L201204-452MHF
L201204-452MHF
    ITG
    插件-4,53.5x26.5mm
    固定电感器 Radial, Vertical 4.5mH ±20% 2.5A 640mΩ
L201204-452MHF 数据手册
L201204 Series 1. Features of L201204 Series: • Alloy Powder based DIP Inductor with lower core loss. • Inductance Range:0.106mH to 33.75mH. Custom values are welcomed. • Lower core loss, lower distributed capacitance. • Coil mount on UL94-V0 rated plastic header. • Fixed pin spacing allow easy PCB insertion. • Operating temperature range of -55°C to + 130°C. • Storage conditions: -40Ԩ~85Ԩ , 75% RH (Max). RoHS & HF compliant. 2. Electrical Characteristics of L201204 Series: L201204-101MHF OCL 1 (mH) ± 20% 0.106 DCR (mΩ) Typ. 10.15 DCR 2 (mΩ) Max. 12.50 Isat 3 (A) @25℃ 16.00 L201204-161MHF 0.165 19.32 23.50 L201204-102MHF 1.000 72.90 88.00 L201204-162MHF 1.634 154.30 ITG Part Number L@Isat (mH) Typ. 0.0726 Irms 4 (A) @25℃ 24.00 13.00 0.1130 17.00 0.0959 2 5.40 0.6913 8.20 0.5010 3 186.00 4.20 1.1289 5.60 0.9210 2 L@Irms (mH) Typ. 0.0558 Dimension 1 L201204-452MHF 4.500 530.00 640.00 2.50 3.0335 2.50 3.3650 2 L201204-333MHF 33.750 2900.00 3480.00 0.95 23.3250 1.30 18.4541 3 3. Mechanical Dimension of L201204 Series: Dim. 1 2 3 A Max. 54.50 53.50 54.00 B Max. 25.50 26.50 28.20 C E E1 E2 F ± 1.00 ± 0.80 ± 0.40 ± 0.40 ± 0.10 5.00 21.50 Φ2.00 5.00 17.78 30.48 Φ1.27 5.00 22.86 38.10 Φ1.27 G Max. 52.50 55.00 55.70 Fig 2 and Fig 3 Fig 1 A A B B 2 Glue G G L201204 xxxx ITG YYWW F 1 4 Side View 1 2 Front View E2 2 2 4 2 E1 4 Bottom View 3 Side View E Bottom View 4 F C 2 2 Front View C SCHEMATIC DIAGRAM Part Marking: L201204: Series Name. xxx x: xxx is inductance value in uH (R:decimal point). x is tolerance . ITGYYWW: ITG is Company Name , YYWW is Date Code. 3 Notes: 1. Open Circuit Inductance (OCL) test condition: 10KHz,0.25Vrms,0Adc. 2. The nominal DCR is measured from PIN2 to PIN4 , as shown above on the mechanical drawing (Ta=25Ԩ). 3. Isat: DC current that will cause inductance to drop approximately by 35% (Ta=25Ԩ). 4. Irms: DC current for temperature rise of 40Ԩ(Typ.) without core loss. ● ● New York 1 914 347 2474 ● Taipei 886 2 2698 8669 ● Kaohsiung 886 7 350 2275 Japan 81 568 85 2830 ● Shenzhen 86 755 8418 6263 ● Shanghai 86 21 5424 5141 ● Hong Kong 852 9688 9767 ● sales@ITG-Electronics.com ● www.ITG-Electronics.com Revision A: October 28, 2016 *Due to continuous product improvement, all specifications are subject to change without prior notice. Kindly contact an ITG field application engineer or a sales representative prior to purchase.
L201204-452MHF 价格&库存
很抱歉,暂时无法提供与“L201204-452MHF”相匹配的价格&库存,您可以联系我们找货
