■ Application
Laptop, desktop and server applications
High current power supplies
Battery powered devices
PMIC
■ Features
RoHS compliant & halogen free
Low resistance and high current rating
Magnetic core made by high performance magnetic metal powder
■ Product Identification
①
MND
②
③ ④
⑤
- 07CZ I R22 M - XB
① Product Code
② Dimensions
③ Inductance: R22 = 0.22 μH
④ Inductance Tolerance: M = ±20%
⑤ Series Type: XB Type
Note: Please refer to the “Product Dimension” for detail dimensions.
M AG .LAYER S
MND-07CZISERIES-XB
■ Electrical Performance
Inductance
Heat rating
Saturation
Rdc(mΩ)
Part number
current (Idc)1 current (Isat)2
±20%@0A
(μH)
Typ. Max. DC amps (A)
DC amps (A)
MND-07CZIR22M-XB
0.22
1.4
1.7
29.5
50
MND-07CZIR30M-XB
0.3
1.75
1.92
27.6
41
MND-07CZIR36M-XB
0.36
2.4
2.7
24
39
MND-07CZIR60M-XB
0.6
3
3.3
23
36
MND-07CZI1R0M-XB
1
4.55
5
21.8
28
MND-07CZI1R5M-XB
1.5
7.6
8.36
15
23.5
MND-07CZI2R7M-XB
2.7
15.7
17.3
11.4
12.8
MND-07CZI3R3M-XB
33
3.3
19 5
19.5
21 45
21.45
10
12 3
12.3
MND-07CZI4R7M-XB
4.7
25.2
27.72
9
12
MND-07CZI6R8M-XB
6.8
38.7
42.57
6.8
10.7
MND-07CZI8R2M-XB
8.2
44.3
48.73
5.9
10.2
MND-07CZI100M-XB
10
57
62.7
5.3
7
M AG .LAYER S
MND-07CZISERIES-XB
■ Note
Test frequency: 100KHz, 0.25V.
Test instruments:
Inductance/saturation current: Keysight 4285A or equivalent.
Rdc: ADEX AX1152D or equivalent.
Notes:
The heat rating current (Idc) will cause temperature rise approximate 40°C.
The saturation current (Isat) will cause initial inductance drop approximate 30%.
All test data is referenced at 25°C ambient.
Operating temperature range -55°C to +125°C.
The part temperature (ambient + temp rise) should not exceed 125°C under the
worst condition.
6. The temperature of component is affected by application conditions, e.g. circuit
design, copper thickness of PCB and cooling conditions, the actual component
temperature should be tested in the end application.
1.
2.
3.
4.
5.
M AG .LAYER S
MND-07CZISERIES-XB
■ Electrical Characteristics
M AG .LAYER S
MND-07CZISERIES-XB
M AG .LAYER S
MND-07CZISERIES-XB
■ Product Dimension
Code: XXX = R22 = 0.22 μH
Dimension
Part number
MND-07CZISERIES-XB
A
B
C
D
E
7.2 ± 0.5
7.5 ± 0.5
3.0 Max
5.0 ± 0.3
1.5 ± 0.3
Unit: mm
M AG .LAYER S
MND-07CZISERIES-XB
■ Recommended PCB Layout
Type
A
B
C
07CZ
6.9
3.7
7.3
Unit: mm
Safety precaution
1. Do not make any through holes and copper pattern in the dotted line area. Except a
copper pattern to the electrode.
2. Don’t design/mount any components in contact with this product.
This power choke coil itself does not have any protective function in abnormal
condition such as overload, short circuit, open conditions and etc, it shall be confirmed
as the end product that there is no risk of smoking, fire, dielectric withstand voltage,
insulation resistance and etc. in abnormal conditions to provide protective devices
and/or protection circuit in the end product.
M AG .LAYER S
MND-07CZISERIES-XB
■ Packaging
Peel-off force
TOP COVER TAPE
165° TO 180°
BASE TAPE
The peel off force of cover tape is 10 to 70 grams in the arrow direction.
Dimensions
F
A
B
C
D
Type
A
B
C
D
E
F
330mm
330±2
100±1
20±0.5
13±1.0
16.4
+2.0/-0
21.4±2
Unit: mm
E
TYPE
MND
SIZE
07CZ
A
B
W
P1
K
8.2±0.1
7.9±0.1
16.0±0.3
12±0.1
3.4±0.1
P0
P2
D
E
T
4.0±0.1
2.0±0.1
1.5+0.1
1.75±0.1
0.35±0.05
Unit: mm
M AG .LAY ER S
MND-07CZISERIES-XB
Taping quantity
Series
07CZ
PCS/Reel
1000
Carton box
Middle packaging: 2 reels/box
External packaging: 5 boxes/carton
M AG .LAY ER S
MND-07CZISERIES-XB
MND-07CZIR22M-XB-RU 价格&库存
很抱歉,暂时无法提供与“MND-07CZIR22M-XB-RU”相匹配的价格&库存,您可以联系我们找货
