PL8405T
PL8405T
    INRCORE
    SMD-4P,32.5x27.2mm
    固定电感器 Nonstandard 4µH 22.4A 3.4mΩ
PL8405T 数据手册
SMT POWER INDUCTORS Toroid - POGO Series Ruggedized Ruggedized header with POGO pins for secure board mounting Current Rating:up to 23.8ADC Frequency Range:up to 1MHz Moisture Sensitivity Level: 3 Part 4,5 Number POGO 40 PL8400 POGO 50 PL8401 PL8402 PL8403 PL8404 POGO 60 PL8405 Electrical Specifications @ 25 °C — Operating Temperature - 55 °C to +130 °C Inductance DCR (mŸ ) Flux Density Factor Core Loss Factor Temp. Rise Reference ET Irated @ 0ADC Factor (A) (Volt-µsec) (K3) TYP MAX (µH) (K1) (K2) Inductance @ Irated (µH) Connection 43.6 1.1 247.2 309 77 7.83 0.295 1.87E-10 114.23 Single 21.9 4.025 0.53 1.1 2.7 6.4 23.8 21 72.4 18.4 1.0 1.7 90.5 23 3 2.5 39.5 6.575 0.88 2.1 6.9 3.135 1 1.75 0.297 0.638 2.020 1.116 3.35E-10 4.52E-10 3.35E-10 4.52E-10 85.71 67.89 85.71 67.89 Single Single Parallel Parallel 2.1 22.4 2.5 3.4 4 3.25 0.559 9.58E-10 44.56 Parallel NOTES: 1.Reference values are for an inductor with a 55°C temperature rise. The core loss is 10% of the copper loss at the ET listed and 500kHz. 2. Core does not saturate abruptly. The ET and DC current are limited by the desired inductance and temperature rise. 3. In high volt-time applications, additional heating in the component can occur due to core losses in the inductor which may necessitate derat-ing the current in order to limit the temperature rise of the component. In order to determine the approximate total losses (or temperature rise) for a given application, both copper and core losses should be taken into account. Estimated Temperature Rise: Trise = K3 * (Coreloss(W) + Copperloss(W).833 (C) CopperLoss = Irms2 * DCR_Typical (mŸ) / 1000 CoreLoss = K2 * (Freq_kHz)1.26 * (¨B)2.11 ¨B = K1 * Volt-µsec * 100 4. Optional Tape & Reel packaging can be ordered by adding a "T" suffix to the part number (i.e. PL8400 becomes PL8400T ). Electrical Schematics Mechanicals D 3 2 1 H C 2 T 4 1 PKG A B C D E F G H J T POGO 50 .725 18,42 .910 23,11 .575 14,61 .700 17,78 .600 15,24 .730 18,54 .450 11,43 .520 13,21 .310 7,87 .400 10,16 .380 9,65 .510 12,95 .450 11,43 .520 13,21 .600 15,24 .730 18,54 .082 2,08 .145 3,68 .062 1,57 .125 3,18 POGO 60 1.280 32,51 1.070 27,18 1.100 27,94 .890 22,61 .400 10,16 .510 12,95 .890 22,61 1.100 27,94 .145 3,68 .125 3,18 POGO 40 1 www.inrcore.com Weight (MAX) Tube Reel 3.5 grams 30 300 8.2 grams 35 200 14.2 grams 15 100 M111.D(07/20) SMT POWER INDUCTORS Toroid - POGO Series Ruggedized For More Information Global Sales Representatives and Lo cations: http://www.inrcore.com iNRCORE,LLC 311 Sinclair Road Bristol, PA 19007-6812 U.S.A Tel: + 1.215.781.6400 Fax: +1.215.7816430 Performance warranty of products offered on this data sheet is limited to the parameters specified. Data is subject to change without notice. Other brand and product names mentioned herein may be trademarks or registered trademarks of their respective owners. © Copyright, 2020. iNRCORE, LLC. All rights reserved. 2 www.inrcore.com M111.D(07/20)
PL8405T 价格&库存
很抱歉,暂时无法提供与“PL8405T”相匹配的价格&库存,您可以联系我们找货
