506WLSN10R7KT150T
506WLSN10R7KT150T
    ATC
    固定电感器 Nonstandard 10.7µH ±10% 150mA 7.1Ω
506WLSN10R7KT150T 数据手册
AT C 5 0 6 W L S S E R I E S U B L S M T I N D U C T O R S ATC 506WLSN10R7KT150T Ultra-Broadband SMT Inductor Features: • Inductance: 10.7 µH • Operating Frequency: 400 KHz (-3 dB roll-off) through 40+ GHz, typ. • Insertion Loss (shunt mounted): 17 dB, typ. • Operating Temperature Range: -55°C to +125°C New Design • Lead-Free, RoHS Compliant Terminations ATC, the industry leader, is introducing the new 506WLS Series High Frequency Ultra-Broadband Inductor (UBL). This unique component provides low insertion loss and an excellent match over multiple octaves of frequency spectrum. Advantages: The 506WLS is ideal for ultra-broadband DC decoupling networks and bias tee applications in optical communications systems and equipment using highspeed digital logic. • Excellent Return Loss Through 40 GHz • Ultra-Broadband Performance • Ultra-Low Insertion Loss • Flat Frequency Response • Unit-to-Unit Performance Repeatability • Rugged Powdered Iron Core Electrical Specifications: *Inductance: measured at 1 MHz, 0.1 Vrms, 0 mA dc with HP4291A impedance analyzer • Inductance: 10.7 µH ±10%* • Rated DC Current (IDC max.): 150 mA** • DC Resistance (RDC typ.): 7.10 𝛀, typ. at +20°C, 10 mA current. **Current Rating: based on a 100 °C temperature rise from a 25°C ambient. ATC 506WLSN10R7 Insertion Loss (S21) ATC 506WLSN10R7 Return Loss (S11) 0 0 -0.2 -10 -0.6 Magnitude (dB) Magnitude (dB) -0.4 -0.8 -1 dB -1.2 -1.4 -1.6 -30 dB -40 -50 Typical -1.8 -2 -20 Typical 0 5 10 15 20 25 Frequency (GHz) 30 35 40 -60 0 5 10 15 20 25 30 35 Frequency (GHz) ATC # 001-1111 Rev. G; 8/17 40 AT C 5 0 6 W L S S E R I E S U B L S M T I N D U C T O R S Outline Dimensions Recommended Foot Print .032 (.813) .025 (.635) .197 (5.004) Note .025 (.635) .117 (2.972) .055±.005 (1.397 ±.127) .055 (1.397) .061 (1.549) .225 (5.715) .245 (6.223) .113 (2.870) .133 (3.378) Note: Terminal is configured to facilitate attachment close to inductor tip. inches (mm) Wire is copper plated with gold 20 µ in. ±5 µ in. Mechanical Configurations Size Length (L) Width (W) Height (H) N 0.245 (6.223) 0.133 (3.378) 0.117 (2.972) Cu Wire Size (AWG) Number of Turns 47 110 inches (mm) Unless noted otherwise, all dimensions are held to ±0.10 (.254) ATC PART NUMBER CODE ATC 506WLS N 10R7 K T 150 T Packaging T = Tape and Reel Series Case Size Inductance Code (µH) 3 significant digits for inductance R = Decimal point Current (mA) T = Tin Termination Inductance Tolerance, (±10%) The above part number refers to a 506WLS Series, Case Size N, 10. 7 µH inductor, K tolerance (±10%, typ.), with Tin Termination (T), 150 mA, tape and reel packaging.. ATC accepts orders for our parts using designations with or without the “ATC” prefix. Consult factory for additional performance data. Sales of ATC products are subject to the terms and conditions contained in American Technical Ceramics Corp. Terms and Conditions of Sale (ATC document #001-992). Copies of these terms and conditions will be provided upon request. They may also be viewed on ATC's website at www.atceramics.com/productfinder/default.asp. Click on the link for Terms and Conditions of Sale. ATC has made every effort to have this information as accurate as possible. However, no responsibility is assumed by ATC for its use, nor for any infringements of rights of third parties which may result from its use. ATC reserves the right to revise the content or modify its product line without prior notice. © 2010 American Technical Ceramics Corp. All Rights Reserved. ATC # 001-1111 Rev. G; 8/17
506WLSN10R7KT150T 价格&库存
很抱歉,暂时无法提供与“506WLSN10R7KT150T”相匹配的价格&库存,您可以联系我们找货
