HCPT1309-R20-R
HCPT1309-R20-R
    EATON(伊顿)
    插件
    固定电感器 Radial, Horizontal 200nH ±20% 43.1A 0.426mΩ
HCPT1309-R20-R 数据手册
Technical Data 4138 Effective July 2017 Supersedes March 2007 HCPT1309 High current power inductors Applications • Next generation processors • High current DC-DC converters • VRM, multi-phase buck regulator • Desktop computers • Video game power Environmental Data • Storage temperature range (Component): -40 °C to +105 °C • Operating temperature range: -40 °C to +105 °C (ambient plus self-temperature rise) • Solder reflow temperature: J-STD-020 (latest revision) compliant Product features • • • • • 13.2 mm x 13.2 mm x 9.0 mm through hole package Iron powder core material Inductance range from 0.20 µH to 3.3 µH Current range from 90.0 A to 11.4 A Frequency range up to 1 MHz  Technical Data 4138 Effective July 2017  Product Specifications Part Number OCL (1) nominal +/20% (µH) 0.20 0.49 0.96 1.59 2.27 3.31 HCPT1309-R20-R HCPT1309-R47-R HCPT1309-1R0-R HCPT1309-1R5-R HCPT1309-2R2-R HCPT1309-3R3-R Irms (2) (A) 43.1 34.0 19.4 13.7 12.5 11.4 Isat (A) (3) Peak 20%rolloff @ +20 °C 72.2 43.3 30.9 24.1 19.7 16.7 Isat (A) (4) Peak 30%rolloff @+20 °C 90.0 55.0 40.0 30.6 25.0 21.0 DCR (mΩ) nom @+20 °C 0.426 0.624 1.90 3.82 4.10 4.80 Dimensions (mm) HCPT1309-xxx wwllyy R FRONT VIEW B OTTOM VIEW 9.0 max 13.2 sq MAX 1 2 3.5 +/- 0.5 "B" +/- 1.0 "A " MAX "C" typ SCHEMATIC Dimension Table Part No "A " "B" HCPT1309-R20 HCPT1309-R47 HCPT1309-1R0 HCPT1309-1R5 HCPT1309-2R2 HCPT1309-3R3 14.0 14.0 13.7 13.5 13.5 13.5 12.2 12.2 12.0 11.8 11.8 11.8 RECOMMENDED PCB PAD LAYOUT "C" "D" 1.63 1.63 1.29 1.15 1.15 1.15 2.13 2.13 1.6 1.40 1.40 1.40 Do not route traces or vias underneath the inductor 2 www.eaton.com/electronics 154.1 92.4 66.0 51.4 42.0 35.6 (3) Isat Amperes peak for approximately 20% rolloff (@+20 °C) (4) Isat Amperes peak for approximately 30% rolloff (@+20 °C) (5) K-factor: Used to determine B p-p for core loss (see graph). B p-p = K*L*∆I, B p-p: (Gauss), K: (K factor from table), L: (Inductance in uH), ∆(Peak to peak ripple current in Amps). (1) OCL: Open Circuit Inductance test parameters: 100 kHz, 0.1 Vrms, 0.0 Adc. (2) Irms: DC current for an approximate ∆T of 40 °C without core loss. Derating is necessary for AC currents. PCB layout, trace thickness and width, air-flow, and proximity of other heat generating components will affect the temperature rise. It is recommended that the temperature of the part not exceed +105 °C under worst case operating conditions verified in the end application. TOP VIEW K-factor (5) "B" +/- 1.0 ØD 1 HCPT1309 High current power inductors Technical Data 4138 Effective July 2017 Core loss vs. Bp-p 160.00 140.00 Core Loss (mW) 120.00 200kHz 300kHz 400kHz 500kHz 600kHz 700kHz 800kH 900kHz 1.0MHz 100.00 80.00 60.00 40.00 20.00 0.00 250 500 750 1000 1250 1500 1750 2000 2250 2500 2750 B p-p (Gauss) Inductance characteristics OCL vs Isat 100 90 80 OCL (%) 70 60 50 40 30 20 10 0 0 20 40 60 80 100 120 140 160 % of Isat www.eaton.com/electronics 3 HCPT1309 Technical Data 4138  Effective July 2017 Wave solder profile- Through-hole components Reflow soldering not recommended Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Eaton Electronics Division 1000 Eaton Boulevard Cleveland, OH 44122 United States www.eaton.com/electronics © 2017 Eaton All Rights Reserved Printed in USA Publication No. 4139 July 2017 Eaton is a registered trademark. All other trademarks are property of their respective owners.
HCPT1309-R20-R 价格&库存
很抱歉,暂时无法提供与“HCPT1309-R20-R”相匹配的价格&库存,您可以联系我们找货
HCPT1309-R20-R
    • 1+3.24000
    • 200+1.26360
    • 500+1.22040
    • 1000+1.18800
