SM1608A-100MHF
SM1608A-100MHF
    ITG
    SMD,4.4x4.2mm
    固定电感器 Nonstandard 10µH ±20% 1.6A 282mΩ
SM1608A-100MHF 数据手册
SM1608 Series 1. Features of SM1608 series: • 4.70 x 4.31mm foot Print , 2.00mm Max. height SMD Power Inductor for high frequency application. Operating frequency up to 5MHz. • Inductance range from 0.10uH to 22.0 uH. Custom values are welcomed. • High saturation current characteristics by distributed gapped metal dust core. • Ideal for portable device, Pad, E-reader and high density DC to DC Converter • Operating Temperature Range: -55˚C to 125˚C . • Tape & Reel Quantity: 2000 piece per 13 inches reel. RoHS and HF compliant. 2. Electrical Characteristics of SM1608 series: Inductance 1 DCR DCR (uH) (mΩ) (mΩ) ± 20% Typ. @25Ԩ Max. @25Ԩ SM1608-R10MHF 0.10 4.50 SM1608-R22MHF 0.22 7.30 ITG Part Number 5.00 Saturation Current 2 Isat (A) Typ. @25Ԩ 35.00 Heat Rating Current 3 Irms (A) Typ. @25Ԩ 11.00 8.00 24.00 13.00 SM1608-R33MHF 0.33 9.60 13.00 18.00 9.00 SM1608-R47MHF 0.47 16.00 18.00 11.50 5.60 SM1608-1R0MHF 1.00 33.00 37.00 8.50 3.75 SM1608-1R5MHF 1.50 35.00 43.00 6.00 4.00 SM1608-2R2MHF 2.20 52.00 58.00 5.00 3.00 SM1608-3R3MHF 3.30 76.00 87.00 4.00 2.50 SM1608-4R7MHF 4.70 118.00 132.00 2.80 2.40 SM1608-6R8MHF 6.80 162.00 178.00 2.10 2.00 SM1608-8R2MHF 8.20 188.00 207.00 2.00 1.80 SM1608-100MHF 10.00 256.00 282.00 1.80 1.60 SM1608-220MHF 22.00 460.00 550.00 1.00 0.80 3. Mechanical Dimensions of SM1608 series (unit: mm): E A F B xxx D H Top View Bottom View G C Part Marking: xxx: Inductance value in uH(R:decimal point). Pad Dimension SM1608 F 4.95 Typ. G 1.16 Typ. H 2.30 Typ. Recommend PCB Layout Front View Type A B C SM1608 4.45 ± 0.25 4.06 ± 0.25 2.00 Max. D E 2.00 ± 0.30 0.76 ± 0.30 Notes: 1. Test conditions: 100KHz, 0.25V, 25˚C ambient temperature . 2. Isat: DC current that causes inductance to drop 20% (Typ.) from OCL (Ta=25Ԩ). 3. Irms: DC current for an approximate temperature rise of 40Ԩ without core loss. Derating is necessary for AC currents. PCB pad layout,trace thickness and width,air-flow and proximity of other heat generating components will affect the temperature rise. It is recommended the part temperature not exceed 125°C under worst case operating conditions as verified in the end application. ● ● New York 1 914 347 2474 ● Taipei 886 2 2698 8669 ● Kaohsiung 886 7 350 2275 Japan 81 568 85 2830 ● Shenzhen 86 755 8418 6263 ● Shanghai 86 21 5424 5141 ● Hong Kong 852 9688 9767 ● sales@ITG-Electronics.com ● www.ITG-Electronics.com Revision D.0 : June 22, 2018 *Due to continuous product improvement, all specifications are subject to change without prior notice. Kindly contact an ITG field application engineer or a sales representative prior to purchase. SM1608 Series 4. Inductance vs. Temperature Rise Characteristics of SM1608 Series 100 0.08 80 0.20 80 0.06 60 0.15 60 0.04 40 0.10 40 0.02 INDUCTANCE uH 0.25 20 0.05 20 INDUCTANCE uH TEMP.Rise(℃) INDUCTANCE uH TEMP.Rise(℃) 0.00 0 5 10 15 20 25 30 0.00 0 35 0 5 10 DC CURRENT (A) 20 25 SM1608-R47MHF SM1608-R33MHF 100 0.75 100 0.4 80 0.60 80 0.3 60 0.45 60 0.2 40 0.30 40 0.1 INDUCTANCE uH 0.5 TEMP.Rise(℃) INDUCTANCE uH 15 DC CURRENT (A) 20 0.15 INDUCTANCE uH TEMP.Rise(℃) TEMP.Rise(℃) 0 0 2 4 6 8 10 12 14 20 INDUCTANCE uH 0.0 16 18 TEMP.Rise(℃) 0 TEMP.Rise(℃) SM1608-R22MHF 100 TEMP.Rise(℃) INDUCTANCE uH SM1608-R10MHF 0.10 0.00 0 20 0 2 4 6 DC CURRENT (A) 8 10 12 14 DC CURRENT (A) SM1608-1R5MHF SM1608-1R0MHF 1.8 100 1.2 100 1.6 1.0 80 60 TEMP.Rise(℃) 60 0.6 40 1.0 0.8 40 0.6 0.4 0.4 20 0.2 INDUCTANCE uH TEMP.Rise(℃) 0.0 0 0 1 2 3 4 5 6 7 8 9 20 INDUCTANCE uH TEMP.Rise(℃) 0.2 0.0 0.0 0 10 1 2 3 4 5 6 7 DC CURRENT (A) DC CURRENT (A) SM1608-3R3MHF SM1608-2R2MHF 3.0 100 2.5 100 4.2 3.6 80 80 40 1.0 60 2.4 1.8 40 1.2 20 INDUCTANCE (uH) 0.5 INDUCTANCE(uH) 60 1.5 20 0.6 TEMP.Rise(℃) TEMP. Rise(˚C) 3.0 2.0 TEMP.Rise(℃) INDUCTANCE (uH) TEMP. Rise(˚C) 1.2 0.8 INDUCTANCE uH 80 1.4 INDUCTANCE uH TEMP.Rise(℃) 0.0 0 0 1 2 3 DC CURRENT (A) ● 4 5 6 0.0 0.0 0 1 2 3 4 5 6 DC CURRENT (A) ● New York 1 914 347 2474 ● Taipei 886 2 2698 8669 ● Kaohsiung 886 7 350 2275 Japan 81 568 85 2830 ● Shenzhen 86 755 8418 6263 ● Shanghai 86 21 5424 5141 ● Hong Kong 852 9688 9767 ● sales@ITG-Electronics.com ● www.ITG-Electronics.com Revision D.0 : June 22, 2018 *Due to continuous product improvement, all specifications are subject to change without prior notice. Kindly contact an ITG field application engineer or a sales representative prior to purchase. SM1608 Series 4. Inductance vs. Temperature Rise Characteristics of SM1608 Series SM1608-4R7MHF SM1608-6R8MHF 5.0 100 8.0 80 7.0 80 60 60 2.0 40 INDUCTANCE uH 3.0 TEMP.Rise(℃) INDUCTANCE uH 6.0 5.0 40 4.0 3.0 20 2.0 1.0 TEMP.Rise(℃) 4.0 20 INDUCTANCE uH 1.0 INDUCTANCE uH TEMP.Rise(℃) TEMP.Rise(℃) 0.0 0 0.0 0.8 1.6 2.4 3.2 4.0 0.0 4.8 0 0.0 0.4 0.8 DC CURRENT (A) 1.2 1.6 2.0 2.4 DC CURRENT (A) SM1608-8R2MHF SM1608-100MHF 10.0 100 8.0 80 6.0 60 100 12 10 80 60 6 40 TEMP.Rise(℃) 40 INDUCTANCE uH 4.0 TEMP.Rise(℃) INDUCTANCE uH 8 4 2.0 20 20 2 INDUCTANCE uH INDUCTANCE uH TEMP.Rise(℃) TEMP.Rise(℃) 0.0 0 0.0 0.4 0.8 1.2 1.6 2.0 2.4 0 0 0.0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 DC CURRENT (A) DC CURRENT (A) INDUCTANCE uH SM1608-220MHF 25 100 20 80 15 60 10 40 5 20 INDUCTANCE uH TEMP.Rise(℃) 0 0 0.0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 1.1 1.2 DC CURRENT(A) ● ● New York 1 914 347 2474 ● Taipei 886 2 2698 8669 ● Kaohsiung 886 7 350 2275 Japan 81 568 85 2830 ● Shenzhen 86 755 8418 6263 ● Shanghai 86 21 5424 5141 ● Hong Kong 852 9688 9767 ● sales@ITG-Electronics.com ● www.ITG-Electronics.com Revision D.0 : June 22, 2018 *Due to continuous product improvement, all specifications are subject to change without prior notice. Kindly contact an ITG field application engineer or a sales representative prior to purchase.
SM1608A-100MHF 价格&库存
很抱歉,暂时无法提供与“SM1608A-100MHF”相匹配的价格&库存,您可以联系我们找货
