ASCH001005055N6SCP
ASCH001005055N6SCP
    CHILISIN(奇力新)
    固定电感器 0402 5.6nH ±0.3nH 400mA 200mΩ 5.1GHz 8@100MHz
ASCH001005055N6SCP 数据手册
Automotive Chip Inductor ASCH Series AEC-Q200 RoHS Compliant Halogen Free REACH Compliant ■ Part Numbering A Grade SCH Series Name 00 Control Code 100505 1N0 Dimensions Code (mm) 100505 1.0x0.5x0.5 160808 1.6x0.8x0.8 Inductance (nH) 1N0 1.0 10N 10 R10 100 S CP Tolerance Internal Code S J ±0.3nH ±5% 00 CP General Low RDC This specification applies to Wire Wound Chip Inductors for Automotive Electronics based on AEC-Q200 except for Power train and Safety. Automotive Chip Inductor ASCH Series AEC-Q200 ASCH00100505_CP Type ■ Dimensions ■ Recommended Land Pattern unit:mm unit:mm ■ Electrical Characteristics Part No. ASCH001005051N0□CP ASCH001005051N1□CP ASCH001005051N2□CP ASCH001005051N3□CP ASCH001005051N5□CP ASCH001005051N6□CP ASCH001005051N8□CP ASCH001005052N0□CP ASCH001005052N2□CP ASCH001005052N4□CP ASCH001005052N7□CP ASCH001005053N0□CP ASCH001005053N3□CP ASCH001005053N6□CP ASCH001005053N9□CP ASCH001005054N3□CP ASCH001005054N7□CP ASCH001005055N1□CP ASCH001005055N6□CP ASCH001005056N2□CP ASCH001005056N8□CP ASCH001005057N5□CP ASCH001005058N2□CP ASCH001005059N1□CP ASCH0010050510N□CP ASCH0010050512N□CP ASCH0010050515N□CP ASCH0010050518N□CP ASCH0010050522N□CP ASCH0010050527N□CP L,Q Q SRF RDC Rated Current (nH) Test Freq. Min. (MHz)Min. (Ω)Max. (mA)Max. (±%) 1.0 1.1 1.2 1.3 1.5 1.6 1.8 2.0 2.2 2.4 2.7 3.0 3.3 3.6 3.9 4.3 4.7 5.1 5.6 6.2 6.8 7.5 8.2 9.1 10 12 15 18 22 27 100 MHz,200 mV 100 MHz,200 mV 100 MHz,200 mV 100 MHz,200 mV 100 MHz,200 mV 100 MHz,200 mV 100 MHz,200 mV 100 MHz,200 mV 100 MHz,200 mV 100 MHz,200 mV 100 MHz,200 mV 100 MHz,200 mV 100 MHz,200 mV 100 MHz,200 mV 100 MHz,200 mV 100 MHz,200 mV 100 MHz,200 mV 100 MHz,200 mV 100 MHz,200 mV 100 MHz,200 mV 100 MHz,200 mV 100 MHz,200 mV 100 MHz,200 mV 100 MHz,200 mV 100 MHz,200 mV 100 MHz,200 mV 100 MHz,200 mV 100 MHz,200 mV 100 MHz,200 mV 100 MHz,200 mV 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 10000 10000 10000 9000 9000 8700 8700 8100 8100 7700 7700 6300 6300 6100 6100 6000 6000 5300 5100 4500 4550 4200 4100 3900 3900 3000 2500 2200 1900 1700 0.07 0.10 0.09 0.10 0.10 0.10 0.10 0.10 0.12 0.15 0.15 0.15 0.15 0.15 0.18 0.18 0.18 0.20 0.20 0.22 0.24 0.24 0.24 0.26 0.26 0.28 0.32 0.36 0.42 0.46 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 300 300 300 300 300 300 300 300 300 ±0.3nH ±0.3nH ±0.3nH ±0.3nH ±0.3nH ±0.3nH ±0.3nH ±0.3nH ±0.3nH ±0.3nH ±0.3nH ±0.3nH ±0.3nH ±0.3nH ±0.3nH ±0.3nH ±0.3nH ±0.3nH ±0.3nH ±0.3nH 5 5 5 5 5 5 5 5 5 5 Inductance Note: When ordering, please specify tolerance code. Tolerance: C=±0.2nH / S=±0.3nH / J=±5% / K=±10% 1. Operating temperature range -55℃~125℃ 2. Applied the current to coils, the temperature rise shall not be more than 30℃ 3. Residual impedance of short chip : 0nH 4. Measure Equipment: L & Q: Agilent E4991A+Agilent 16197A SRF: Agilent E4991A or HP19196C RDC: HP4338B or CHEN HWA 502 Tolerance Automotive Chip Inductor ASCH Series AEC-Q200 ASCH00100505_CP Type ■ Dimensions ■ Recommended Land Pattern unit:mm unit:mm ■ Electrical Characteristics Part No. ASCH0010050533N□CP ASCH0010050539N□CP ASCH0010050547N□CP ASCH0010050556N□CP ASCH0010050568N□CP ASCH0010050582N□CP ASCH00100505R10□CP ASCH00100505R12□CP ASCH00100505R15□CP ASCH00100505R18□CP ASCH00100505R22□CP ASCH00100505R27□CP L,Q Q SRF RDC Rated Current Tolerance (nH) Test Freq. Min. (MHz)Min. (Ω)Max. (mA)Max. (±%) 33 39 47 56 68 82 100 120 150 180 220 270 100 MHz,200 mV 100 MHz,200 mV 100 MHz,200 mV 100 MHz,200 mV 100 MHz,200 mV 100 MHz,200 mV 100 MHz,200 mV 100 MHz,200 mV 100 MHz,200 mV 100 MHz,200 mV 100 MHz,200 mV 100 MHz,200 mV 8 8 8 8 8 8 8 8 8 8 8 8 1600 1200 1000 800 800 700 900 800 700 600 500 500 0.58 0.65 0.72 0.82 0.92 1.20 2.00 2.20 3.50 3.80 4.20 4.80 200 200 200 200 180 150 100 100 100 100 100 100 5 5 5 5 5 5 5 5 5 5 5 5 Inductance Note: When ordering, please specify tolerance code. Tolerance: C=±0.2nH / S=±0.3nH / J=±5% / K=±10% 1. Operating temperature range -55℃~125℃ 2. Applied the current to coils, the temperature rise shall not be more than 30℃ 3. Residual impedance of short chip : 0nH 4. Measure Equipment: L & Q: Agilent E4991A+Agilent 16197A SRF: Agilent E4991A or HP19196C RDC: HP4338B or CHEN HWA 502 Automotive Chip Inductor ASCH Series AEC-Q200 ASCH00100505_CP Type ■ Characteristics Graph ASCH001005051N1SCP 2.1 1.2 30 0.9 0.3 1 10 100 1000 0.0 0 10000 1 FREQUENCY(MHz) RDC
ASCH001005055N6SCP 价格&库存
很抱歉,暂时无法提供与“ASCH001005055N6SCP”相匹配的价格&库存,您可以联系我们找货
