BA2M-DDT-P
BA2M-DDT-P
    INDUSTRIALEMART
    SENSOR REFLECTIVE 2M PNP 12-24V
BA2M-DDT-P 数据手册
BA Series Small, Diffuse Reflective Type with Long Sensing Distance SENSORS Features ● Realization of long sensing distance (2m) by special optical design ● Protection structure IP64 (IEC standard) ● Built-in stability indicator ● Includes sensitivity adjustment function ● 2 color LED display CONTROLLERS MOTION DEVICES SOFTWARE Please read “Safety Considerations” in the instruction manual before using. Specifications Model (A) Photoelectric Sensors NPN open collector BA2M-DDT BA2M-DDTD PNP open collector BA2M-DDT-P BA2M-DDTD-P Sensing type Diffuse reflective Sensing distance 2m (non-glossy white paper 200×200mm) Sensing target Translucent, opaque materials Hysteresis Max. 20% at sensing distance Response time Approx. 1ms Power supply 12-24VDC Current consumption Max. 15mA (max. 30mA when the output is ON) Light source Infrared LED (850nm) Sensitivity adjustment Sensitivity adjuster Operation mode Light ON Control output NPN or PNP open collector output ●Load voltage: max. 26.4VDC ●Load current: max. 100mA ●Residual voltage - NPN: max. 1VDCᜡ, PNP: min. 2.5VDC Protection circuit Reverse polarity protection circuit, output short overcurrent protection circuit Indicator ●Operation indicator: red LED Insulation resistance Over 20MΩ (at 500VDC megger) Noise immunity ±240V the square wave noise (pulse width: 1㎲) by the noise simulator Dielectric strength 1000VAC 50/60Hz for 1 minute Vibration 1.5mm amplitude at frequency of 10 to 55Hz (for 1 min) in each X, Y, Z direction for 2 hours Shock 100m/s² (approx. 10G) in each X, Y, Z direction for 3 times (B) Fiber Optic Sensors (C) LiDAR (D) Door/Area Sensors ±10% (ripple P-P: max. 10%) (E) Vision Sensors (F) Proximity Sensors Dark ON (G) Pressure Sensors (H) Rotary Encoders ●Stability indicator: orange LED (light on), green LED (dark on) (I) Connectors/ Connector Cables/ Sensor Distribution Boxes/ Sockets Ambient illumination Sunlight: max. 11,000㏓, incandescent lamp: max. 3,000㏓ (receiving illumination) EnvironAmbient temperature -25 to 55℃, storage: -25 to 70℃ ment Ambient humidity 35 to 85%RH, storage: 35 to 85%RH Protection structure IP64 (IEC standard) Material Case: acrylonitrile butadiene styrene, sensing part: polycarbonate, indicator: polycarbonate, adjuster: IXEF Cable Ø3mm, 3-wire, 2m (AWG24, core diameter: 0.08mm, number of cores: 40, insulator out diameter: Ø1mm) Accessory Adjuster driver Approval Unit weight Approx. 50g ※The temperature or humidity mentioned in Environment indicates a non freezing or condensation environment. A-55 BA Series Feature Data Sensing distance against the target size ℓ1 2.2 2.0 1.8 1.6 1.4 1.2 1.0 0.8 0.6 0.4 0.2 0 Sensing distance L (m) Sensing target Sensing distance L (m) Sensing area characteristic 60 40 20 0 20 40 60 ℓ1 ℓ1 Center Left 2.2 2.0 1.8 1.6 1.4 1.2 1.0 0.8 0.6 0.4 0.2 0 Sensing distance against the target color (%) 75 60 45 Black 30 15 0 50 80 100 150 200 In case non-glossy white paper is 100% (standard targets: 200×200mm) Sensing area (mm) Control Output Diagram ● NPN open collector output ● PNP open collector output Photoelectric sensor circuit Connection Photoelectric sensor circuit Connection Output short over current protection circuit (brown) +V Load Max. 100mA + - Main circuit Main circuit (brown) +V (black) Output Blue 90 Sensing target size (mm) Right White Yellow Red 100 12-24VDC (blue) 0V Output short over current protection circuit Max. 100mA + - (black) Output 12-24VDC Load (blue) 0V ※If short-circuit the control output terminal or supply current over the rated specification, normal control signal is not output due to the output short over current protection circuit. Connections (brown) (blue) Sensing target + 12-24VDC - (black)Output Dimensions (unit: mm) 4.7 18.5 3.5 16 M3 Bolt Ø3, 2m A-56 10 8 7.5 2color LED (operation/stability indicator) 15.5 41.5 16 48.5 34.5 Sensitivity adjuster 19 Diffuse Reflective Type with Long Sensing Distance Operation Mode If the control output terminal is short-circuit or over current than the rated current flows the unit, the sensor does not operate normally by protection circuit. SENSORS ● Light ON Stable light ON area Unstable light ON area Unstable light OFF area Stable light OFF area Stability indicator (orange LED) Light ON operation CONTROLLERS High MOTION DEVICES Incident light level SOFTWARE Low ON OFF Operation indicator ON (red LED) OFF Transistor output (A) Photoelectric Sensors ON OFF (B) Fiber Optic Sensors (control output according to amount of receiving light) ● Dark ON Stable light ON area Unstable light ON area Unstable light OFF area Stable light OFF area Stability indicator (green LED) Light ON operation Operation level High (C) LiDAR Incident light level (D) Door/Area Sensors Operation level (E) Vision Sensors Low (F) Proximity Sensors ON OFF Operation indicator ON (red LED) OFF (G) Pressure Sensors ON OFF (H) Rotary Encoders Transistor output (control output according to amount of receiving light) Mounting and Sensitivity Adjustment Install the sensor to the desired place and check the connections. Supply the power to the sensor and adjust the optical axis and the sensitivity as follow ; When using photoelectric sensors closely over two units, ● Adjustment it may result in malfunction due to mutual interference. 1. When sensing the object, set the sensitivity adjuster in When installing the product, tighten the screw with a stable Light ON area (orange: Light ON, green: Dark tightening torque of 0.5N.m. ON) as shown ‘ Operation mode’. ● Optical axis adjustment 2. The sensitivity should be adjusted depending on a sensing target or mounting place. ⓐ 3. Set the target at a position to be detected by the beam, Optimal then turn the sensitivity adjuster until position ⓐ where position Sensing the operation indicator turns ON from min. position of the target sensitivity adjuster ⓑ 4. Take the target out of the sensing area, then turn the MIN. MAX. sensitivity adjuster until position ⓑ where the operation indicator turns ON. If the indicator dose not turn ON, max. position is ⓑ. Mount this unit at the center where the stability indicator 5. Set the sensitivity adjuster at the center of two switching turns ON with moving the unit toward right or left, up or position ⓐ, ⓑ. down. ※The sensing distance indicated on specification chart is for 200×200mm of non-glossy white paper. Be sure that it can be different by size, surface and gloss of target. A-57 (I) Connectors/ Connector Cables/ Sensor Distribution Boxes/ Sockets
BA2M-DDT-P 价格&库存
很抱歉,暂时无法提供与“BA2M-DDT-P”相匹配的价格&库存,您可以联系我们找货
