105V2-680-R 70 100 90 Inductance 80 OCL (uH) 50 70 60 40 50 30 40 20 30 Temperature rise 20 10 0 Temperature rise (℃) 60 10 0 1 2 3 4 5 Idc (A) 6 7 8 9 10 0 www.eaton.com/electronics 13 Technical Data 10909 HCM1A1105V2 Automotive grade high current power inductors  Effective April 2019 Solder reflow profile TP TC -5°C tP Max. Ramp Up Rate = 3°C/s Max. Ramp Down Rate = 6°C/s Temperature TL Preheat A T smax Package thickness Volume mm3
HCM1A1105V2-R72-R 价格&库存
很抱歉,暂时无法提供与“HCM1A1105V2-R72-R”相匹配的价格&库存,您可以联系我们找货
HCM1A1105V2-R72-R
  • 500+6.87978
  • 15000+5.71905
库存:500
HCM1A1105V2-R72-R
  • 500+8.97646500+1.16469
库存:300
