BTF15-BDTD
BTF15-BDTD
    INDUSTRIALEMART
    SENSOR BGS REFLECTIVE 1-15MM NPN
BTF15-BDTD 数据手册
BTF Series Ultra-slim and Amplifier Built-in Type Features SENSORS ●U  ltra-thin size of only 3.7mm - W13 × H19 × L3.7mm (through-beam type) - W13 × H24 × L3.7mm (diffuse reflective type, BGS reflective type) ●D  etection methods and minimum target size - Through-beam type (BTF1M): Ø2mm - Diffuse reflective type (BTF30): Ø0.2mm (at distance 10mm) - BGS reflective type (BTF15): Ø0.2mm (at distance 10mm) ● Detecting distance may vary by environmental factors ● Maximum detection distance: 1m (through-beam type) ● Stability indicator (green LED) and operation indicator (red LED) ● Stainless steel 304 mounting brackets ● IP67 protection structure (IEC standard) Please read “Safety Considerations” in the instruction manual before using. CONTROLLERS MOTION DEVICES Through-beam SOFTWARE Diffuse reflective / BGS reflective (A) Photoelectric Sensors (B) Fiber Optic Sensors Model Specifications NPN open collector output BTF1M-TDTL BTF1M-TDTD PNP open collector output BTF1M-TDTL-P BTF1M-TDTD-P BTF30-DDTL-P BTF30-DDTL BTF30-DDTD BTF15-BDTL BTF15-BDTD BTF30-DDTD-P BTF15-BDTL-P BTF15-BDTD-P Sensing type Sensing distance Sensing target Through-beam 1m Opaque material over Ø2mm Min. sensing target Opaque material of Ø2mm Hysteresis Reflectivity characteristics (black/white error) Response time Power supply Current consumption Light source Operation mode - Diffuse reflective 5 to 30mm※1 Translucent, opaque materials Ø0.2mm (sensing distance 10mm) Max. 20% at sensing distance - - BGS reflective 1 to 15mm※1 (C) LiDAR (D) Door/Area Sensors Ø0.2mm non-illuminated objects (sensing distance 10mm) Max. 5% at sensing distance Max. 15% of maximum sensing distance (E) Vision Sensors (F) Proximity Sensors Max. 1ms 12-24VDCᜡ ±10% (ripple P-P: max. 10%) Max. 20mA (this is for each emitter and receiver of throught-beam type.) Red LED (650nm) Light ON Dark ON Light ON Dark ON Light ON Dark ON NPN or PNP open collector output Control output • Load voltage: max. 26.4VDCᜡ • Load current: max. 50mA • Residual voltage - NPN: max. 1VDCᜡ, PNP: max. 2VDC Protection circuit Power reverse polarity protection circuit, output short over current protection circuit Indicator Operation indicator: red LED, stability indicator: green LED Connection Cable type Insulation resistance Over 20MΩ (at 500VDC megger) Noise immunity ±240V the square wave noise (pulse width:1㎲) by the noise simulator Dielectric strength 1,000VAC 50/60Hz for 1 minute Vibration 1.5mm amplitude at frequency of 10 to 55Hz in each X, Y, Z direction for 2 hours Shock 500m/s² (approx. 50G) in each X, Y, Z direction for 3 times Ambient illumination Sunlight: max. 10,000lx, incandescent lamp: max. 3,000lx (receiver illumination) EnvironAmbient temperature -25 to 55℃, storage: -40 to 70℃ ment Ambient humidity 35 to 85%RH, storage: 35 to 85%RH Protection IP67 (IEC standards) Case: polybutylene terephthalate, sensing part: polymethyl methacrylate, Material bracket: SUS304 (steel use stainless 304), bolt: carbon steel, sleeve: SUS304 (steel use stainless 304) Ø2.5mm, 3P, 2m (emitter of through-beam type: Ø2.5mm, 2P, 2m) Cable (AWG 28, core diameter: 0.08mm, number of core: 19, insulator out diameter: Ø0.9mm) Accessory Fixing bracket, M2 bolt: 4 Fixing bracket, M2 bolt: 2 Approval Weight※2 Approx. 70g (approx. 40g) Approx. 40g (approx. 25g) (G) Pressure Sensors (H) Rotary Encoders (I) Connectors/ Connector Cables/ Sensor Distribution Boxes/ Sockets ※1: Non-glossy white paper 50×50mm. ※2: The weight includes packaging. The weight in parenthesis is for unit only. ※The temperature or humidity mentioned in Environment indicates a non freezing or condensation. A-15 BTF Series Feature Data Diffuse reflective type Through-beam type ● BTF1M-TDTL / BTF1M-TDTL-P ● BTF30-DDTL / BTF30-DDTL-P Sensing area characteristic Measuring method Data Sensing area characteristic Measuring method Data 1.6 Emitter ℓ1 L Receiver Sensing distance L (mm) Sensing distance L (m) 1.4 1.2 1.0 Standard ℓ1 sensing target 0.8 0.6 0.4 L 0.2 0 60 40 20 0 20 40 60 ℓ1 ℓ1 50 45 40 35 30 25 20 15 10 0 3 2 1 0 1 2 3 ℓ1 ℓ1 Sensing area (mm) Sensing area (mm) BGS reflective type ● BTF15-BDTL / BTF15-BDTL-P Sensing area characteristic Measuring method Data Standard sensing target L Sensing distance L (mm) Sensing distance L (mm) ℓ1 Sensing distance by material 18 16 14 12 10 9 6 4 2 0 3 2 1 0 1 2 3 ℓ1 ℓ1 20 15 10 5 0 White paper Black paper PCB (green) SUS304 Acrylic (transparent) Sensing target (material) Sensing area (mm) Connections Control Output Circuit Diagram ● Through-beam type ● NPN open collector output Photoelectric sensor circuit Connection Main circuit (brown) +V Sensing target (brown) +V 12-24VDC (blue) 0V (brown) +V + - 1 Load (black) Output 2 Load (blue) 0V Load (black) Output Output short over current protection circuit Max. 50mA + - 12-24VDC + - 12-24VDC (blue) 0V ● PNP open collector output ● Diffuse reflective/BGS reflective type Photoelectric sensor circuit Connection Main circuit (brown) +V Sensing target (brown) +V (black) Output (blue) 0V 1: Load connection for NPN output 2: Load connection for PNP output A-16 Load 1 12-24VDC Load 2 + - Output short over current protection circuit Max. 50mA (black) Output (blue) 0V Load ※If short-circuit the control output terminal or supply current over the rated specification, normal control signal is not output due to the output short over current protection circuit. Ultra-slim and Amplifier Built-in Type Operation Mode Operation mode Receiver operation Light ON SENSORS Dark ON Received light Received light Interrupted light Interrupted light ON ON OFF OFF Operation indicator (red LED) Transistor output ON ON OFF OFF CONTROLLERS MOTION DEVICES SOFTWARE Dimensions (unit: mm) ● Through-beam type 1.2 (A) Photoelectric Sensors 9 (B) Fiber Optic Sensors 15.5 Operation indicator (red) Optical axis of emitter Stability indicator (green) 3.7 6.8 (C) LiDAR 2-M3 8 (E) Vision Sensors 4 4 4 Optical axis of receiver 16 2.4 8.6 18 8.6 19 (D) Door/Area Sensors (F) Proximity Sensors 2-2M 13 (G) Pressure Sensors 3.2 8 Ø2.5, 2m 4.6 10.3 (H) Rotary Encoders ● Diffuse reflective/BGS reflective type 1.2 (I) Connectors/ Connector Cables/ Sensor Distribution Boxes/ Sockets 9 15.5 Operation indicator (red) Stability indicator (green) 3.7 6.8 8 2.4 4 4 Optical axis of emitter 16 4.8 Optical axis of receiver 7.9 23 24 2-M3 2-2M Ø2.5, 2m 3.2 8 13 4.6 10.3 A-17 BTF Series Operation Timing Diagram High Stable light ON area Unstable light ON area Unstable light OFF area Incident light level Operation level Stable light OFF area Low Stability indicator ON (green LED) OFF Light ON operation Operation indicator ON (red LED) OFF Transistor output ON OFF ※The waveform of ‘Operation indicator’ and ‘Transistor output’ are for Light ON operation. The waveform are reversed for Dark ON operation. Installation and Adjustment For mounting Notice for BGS reflective type When using photoelectric sensors closely over two units, it may result in malfunction due to mutual interference. When installing the product, tighten the screw with a tightening torque of 0.3N.m. ※Do not impact on the unit with hard objects and do not bend the cable part too much. It may cause damage to waterproof function. ● Through-beam type 4-M2 Tap×0.4mm M2×4mm ● Diffuse reflective/BGS reflective type 1) Make sure that the sensing side of this sensor is parallel with the surface of each sensing object. 2) If the sensing object has glossary surface or high reflection, the sensor tilts from 5 to 10˚as shown in the figure. Make sure whether the sensor is influenced by any background objects. Sensing target 5 to 10° Glossy materials 3) Make sure to install the sensor in the proper direction with considering moving direction of sensing objects. Sensing Refer to the following. 4-M2 Tap×0.4mm Sensing target M2×4mm Sensing target target Moves vertically Moves horizontally Optical axis adjustment ● Through-beam type Set the emitter and the receiver facing each other and adjust these up·down, right·left after checking the point of operating the stability indicator. Fix the emitter and the receiver at the center of the point. Adjust Right/Left A-18 ● Diffuse reflective/BGS reflective type After placing a sensing target, fix it in the middle of position where the stability indicator operates when adjusting the sensor to up·down, right·left. Make sure that the sensing side of the sensor is parallel with the surface of each sensing target. Adjust Right/Left Adjust Up/Down Moves back and forth Sensing target Adjust Up/Down
BTF15-BDTD 价格&库存
很抱歉,暂时无法提供与“BTF15-BDTD”相匹配的价格&库存,您可以联系我们找货
