SMHC2511-1R0MHF
SMHC2511-1R0MHF
    ITG
    SMD,7.1x6.6mm
    固定电感器 Nonstandard 1µH ±20% 11A 10mΩ
SMHC2511-1R0MHF 数据手册
SMHC2511 Series 1. Features of SMHC2511 series: • 7.40 x 6.80mm foot Print , 3.00mm Max. height SMD Power Inductor for high frequency application. Operating frequency up to 5MHz. • Inductance range from 0.10uH to 10.0uH. Custom values are welcomed. • High saturation current characteristics by distributed gapped metal dust core. • Ideal for portable device, Pad, E-reader and high density DC to DC Converter. • Lower DC resistance for higher current application. • Tape & Reel Quantity: 1000 piece per 13 inches reel. RoHS and HF compliant. 2. Electrical Characteristics of SMHC2511 series: 3. Mechanical Dimensions (unit: mm): OCL DCR DCR Isat 1 Irms 2 (uH) (mΩ) (mΩ) (A) (A) ±20% Typ. @25Ԩ Max. @25Ԩ @25Ԩ @25Ԩ SMHC2511-R10MHF 0.10 1.50 1.70 60.00 32.50 SMHC2511-R15MHF 0.15 1.90 2.40 52.00 26.00 ITG Part Number A± 0.20 B± 0.30 C Max. D± 0.30 E± 0.50 6.60 7.10 3.00 3.00 1.60 E B xxx YWW A D SMHC2511-R20MHF 0.20 2.40 2.70 41.00 24.00 SMHC2511-R22MHF 0.22 2.50 2.80 40.00 23.00 SMHC2511-R33MHF 0.33 3.50 3.90 30.00 20.00 SMHC2511-R47MHF 0.47 4.00 4.20 26.00 17.50 SMHC2511-R68MHF 0.68 5.00 5.50 25.00 15.50 SMHC2511-R82MHF 0.82 6.70 8.00 24.00 13.00 SMHC2511-1R0MHF 1.0 9.00 10.00 22.0 11.00 SMHC2511-1R5MHF 1.5 14.00 15.00 18.0 9.00 G 3.70 Typ. H 3.50 Typ. SMHC2511-2R2MHF 2.2 18.00 20.00 14.00 8.00 SMHC2511-3R3MHF 3.3 28.00 30.00 13.50 6.00 SMHC2511-4R7MHF 4.7 37.00 40.00 10.00 5.50 SMHC2511-6R8MHF 6.8 54.00 60.00 8.00 4.50 SMHC2511-8R2MHF 8.2 64.00 68.00 7.50 4.00 SMHC2511-100MHF 10.0 102.00 105.00 7.00 3.00 Part Marking: xxx : inductance value in uH. YWW: Y is Year Code , WW is week. C Pad Dimension SMHC2511 F 7.40 Typ. F H G Recommend PCB Layout Notes: 1. Isat: DC current that causes inductance to drop 30%(Typ.) from OCL (Ta=25Ԩ). 2. Irms: DC current for an approximate temperature rise of 40Ԩ without core loss. Derating is necessary for AC currents. PCB pad layout,trace thickness and width,air-flow and proximity of other heat generating components will affect the temperature rise. It is recommended the part temperature not exceed 125°C under worst case operating conditions as verified in the end application. 3. Test conditions: 100KHz, 1.0V, 25˚C ambient temperature . 4. Operating Temperature Range: -55˚C to 125˚C . ● ● New York 1 914 347 2474 ● Taipei 886 2 2698 8669 ● Kaohsiung 886 7 350 2275 Japan 81 568 85 2830 ● Shenzhen 86 755 8418 6263 ● Shanghai 86 21 5424 5141 ● Hong Kong 852 9688 9767 ● sales@ITG-Electronics.com ● www.ITG-Electronics.com Revision E.1: May 17 , 2017 *Due to continuous product improvement, all specifications are subject to change without prior notice. Kindly contact an ITG field application engineer or a sales representative prior to purchase. SMHC2511 Series 4. Inductance vs. Current vs. Temperature Rise Characteristics of SMHC2511 Series : 0.080 80 0.120 TEMP RISE(Ԩ) 0.060 60 INDUCTANCE(μH) 0.040 40 0.020 20 0.000 0 SMHC2511‐R15MHF 80 TEMP RISE(Ԩ) 0.090 40 0.030 20 0.000 0 0 10 20 30 40 50 60 70 DC  BIAS(Amps) DC  BIAS(Amps) SMHC2511‐R20MHF SMHC2511‐R22MHF 80 0.176 TEMP RISE(Ԩ) 60 INDUCTANCE(μH) 0.080 40 0.040 20 0.000 0 20 30 40 50 60 80 TEMP RISE(Ԩ) 0.132 60 INDUCTANCE(μH) 0.088 40 0.044 20 0.000 0 70 0 DC  BIAS(Amps) 0.376 60 0.132 40 0.066 20 0.000 0 5 10 15 20 25 30 35 40 45 DC  BIAS(Amps) 40 50 60 70 100 80 INDUCTANCE(μH) 80 INDUCTANCE(μH) 0 ● 0.470 TEMP RISE(Ԩ) 0.198 30 SMHC2511‐R47MHF 100 TEMP RISE(Ԩ) INDUCTANCE(μH) 0.264 20 DC  BIAS(Amps) SMHC2511‐R33MHF 0.330 10 TEMP RISE(Ԩ) 0.282 60 INDUCTANCE(μH) 0.188 40 0.094 20 0.000 0 0 TEMP RISE(Ԩ) 0.120 100 TEMP RISE(Ԩ) 0.220 INDUCTANCE(μH) INDUCTANCE(μH) 0.160 100 TEMP RISE(Ԩ) 0.200 10 60 INDUCTANCE(μH) 0.060 0 10 20 30 40 50 60 70 80 90 0 100 TEMP RISE(Ԩ) 0.150 INDUCTANCE(μH) 100 TEMP RISE(Ԩ) INDUCTANCE(μH) SMHC2511‐R10MHF 0.100 5 10 15 20 25 30 35 40 45 DC  BIAS(Amps) ● New York 1 914 347 2474 ● Taipei 886 2 2698 8669 ● Kaohsiung 886 7 350 2275 Japan 81 568 85 2830 ● Shenzhen 86 755 8418 6263 ● Shanghai 86 21 5424 5141 ● Hong Kong 852 9688 9767 ● sales@ITG-Electronics.com ● www.ITG-Electronics.com Revision E.1: May 17 , 2017 *Due to continuous product improvement, all specifications are subject to change without prior notice. Kindly contact an ITG field application engineer or a sales representative prior to purchase. SMHC2511 Series 4. Inductance vs. Current vs. Temperature Rise Characteristics of SMHC2511 Series : SMHC2511‐R82MHF SMHC2511‐R68MHF 80 0.656 TEMP RISE(Ԩ) 60 INDUCTANCE(μH) 0.272 40 0.136 20 0.000 0 0.492 60 INDUCTANCE(μH) 0.328 40 0.164 20 0.000 0 5 10 15 20 25 30 35 40 0 5 10 DC  BIAS(Amps) 80 1.20 60 INDUCTANCE(μH) 0.40 40 0.20 20 0.00 0 0.30 20 0.00 0 0 80 2.64 60 0.88 40 0.44 20 0.00 0 INDUCTANCE(μH) 3.30 TEMP RISE(Ԩ) INDUCTANCE(μH) ● 6 9 12 15 18 21 24 27 SMHC2511‐3R3MHF 100 INDUCTANCE(μH) DC  BIAS(Amps) 3 DC  BIAS(Amps) TEMP RISE(Ԩ) 0 2 4 6 8 10 12 14 16 18 20 60 INDUCTANCE(μH) 40 SMHC2511‐2R2MHF 1.32 80 TEMP RISE(Ԩ) 0.60 DC  BIAS(Amps) 1.76 35 0.90 0 3 6 9 12 15 18 21 24 27 30 2.20 30 100 INDUCTANCE(μH) 1.50 TEMP RISE(Ԩ) 0.60 25 SMHC2511‐1R5MHF 100 TEMP RISE(Ԩ) INDUCTANCE(μH) 0.80 20 DC  BIAS(Amps) SMHC2511‐1R0MHF 1.00 15 TEMP RISE(Ԩ) 0 80 TEMP RISE(Ԩ) 100 80 TEMP RISE(Ԩ) 1.98 60 INDUCTANCE(μH) 1.32 40 0.66 20 0.00 0 TEMP RISE(Ԩ) 0.408 100 TEMP RISE(Ԩ) 0.820 INDUCTANCE(μH) 0.544 100 TEMP RISE(Ԩ) INDUCTANCE(μH) 0.680 0 2 4 6 8 10 12 14 16 18 20 DC  BIAS(Amps) ● New York 1 914 347 2474 ● Taipei 886 2 2698 8669 ● Kaohsiung 886 7 350 2275 Japan 81 568 85 2830 ● Shenzhen 86 755 8418 6263 ● Shanghai 86 21 5424 5141 ● Hong Kong 852 9688 9767 ● sales@ITG-Electronics.com ● www.ITG-Electronics.com Revision E.1: May 17 , 2017 *Due to continuous product improvement, all specifications are subject to change without prior notice. Kindly contact an ITG field application engineer or a sales representative prior to purchase. SMHC2511 Series 4. Inductance vs. Current vs. Temperature Rise Characteristics of SMHC2511 Series : SMHC2511‐4R7MHF SMHC2511‐6R8MHF 80 5.44 TEMP RISE(Ԩ) 2.82 60 INDUCTANCE(μH) 1.88 40 0.94 20 0.00 0 2 4 6 8 4.08 2.72 40 1.36 20 0.00 0 10 12 14 16 0 2 4 6 8 10 12 14 DC  BIAS(Amps) SMHC2511‐8R2MHF SMHC2511‐100MHF 100 10.00 100 6.56 80 8.00 80 4.92 TEMP RISE(Ԩ) 60 3.28 INDUCTANCE(μH) 40 1.64 20 0.00 0 0.0 1.0 2.0 3.0 4.0 5.0 6.0 7.0 8.0 9.0 DC BIAS(Amps) INDUCTANCE(μH) 8.20 TEMP RISE(Ԩ) INDUCTANCE(μH) 60 INDUCTANCE(μH) DC  BIAS(Amps) ● 80 TEMP RISE(Ԩ) 6.00 TEMP RISE(Ԩ) 60 4.00 INDUCTANCE(μH) 40 2.00 20 0.00 0 TEMP RISE(Ԩ) 0 100 TEMP RISE(Ԩ) 6.80 INDUCTANCE(μH) INDUCTANCE(μH) 3.76 100 TEMP RISE(Ԩ) 4.70 0.0 1.0 2.0 3.0 4.0 5.0 6.0 7.0 8.0 DC BIAS(Amps) ● New York 1 914 347 2474 ● Taipei 886 2 2698 8669 ● Kaohsiung 886 7 350 2275 Japan 81 568 85 2830 ● Shenzhen 86 755 8418 6263 ● Shanghai 86 21 5424 5141 ● Hong Kong 852 9688 9767 ● sales@ITG-Electronics.com ● www.ITG-Electronics.com Revision E.1: May 17 , 2017 *Due to continuous product improvement, all specifications are subject to change without prior notice. Kindly contact an ITG field application engineer or a sales representative prior to purchase. SMHC2511 Series 5.PACKAGE SPECIFICATION.(UNIT:mm): (1).ENCAPSOLATION MODE: P0 P2 P1 E1 D0 D1 F Marking TOP VIEW W A0 B0 16.0±0.30 7.0±0.10 7.5±0.10 K0 B0 A0 P1 K0 User Direction of Feed (2).DIMENSION(mm): W T P0 3.4±0.15 12.0±0.10 4.0±0.10 (3).REEL SIZE: P2 D0 D1 F 2.0±0.10 1.5±0.10 1.5±0.10 BOTTOM VIEW E1 T 7.5±0.10 1.75±0.10 0.4±0.05 (4).PACKAGE MODE: (5).PACKAGING LIST: No. Packing Part Dimension (mm) Material Quantity 1 2 Reel Bag 330 450 X 360 X 0.075 Plastic Plastic 1000PCS / Reel 1Reel / Bag 3 Small Box 340 X 335 X 45 Paper 2Bag / Small Box 4 Middle Box 356 X 350 X 226 Paper 4Small Boxes / Middle Box 5 Outer Box 378 X 362 X 252 Paper 1Middle Box / Outer Box (6).WEIGHT: N.W: 0.79g/pcs TOTAL6.32Kg(APPROX) , G.W: TOTA11.92Kg(APPROX). (7).Storage conditions: -40Ԩ~85Ԩ ,75%RH (Max.). ● ● New York 1 914 347 2474 ● Taipei 886 2 2698 8669 ● Kaohsiung 886 7 350 2275 Japan 81 568 85 2830 ● Shenzhen 86 755 8418 6263 ● Shanghai 86 21 5424 5141 ● Hong Kong 852 9688 9767 ● sales@ITG-Electronics.com ● www.ITG-Electronics.com Revision E.1: May 17 , 2017 *Due to continuous product improvement, all specifications are subject to change without prior notice. Kindly contact an ITG field application engineer or a sales representative prior to purchase. SMHC2511 Series 6.RELIABILITY TEST: 6.1 Mechanical Reliability Item Solderability Specification and Requirement Test Method The surface of terminal immersed shall be Solder heat proof: minimum of 95% covered with a new coating 1. Preheating: 160 ± 10 ℃ 2. Retention time: 245 ± 5 ℃ for 2 ± 0.5 seconds of solder Vibration Inductance change: Within ± 10% Without mechanical damage such as break 1. Vibration frequency: (10 Hz to 55 Hz to 10Hz) in 60 seconds as a period 2. Vibration time: Period cycled for 2 hours in each of 3 mutual perpendicular directions. 3. Amplitude: 1.5 mm max. Shock Inductance change: Within ±10% Without mechanical damage such as break 1. Peak value: 100 G 2. Duration of pulse: 11ms 3. 3 times in each positive and negative direction of 3 mutual perpendicular directions. Thermal Shock Inductance change: Within ± 10% Without distinct damage in appearance 1. Repeat 100 cycles as follow: (-55 ± 2 ℃; 30 ± 3 min) →(Room temp., 5 min) → (+125 ± 2 ℃, 30 ± 3 min) → (Room temp., 5 min) 2. Recovery: 48 + 4 / -0 hours of recovery under the standard condition after the test. High Temperature Resistance Inductance change: Within ± 10% Without distinct damage in appearance 1. Environment condition: 85 ± 2 ℃ Applied Current: Rated current 2. Duration: 1000 + 4 / -0 hours Humidity Resistance Inductance change: Within ± 10% Without distinct damage in appearance 1. Environment condition: 60 ± 2 ℃ Humidity: 90–95% Applied Current: Rated current 2. Duration: 1000 + 4 / -0 hours Low Temperature Store Inductance change: Within ± 10% Without distinct damage in appearance Store temperature: -55 ± 2 ℃,1000 + 4 / -0 hours High Temperature Store Inductance change: Within ± 10% Without distinct damage in appearance Store temperature: +125 ± 2 ℃,1000 + 4 / -0 hours 6.2 Endurance Reliability ● ● New York 1 914 347 2474 ● Taipei 886 2 2698 8669 ● Kaohsiung 886 7 350 2275 Japan 81 568 85 2830 ● Shenzhen 86 755 8418 6263 ● Shanghai 86 21 5424 5141 ● Hong Kong 852 9688 9767 ● sales@ITG-Electronics.com ● www.ITG-Electronics.com Revision E.1: May 17 , 2017 *Due to continuous product improvement, all specifications are subject to change without prior notice. Kindly contact an ITG field application engineer or a sales representative prior to purchase. SMHC2511 Series Soldering Reflow Chart Stage Precaution Recommended temperature profile Temperature profile can be referenced after confirming of adhesion , temperature of resistance to soldering heat , component size , soldering etc. sufficient . Reflow soldering Note: please refer to the latest IPC/JEDEC J-STD-020: “Moisture/Reflow Sensitivity Classification for Nonhermetic Solid State Surface Mount Devices" ● ● New York 1 914 347 2474 ● Taipei 886 2 2698 8669 ● Kaohsiung 886 7 350 2275 Japan 81 568 85 2830 ● Shenzhen 86 755 8418 6263 ● Shanghai 86 21 5424 5141 ● Hong Kong 852 9688 9767 ● sales@ITG-Electronics.com ● www.ITG-Electronics.com Revision E.1: May 17 , 2017 *Due to continuous product improvement, all specifications are subject to change without prior notice. Kindly contact an ITG field application engineer or a sales representative prior to purchase.
SMHC2511-1R0MHF
物料型号:SMHC2511系列
器件简介: - 这是一款高频应用的SMD功率电感器,操作频率可达5MHz。 - 尺寸为7.40 x 6.80mm,最大高度为3.00mm。 - 电感范围从0.10μH到10.0μH,可定制值。 - 采用分布式间隙金属粉尘芯,具有高饱和电流特性。 - 适用于便携设备、Pad、电子阅读器和高密度DC-DC转换器。 - 直流电阻较低,适用于高电流应用。
引脚分配:文档中未明确提供引脚分配信息。
参数特性: - 电感公差为±20%。 - 直流电阻(DCR)典型值和最大值在不同型号中有所不同,例如SMHC2511-R10MHF的DCR典型值为1.50mΩ,最大值为1.70mΩ。 - 饱和电流(Isat)和额定电流(Irms)也因型号而异。
功能详解: - 电感值随电流和温度变化的特性图提供了不同型号电感器在不同直流偏置下的电感值和温度上升情况。
应用信息: - 适用于需要高频率操作的便携式设备和高密度DC-DC转换器。
封装信息: - 提供了详细的机械尺寸和封装规格,包括封装模式、尺寸、卷带尺寸和包装清单。 - 存储条件为-40~85°C,75%RH(最大)。
可靠性测试包括焊接性、振动、冲击、热冲击、高温抗性、湿度抗性、低温存储和高温存储等测试项目,以确保产品在各种环境下的性能和稳定性。
SMHC2511-1R0MHF 价格&库存
很抱歉,暂时无法提供与“SMHC2511-1R0MHF”相匹配的价格&库存,您可以联系我们找货
