Technical Data 4355
Effective June 2017
Supersedes March 2012
FP1308R
High frequency, high current power inductors
Applications
SMD Device
Environmental data
Product features
13.4 x 12.7 x 8.0mm surface mount package
Ferrite core material
High current carrying capacity, Low core losses
Controlled DCR tolerance for sensing circuits
Inductance range from 110nH to 440nH
Current range from 37 to 120 Amps
Frequency range up to 2MHz
Multi-phase regulators
Voltage Regulator Module (VRM)
Desktop and server VRMs and EVRDs
Data networking and storage systems
Graphics cards and battery power systems
Point-of-load modules
DCR sensing
Storage temperature range (component):
-40 °C to +125 °C
Operating temperature range: -40 °C to +125 °C
(ambient plus self-temperature rise)
Solder reflow temperature:
J-STD-020 (latest revision) compliant
Pb HF
FREE
HALOGEN
Technical Data 4355
Effective June 2017
Product Specifications
Part
Number
R1 Version
FP1308R1-R11-R
FP1308R1-R21-R
FP1308R1-R26-R
FP1308R1-R32-R
FP1308R1-R44-R
R2 Version
FP1308R2-R11-R
FP1308R2-R21-R
FP1308R2-R26-R
FP1308R2-R32-R
FP1308R2-R44-R
R3 Version
FP1308R3-R11-R
FP1308R3-R21-R
FP1308R3-R26-R
FP1308R3-R32-R
FP1308R3-R44-R
7
OCL1
FLL2
± 10% (nH)
(nH)
110
210
260
320
440
79
152
187
230
317
110
210
260
320
440
79
152
187
230
317
110
210
260
320
440
79
152
187
230
317
Irms3
(Amps)
Isat14
@ 25°C (Amps)
Isat25
@ 125°C (Amps)
57
120
80
64
52
37
105
68
52
40
28
45
120
80
64
52
37
105
68
52
40
28
68
120
80
64
52
37
105
68
52
40
28
1 Open Circuit Inductance (OCL) Test Parameters: 100kHz, 1.0Vrms, 0.0Adc
2 Full Load Inductance (FLL) Test Parameters: 100kHz, 1.0Vrms, Isat1.
3 Irms: DC current for an approximate temperature rise of 40°C without core loss. Derating is
DCR (mΩ)
@ 20°C
K-factor6
0.32 ± 9.4%
233
233
233
233
233
0.53 ± 10%
233
233
233
233
233
0.18 ± 20%
233
233
233
233
233
5 Isat2: Peak current for approximately 20% rolloff at +125°C.
6 K-factor: Used to determine Bp-p for core loss (see graph). Bp-p = K * L * ΔI * 10-3. Bp-p (Gauss),
K: (K-factor from table), L: (inductance in nH), ΔI (peak-to-peak ripple current in amps).
7 Part Number Definition: FP1308Rx-Rxx-R
necessary for AC currents. PCB pad layout, trace thickness and width, air-flow and proximity of other heat
generating components will affect the temperature rise. It is recommended the part temperature not exceed
125°C under worst case operating conditions verified in the end application.
• FP1308 = Product code and size
• Rx = DCR indicator
• Rxx = Inductance value in μH, R = decimal point.
• “-R” suffix = RoHS compliant
4 Isat: Peak current for approximately 20% rolloff at +25°C.
Dimensions- mm
T op V iew
S ide V iew
12.7 m ax
8.0
m ax
1
1308R x
R xx
w w llyy R
B ottom V iew
R ecom m ended P ad Layout
5.08
±0.15
b
S chem atic
7.62
1
1
3.18
2.54
±0.3
7.2
7.5
typ.
13.4
m ax
2
2
2
a
The nominal DCR is measured from point “a” to point “b”
All soldering surfaces to be coplanar within 0.1016mm.
Part Marking: FP1308R (Rx = DRC indicator)
Rxx = Inductance value in μH. (R = Decimal point).
wwllyy = Date code
R = Revision level
Packaging information - mm
4.0
1.5 dia
2.0
Section A-A
1.5 dia
min
A
1
13.9
11.5
24.0
±0.3
1308Rx
R xx
w w llyy R
2
13.2
8.2
Supplied in tape-and-reel packaging, 400 parts per reel, 13” diameter reel.
2
www.eaton.com/electronics
1.75
A
20.0
User direction of feed
FP1308R
Technical Data 4355
Effective June 2017
Temperature rise vs total loss
60
T e m p e ra tu re R is e (°C )
50
F P1 3 0 8 R 2
F P1 3 0 8 R 1
40
30
F P1 3 0 8 R 3
0.2
0.4
0.6
0.8
1.0
1.2
1.4
1.6
1.8
2.0
500kH z
300kH z
T o ta l L o s s (W )
Core loss vs Bp-p
1M H z
200kH z
10
C o re L o s s (W )
100kH z
1
0 .1
0 .0 1
100
1000
10000
B p -p (G a u s s )
Inductance characteristics
% o f O C L vs % o f I s a t 1
100%
80%
% o f O CL
-4 0 °C
60%
40%
+2 5 °C
20%
+1 2 5 °C
0%
0%
20%
40%
60%
80%
100%
120%
140%
% o f Is a t 1
3
FP1308R
Technical Data 4355
Effective June 2017
Solder Reflow Profile
TP
TC -5°C
Temperature
TL
25°C
Preheat
A
T smax
Table 1 - Standard SnPb Solder (Tc)
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
t
Volume
mm3
220°C
220°C
Table 2 - Lead (Pb) Free Solder (T c)
Tsmin
Package
Thickness
2.5mm
ts
Time 25°C to Peak
Volume
mm3
2000
260°C
245°C
245°C
Time
Reference JDEC J-STD-020
Profile Feature
Preheat and Soak
• Temperature min. (Tsmin)
• Temperature max. (Tsmax)
• Time (Tsmin to Tsmax) (ts)
Average ramp up rate Tsmax to Tp
Liquidous temperature (TL)
Time at liquidous (tL)
Peak package body temperature (TP)*
Time (tp)** within 5 °C of the specified classification temperature (Tc)
Average ramp-down rate (Tp to Tsmax)
Time 25°C to Peak Temperature
100°C
150°C
150°C
200°C
60-120 Seconds
60-120 Seconds
3°C/ Second Max.
3°C/ Second Max.
183°C
60-150 Seconds
217°C
60-150 Seconds
Table 1
Table 2
20 Seconds**
30 Seconds**
6°C/ Second Max.
6°C/ Second Max.
6 Minutes Max.
8 Minutes Max.
* Tolerance for peak profile temperature (Tp) is defined as a supplier minimum and a user maximum.
** Tolerance for time at peak profile temperature (tp) is defined as a supplier minimum and a user maximum.
Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written
approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly
used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user.
Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also
reserves the right to change or update, without notice, any technical information contained in this bulletin.
Eaton
Electronics Division
1000 Eaton Boulevard
Cleveland, OH 44122
United States
© 2017 Eaton
All Rights Reserved
Printed in USA
Publication No. 4355 BU-SB12178
June 2017
Eaton is a registered trademark.
All other trademarks are property
of their respective owners.
很抱歉,暂时无法提供与“FP1308R1-R11-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 400+9.60761400+1.24300
- 800+9.17090800+1.18650
- 1200+8.908871200+1.15260
- 2000+8.734192000+1.13000
- 国内价格 香港价格
- 1+17.036031+2.20407
- 10+13.9736010+1.80786
- 100+11.49046100+1.48660
- 国内价格 香港价格
- 400+10.31404400+1.33440
- 800+9.72624800+1.25835
- 1200+9.398421200+1.21594
- 2000+9.001502000+1.16459
- 2800+8.749522800+1.13199
- 4000+8.490384000+1.09846
- 国内价格
- 400+8.92361
- 800+8.55229
- 1200+8.27680
- 2000+8.15702
