BPS3M-TDTL
BPS3M-TDTL
    INDUSTRIALEMART
    SENSOR THROUGH-BEAM 3M NPN
BPS3M-TDTL 数据手册
BPS Series Slim Photoelectric Sensor for Long Sensing Distance SENSORS Features ● Easy to mount by Flat type ● Realization of 3m sensing distance as small size ● Protection structure IP67 (IEC standard) CONTROLLERS MOTION DEVICES Please read “Safety Considerations” in the instruction manual before using. SOFTWARE Specifications NPN open collector output PNP open collector output Sensing type Sensing target Operation mode Sensing distance Response time Power supply Current consumption Light source Model BPS3M-TDT BPS3M-TDTL BPS3M-TDT-P BPS3M-TDTL-P (A) Photoelectric Sensors Through-beam Opaque materials of min. Ø5mm Dark ON Light ON 3m Max. 1ms 12-24VDC ±10% (ripple P-P: max. 10%) Max. 20mA Infrared LED (850nm) NPN or PNP open collector output Control output ●Load voltage: max. 30VDC ●Load current: max. 100mA ●Residual voltage - NPN: max. 1VDC , PNP: Max. 2.5VDC Protection circuit Reverse polarity protection circuit, output short overcurrent protection circuit Indicator Emitter - power indicator: red LED, receiver - operation indicator: red LED Insulation resistance Over 20MΩ (at 500VDC megger) Noise immunity ±240V the square wave noise (pulse width: 1㎲) by the noise simulator Dielectric strength 1,000VAC 50/60Hz for 1 minute Vibration 1.5mm amplitude at frequency of 10 to 55Hz (for 1 min) in each X, Y, Z direction for 2 hours Shock 500m/s² (approx. 50G) in each X, Y, Z direction for 3 times Ambient illumination Sunlight: max. 11,000lx, incandescent lamp: max. 3,000lx (receiver illumination) EnvironAmbient temperature -25 to 65℃, storage: -25 to 70℃ ment Ambient humidity 35 to 85%RH, storage: 35 to 90%RH Protection structure IP67 (IEC standard) Material Case: polycarbonate, bolt: steel chromium molybdenum, nut: steel chromium molybdenum Ø3mm, 3-wire, 2m (emitter of through-beam type: Ø3mm, 2-wire, 2m) Cable (AWG24, core diameter: 0.08mm, number of cores: 40, insulator out diameter: Ø1mm) Accessory M3 bolt: 4, M3 nut: 4 Approval Unit weight Approx. 66g ※The temperature or humidity mentioned in Environment indicates a non freezing or condensation environment. (B) Fiber Optic Sensors (C) LiDAR (D) Door/Area Sensors (E) Vision Sensors (F) Proximity Sensors (G) Pressure Sensors (H) Rotary Encoders (I) Connectors/ Connector Cables/ Sensor Distribution Boxes/ Sockets Feature Data Measuring method Parallel shifting characteristic Measuring method Sensor angle characteristic 3.0 3.5 ℓ1 Emitter Sensing distance L (m) L 2.5 2.0 1.5 1.0 0.5 0 200 θ 100 Left ℓ1 0 Center 100 ℓ1 200 Emitter Right Sensing area (mm) L Sensing distance L (m) 3.0 Receiver 2.5 Receiver 2.0 1.75 1.5 1.25 1.0 0.5 0 20° 10° Left 0 Center 10° Right 20° Operation angle (θ) A-67 BPS Series Control Output Diagram ● NPN open collector output ● PNP open collector output Photoelectric sensor circuit Photoelectric sensor circuit Connection Connection (brown)+V (black)output Load Max.100mA Output short overcurrent protection circuit 3.3Ω + - Main circuit Main circuit (brown)+V 12-24VDC (blue)0V Output short overcurrent protection circuit 3.3Ω Max.100mA + - (black)output (blue)0V 12-24VDC Load ※If short-circuit the control output terminal or supply current over the rated specification, normal control signal is not output due to the output short over current protection circuit. Operation Mode Operation mode Light ON Dark ON Received light Interrupted light ON Operation indicator OFF (red LED) ON Transistor output OFF Received light Interrupted light ON OFF Receiver operation ※Dark ON mode is standard and Light ON (Received Light: ON) mode is customizable. ON OFF Connections NPN open collector output ● BPS3M-TDT1 PNP open collector output (brown)+V + - (blue)0V (emitter) ● BPS3M-TDT1 (black)Output Load (brown)+V + 0.3 (unit: mm) 7.5 11.4 19 9.5 14.8 5.5 28 12.7 2-M4 Bolt 57.2 5.5 Ø3, 2m 30 Optical axis 25.8 17 12-24VDC ●Cover (sold separately) 2.5 M3 Bolt 4.5 A-68 - (blue)0V Load (receiver) Emitter: power indicator Receiver: operation indicator 12 + (black)Output 12-24VDC Dimensions Optical axis 12-24VDC ● BPS3M-TDT2-P / BPS3M-TDTL2-P - (blue)0V - (blue)0V (emitter) (brown)+V 16 + 12-24VDC ● BPS3M-TDT2 / BPS3M-TDTL2 (receiver) (brown)+V
BPS3M-TDTL 价格&库存
很抱歉,暂时无法提供与“BPS3M-TDTL”相匹配的价格&库存,您可以联系我们找货
