Technical Data 10155
Effective March 2015
Supersedes March 2014
Coiltronics FP1008 Family
High frequency, high current power inductors
Applications
Multi-phase and Vcore regulators
Voltage Regulator Modules (VRMs)
Desktop and server VRMs and EVRDs
Laptop and notebook regulators
Data networking and storage systems
Graphics cards and battery power systems
Point-of-Load modules
DCR Sensing circuits
Environmental data
Product description
High current carrying capacity
Low core loss
Controlled DCR for sensing circuits
Inductance range from 120nH to 180nH
Current range from 63 to 100 Amps
10.8 x 8.0mm footprint surfaace mount package
in a 8.0mm height
Ferrite core material
Halogen free, lead free, RoHS compliant
Storage temperature range (Component):
-40°C to +125°C
Operating temperature range: -40°C to +125°C
(ambient + self-temperature rise)
Solder reflow temperature:
J-STD-020D compliant
HALOGEN
Pb HF
FREE
The Coiltronics brand of
magnetics (formerly of
the Bussmann Division of
Cooper Industries)
is now part of
Eaton’s Electrical Group,
Electronics Division.
Coiltronics is now
part of Eaton
Same great
products plus
even more.
FP1008 Family
Product specifications
Part Number9
OCL1
(nH)±10%
FLL2
(nH) minimum
Irms3
(amps)
Isat14
(amps)
Isat25
(amps)
Isat36
(amps)
Isat47
(amps)
DCR (mΩ)
@ 20°C ±5%
K-factor8
FP1008-120-R
120
82
63
100
95.0
91.0
82
0.17
366
FP1008-150-R
150
104
63
82
78.0
75.0
68
0.17
366
FP1008-180-R
180
130
63
64
60.8
58.6
53
0.17
366
1. Open Circuit Inductance (OCL) Test Parameters: 100kHz, 0.1Vrms, 0.0Adc @ 25°C
2. Full Load Inductance (FLL) Test Parameters: 100kHz, 0.1Vrms, Isat1
3. Irms: DC current for an approximate temperature rise of 40°C without core loss. Derating is necessary for AC currents. PCB layout, trace thickness and width, air-flow, and proximity of other heat
generating components will affect the temperature rise. It is recommended that the temperature
of the part not exceed 125°C under worst case operating conditions verified in the end application.
4. Isat1: Peak current for approximately 20% rolloff @ 25°C
5. Isat2: Peak current for approximately 20% rolloff @ 85°C
6. Isat3: Peak current for approximately 20% rolloff @ 100°C
7. Isat4: Peak current for approximately 20% rolloff @ 125°C
8. K-factor: Used to determine Bp-p for core loss (see graph).
Bp-p = K * L * ∆I * 10-3. Bp-p:(Gauss), K: (K-factor from table),
L: (Inductance in nH), ∆I (Peak-to-peak ripple current in Amps).
9. Part Number Definition: FP1008-xxx-R
- FP1008= Product code and size
- xxx= Inductance value in nH
- “-R” suffix = RoHS compliant
Dimensions (mm)
Recommended Pad Layout
2.5
±0.1
A
3.0
2.6
FP1008-XXX
wwllyy R
2.6
10.0 10.8
max. max.
4.06
3.56
2.5
B
8.0
max.
2
www.eaton.com/elx
8.0
max.
DCR measured from point “A” to point “B”
Part marking: FP1008-xxx, xxx = inductance value in nH
wwllyy = date code, R = revision level
Tolerances are ±0.205 millimeters unless stated otherwise.
All soldering surfaces to be coplanar within 0.1 millimeter
Do not route traces or vias underneath the inductor
11.18
Schematic
FP1008 Family
Packaging information (mm)
Supplied in tape-and-reel packaging, 350 parts on a 13” diameter reel.
1.5 dia
1.75
4.0
2.0
8.3
11.5
10.4
24.0
+/–0.3
16.0
1.5 dia
User Direction of Feed
Section A – A
1M
80 Hz
50 kH
0 z
30 kH
0k z
Hz
10
0k
Hz
Core loss vs. B p-p
10
Core Loss (W)
1
0.1
0.01
0.001
100
1000
10000
B p-p (Gauss)
www.eaton.com/elx
3
FP1008 Family
Inductance characteristics
FP1008-120-R
120
100
% of OCL
80
60
40
60
80
100
120
140
Idc (Amps)
FP1008-150-R
120
100
% of OCL
80
60
40
60
Idc (Amps)
4
www.eaton.com/elx
80
100
120
FP1008 Family
FP1008-180-R
120
100
% of OCL
80
60
40
60
80
100
Idc (Amps)
www.eaton.com/elx
5
FP1008 Family
Solder reflow profile
Table 1 - Standard SnPb Solder (Tc)
Package
Thickness
Volume
mm3
很抱歉,暂时无法提供与“FP1008-150-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 350+1.51689
- 700+1.41583
- 1050+1.37903
- 1750+1.34415
- 3500+1.31093
- 8750+1.27935
- 17500+1.24923
