BRP200-DDTN
BRP200-DDTN
    INDUSTRIALEMART
    SENSOR REFLECTIVE 200MM NPN
BRP200-DDTN 数据手册
BR Series Cylindrical (Ø18mm) Type Features SENSORS ● Realizes long sensing distance (20m) (through-beam type) ● Superior noise resistance with digital signal processing ● High-speed response time under 1ms ● Power reverse polarity protection circuit, output short over current protection circuit ● Suitable for sensing in narrow space (narrow beam type) ● External sensitivity adjustment (except through-beam type) ● Light ON, Dark ON switchable by control wire (except through-beam type) ● Excellent environment-resistance performance with glass lens(BR4M) ● Protection structure IP66 (IEC standard) Please read “Safety Considerations” in the instruction manual before using. model BR100­DDT BR100­ DDT-C BR100­ DDT-P BR100­ DDT-C-P Metal BRP400­ DDT BRP400­ DDT-C BRP400­ DDT-P BRP400­ DDT-C-P Plastic BR400­DDT BR400­ DDT-C BR400­ DDT-P BR400­ DDT-C-P Metal Diffuse reflective type Sensing distance 100mm Sensing target Opaque, translucent materials 400mm Cable type SOFTWARE (MS-2) Connector Type ※The model name with ‘-C’ is connector type. ※MST- is sold separately. Sensing type ※1 MOTION DEVICES (MST- ) Specifications BRP100­NPN open collector DDT output BRP100­ DDT-C BRP100­ PNP open collector DDT-P output BRP100­ DDT-C-P Case Plastic CONTROLLERS ※2 BRP200­ BR200­ DDTN DDTN BRP200­ BR200­ DDTN-C DDTN-C BRP200­ BR200­ DDTN-P DDTN-P BRP200­ BR200­ DDTN-C-P DDTN-C-P Plastic Metal Narrow beam reflective type ※2 200mm BR4MBR20M- BR4MBR20MTDTD TDTD TDTL TDTL BR4MBR20M- BR4MBR20MTDTD-C TDTD-C TDTL-C TDTL-C BR4MBR20M- BR4MBR20MTDTD-P TDTD-P TDTL-P TDTL-P BR4MBR20M- BR4MBR20MTDTD-C-P TDTD-C-P TDTL-C-P TDTL-C-P Metal 4m 20m 4m (B) Fiber Optic Sensors (C) LiDAR (D) Door/Area Sensors 20m Opaque materials of min. Ø15mm Ambient temperature -10 to 60℃, storage: -25 to 75℃ Ambient humidity Protection structure (A) Photoelectric Sensors Through-beam type Max. 20% at rated sensing distance Max. 1ms 12-24VDCᜡ±10% (ripple P-P: max. 10%) Max. 45mA Infrared LED (940nm) Infrared LED (850nm) Red LED (660nm) Infrared LED (850nm) Sensitivity adjuster Fixed Selectable Light ON or Dark ON by control wire (white) Dark ON Light ON NPN or PNP open collector output Control output ●Load voltage: max. 30VDCᜡ ●Load current: max. 200mA ●Residual voltage - NPN: max. 1VDCᜡ, PNP: max. 2.5VDC Protection circuit Power reverse polarity protection circuit, output short over current protection circuit Indicator Operation indicator: red LED, power indicator: red LED (only for emitter of through-beam type) Connection Cable type, connector type Insulation resistance Over 20MΩ (at 500VDC megger) Noise immunity ±240V the square wave noise (pulse width: 1㎲) by the noise simulator Dielectric strength 1000VAC 50/60Hz for 1 minute Vibration 1.5mm amplitude at frequency of 10 to 55Hz (for 1 min) in each X, Y, Z direction for 2 hours Shock 500m/s² (approx. 50G) in each X, Y, Z direction for 3 times Ambient illumination Sunlight: max. 11,000lx, incandescent lamp: max. 3,000lx (receiver illumination) Environment Hysteresis Response time Power supply Current consumption Light source Sensitivity adjustment Operation mode BRP3M­- BR3M­MDT MDT BRP3M­ BR3MMDT-C MDT-C BRP3M­ BR3M-­ MDT-P MDT-P BRP3M- BR3M-­ ­MDT-C-P MDT-C-P Plastic Metal Retroreflective type ※3 3m Opaque materials of min. Ø60mm - 35 to 85%RH, storage: 35 to 85%RH IP66 (IEC standard) (BR20M Series: IP67) ●Case - BRP: ●Case - brass, ni-plate polyamide (black) ●Sensing part - BR4M: glass lens Material BR: brass, ni-plate BR20M: polycarbonate ●Sensing part lens acrylic lens Ø5mm, 4-wire, 2m (emitter of through-beam type: Ø5mm, 2-wire, 2m / receiver: Ø5mm, 3-wire, 2m) Cable type (AWG22, core diameter: 0.08mm, number of cores: 60, insulator out diameter: Ø1.25mm) Cable Connector type M12 connector Adjustment Individual Adjustment screwdriver screwdriver, AcceReflector (MS-2) ssory ● BR: M18 fixing nut: 2, washer: 1 ● BR: M18 fixing nut: 4, washer: 2 Common ● BRP: M18 fixing nut: 2 ● BRP: M18 fixing nut: 4 Approval ※4 ●BRP: approx. 140g (approx. 100g) ●BR: approx. 160g (approx. 120g) ●BR: a  pprox. 340g (approx. 300g) Weight ●BRP-C: approx. 70g (approx. 30g) ●BR-C: approx. 90g (approx. 50g) ●BR-C:approx. 150g (approx.110g) ※1: Non-glossy white paper 50×50mm. ※2: Non-glossy white paper 100×100mm. ※3: The sensing distance is specified with using the MS-2 reflector. The distance between the sensor and the reflector should be set over 0.1m. When using reflective tapes, the reflectivity will vary by the size of the tape. Please refer to the catalog or website. ※4: The weight includes packaging. The weight in parenthesis is for unit only. ※Tightening torque for connector is 0.39 to 0.49N.m. ※The temperature or humidity mentioned in Environment indicates a non freezing or condensation. ●Case - BRP: polyamide (black) BR: brass, ni-plate ●Sensing part - polycarbonate lens A-101 (E) Vision Sensors (F) Proximity Sensors (G) Pressure Sensors (H) Rotary Encoders (I) Connectors/ Connector Cables/ Sensor Distribution Boxes/ Sockets BR Series Feature Data Diffuse reflective type / Narrow beam reflective type Sensing area characteristic Sensing area characteristic Measuring method Data Measuring method Measuring method Data Standard sensing target:Non-glossy white paper 50×50mm Standard sensing target:Non-glossy white paper 50×50mm L Sensing distance L (mm) ℓ1 100 Data ℓ1 70 40 L 10 0 Diffuse reflective 20 10 0 ℓ1 Left 10 ℓ1 Center 20 400 ℓ1 300 200 L 100 0 20 Diffuse reflective Right Sensing area ℓ1 (mm) Standard sensing target:Non-glossy white paper 50×50mm 10 0 ℓ1 Left Center 10 Sensing distance L (mm) ●BR200-DDTN- (-P)/BRP200-DDTN- (-P) Sensing area characteristic Sensing distance L (mm) ●BR100-DDT- (-P)/BRP100-DDT- (-P) ●BR400-DDT- (-P)/BRP400-DDT- (-P) 200 150 100 50 0 20 20 ℓ1 Diffuse reflective Right Sensing area ℓ1 (mm) 10 0 ℓ1 ℓ1 Left Center 10 20 Right Sensing area ℓ1 (mm) Retroreflective type ● BR3M-MDT- (-P) / BRP3M-MDT- (-P) Parallel shifting characteristic Parallel shifting characteristic Parallel shifting characteristic Measuring method Measuring method Measuring method Data Reflector (MS-2) L 4 3 θ 2 1 0 120 80 40 0 ℓ1 40 80 120 ℓ1 Center Left Retroreflective L Right Reflector (MS-2) Sensing distance L (m) Sensing distance L (m) Reflector (MS-2) ℓ1 Data 4 3 2 L 1 0 10° 5° 0 Center Left 5° 10° 4 3 2 1 0 60° 40° 20° Left Right Operation angle θ Retroreflective Sensing area ℓ1 (mm) θ Sensing distance L (m) Data Angle characteristic Measuring method Measuring method Receiver L ℓ1 L Sensing distance L (m) Data 4 Receiver 3 2 θ L 1 0 200 Emitter 100 ℓ1 0 100 ℓ1 Center Left 200 4 3 2 1 0 20° 10° 0 Center Left Right Sensing area ℓ1 (mm) ● BR20M-TDT - Data Sensing distance L (m) / BR4M-TDT - -P Parallel shifting characteristic / BR20M-TDT - -P Parallel shifting characteristic Angle characteristic Measuring method Measuring method Data 10 20° Right Operation angle θ Emitter Data Emitter L 20 Receiver 15 10 θ 5 0 800 600 400 200 0 200 400 600 800 ℓ1 Left Center Right A-102 15 10 5 0 15° 10° ℓ1 Sensing area ℓ1 (mm) L Sensing distance L (m) ℓ1 Sensing distance L (m) 20 Receiver Emitter Left 5° 0° Center 20° 40° 60° Right Operation angle θ Retroreflective Through-beam type ● BR4M-TDT - 0 Center 5° 10° Right Operation angle θ 15° Cylindrical Type Dimensions (unit: mm) Diffuse reflective/Narrow beam reflective/Retroreflective type BR100-DDT(-P) BR400-DDT(-P) Ø29 24 BR200-DDTN(-P) SENSORS BR3M-MDT(-P) CONTROLLERS 4 47 74.3 18.3 Sensitivity adjuster 4 48 75.3 18.3 M18×1 4 BR100-DDT-C(-P) BR400-DDT-C(-P) Ø29 24 3 48 4 Lens Ø5, 2m 17.6 M18×1 Sensitivity adjuster Operation indicator (red) M18×1 4 BR200-DDTN-C(-P) 78.6 MOTION DEVICES Operation indicator (red) Operation indicator (red) Lens Sensitivity adjuster SOFTWARE Ø5, 2m BR3M-MDT-C(-P) 4 M12×1 79.6 48 17.6 M18×1 4 (A) Photoelectric Sensors (B) Fiber Optic Sensors Sensitivity adjuster Operation indicator (red) (C) LiDAR (D) Door/Area Sensors M12×1 (E) Vision Sensors BRP100-DDT(-P) BRP400-DDT(-P) Ø26.5 24 3 BRP200-DDTN(-P) 48 44 Lens BRP100-DDT-C(-P) BRP400-DDT-C(-P) Ø26.5 24 3 74.3 18.3 M18×1 Sensitivity adjuster Operation indicator (red) 4 Ø5, 2m 78.6 17.6 Sensitivity adjuster 48 44 BRP200-DDTN-C(-P) 48 75.3 18.3 M18×1 44 M18×1 M12×1 (G) Pressure Sensors Sensitivity adjuster (H) Rotary Encoders Operation indicator (red) (I) Connectors/ Connector Cables/ Sensor Distribution Boxes/ Sockets Ø5, 2m BRP3M-MDT-C(-P) 4 48 79.6 17.6 Sensitivity adjuster Operation indicator (red) Operation indicator (red) Lens (F) Proximity Sensors BRP3M-MDT(-P) 44 M18×1 M12×1 A-103 BR Series Through-beam type (unit: mm) BR4M-TDTD(-P) / BR4M-TDTL(-P) Ø29 24 68.5 2.5 67 Operation indicator (red) 48 Lens Operation indicator (red) 46.5 2.5 Lens Ø5, 2m M18×1 4 Ø5, 2m M18×1 4 BR4M-TDTD-C(-P) / BR4M-TDTL-C(-P) Ø29 24 74.1 Lens 2.5 17.6 44 Operation indicator (red) 72.6 2.5 Lens 17.6 42.5 M12×1 4 M18×1 Power indicator (red) M12×1 4 M18×1 BR20M-TDTD(-P) / BR20M-TDTL(-P) Ø29 24 3 62 41 11.5 Power indicator (red) Lens M18×1 4 Ø5, 2m 62 41 3 11.5 Operation indicator (red) Lens Ø5, 2m M18×1 4 BR20M-TDTD-C(-P) / BR20M-TDTL-C(-P) Ø29 24 3 Lens M18×1 37 67.6 17.6 M12×1 4 37 3 Power indicator (red) Lens M18×1 67.6 17.6 M12×1 4 Operation indicator (red) Connection cable (sold separately) CIDH4- CLDH4- Ø6 Ø14.8 32 Ø14.8 L(m)※ ※Specifi cation of connector cable: Ø6mm, 4-wire, 2m/3m/5m/7m (AWG22, core diameter: 0.08mm, number of cores: 60, insulator out diameter: Ø1.65mm) A-104 Ø6 27.5 40 L(m)※ Cylindrical Type ● Reflector M18 fixing nut 4 24 M18×1 A 2-Ø3.8 0.38 SENSORS 4.2 24 24 4 Reflective tape (sold separately) MS-2 52 60.5 (unit: mm) M18×1 34 40.5 Model 3.25 8.5 2.5 CONTROLLERS A MST-50-10 50 MST-100-5 100 MST-200-2 200 MOTION DEVICES SOFTWARE Operation Mode Operation mode Light ON Receiver operation Dark ON Received light Received light Interrupted light Interrupted light ON ON OFF OFF ON ON OFF OFF Operation indicator (red LED) Transistor output (A) Photoelectric Sensors (B) Fiber Optic Sensors ※The transistor output will be held OFF for 0.5 sec after supplied power in order to prevent malfunction of this photoelectric sensor (except through-beam type). Connections ● Diffuse reflective type / Narrow beam reflective type Sensitivity adjuster Sensitivity adjuster + 12-24VDC - Dark ON Light ON MS-2 (reflector) Reflective tape (MST Series) (brown) +V Operation indicator (red) Sensing target (blue) 0V Dark ON (white) Control Light ON (brown) +V + 12-24VDC (blue) 0V (white) Control Operation indicator (red) Sensing target (brown) +V (brown) +V + 12-24VDC - (blue) 0V 12-24VDC + - (blue) 0V (black) Output Connections for Connector Part 1 Pin No. 2 3 4 M12 Connector pin 1 2 3 4 Cable color Brown White Blue Black Application Diffuse/ Narrow beam reflective/ Retroreflective type 24VDC CONTROL GND OUTPUT Through-beam type Emitter Receiver 24VDC N.C GND N.C 24VDC GND GND OUTPUT (G) Pressure Sensors (I) Connectors/ Connector Cables/ Sensor Distribution Boxes/ Sockets ● Through-beam type Power indicator (red) (F) Proximity Sensors (H) Rotary Encoders (black) Output (black) Output (D) Door/Area Sensors (E) Vision Sensors ● Retroreflective type Operation indicator (red) Sensing target (C) LiDAR ● Connector cable (sold separately) ※Please refer to the connector cable section. A-105 BR Series Control Output Diagram ● NPN open collector output ● PNP open collector output Through-beam type (receiver) Through-beam type (receiver) Connection Main circuit 1 4 Output short over current protection circuit Photoelectric sensor circuit 1.5Ω 3 (brown) +V 1 Load (black) Output + - Max. 200mA 39V Connection (brown) +V 12-24VDC Main circuit Photoelectric sensor circuit Output short over current protection circuit 1.5Ω 39V Max. 200mA 4 (blue) 0V 3 (black) Output (blue) 0V + - 12-24VDC Load Diffuse reflective/Narrow beam reflective/Retroreflective type Diffuse reflective/Narrow beam reflective/Retroreflective type Photoelectric sensor circuit Photoelectric sensor circuit Connection Main circuit 4 Output short over current protection circuit 39V 1.5Ω 3 10kΩ 2 1 Load (black) Output + Max. 200mA (blue) 0V Connection Dark ON - 12-24VDC Main circuit 1 (brown) +V Light ON Output short over current protection circuit Dark ON 1.5Ω 39V Max. 200mA 4 3 10kΩ (white) Control (brown) +V 2 (black) Output (blue) 0V Load + - 12-24VDC Light ON (white) Control ※Before using this unit, select Light ON/Dark ON with control wire. (light on: connect control wire 0V / dark on: connect control wire with +V) ※Control wire is only for Diffuse reflective/Narrow beam reflective/Retroreflective type. ※If short-circuit the control output terminal or supply current over the rated specification, normal control signal is not output due to the output short over current protection circuit. Installation and Sensitivity Adjustment Install the sensor to the desired place and check the connections. Supply the power to the sensor and adjust the optical axis and the sensitivity as following. When using photoelectric sensors closely over two units, it may result in malfunction due to mutual interference. When installing the product, tighten the screw with a tightening torque of 0.39N.m for BRP and to 14.7N.m for BR. Diffuse reflective/Narrow beam reflective type 1. The sensitivity should be adjusted depending on a sensing target or mounting place. ※Be sure that it can be different by size, surface and gloss of target. ⓐ Optimal position ⓑ Photoelectric sensor Sensing target 2. Set the target at a position to be detected by the beam, then turn the sensitivity adjuster until position ⓐ where the operation indicator turns ON from min. position of the sensitivity adjuster. 3. Take the target out of the sensing area, then turn the sensitivity adjuster until position ⓑ where the operation indicator turns ON. If the indicator dose not turn ON, max. position is ⓑ. 4. Set the sensitivity adjuster at the center of two switching position ⓐ, ⓑ. A-106 MAX MIN SENS Cylindrical Type Through-beam type 1. Supply the power to the photoelectric sensor, after setting the emitter and the receiver facing each other. 2. Set the receiver in center of position in the middle of the operation range of indicator by adjusting the receiver or the emitter right and left, up and down. 3. After the adjustment, check the stability of operation putting the object at the optical axis. ※If the sensing target is translucent body or smaller than Ø15, it can be missed by sensor cause light penetrate it. Adjust Right/Left Emitter Receiver Reflectivity by Reflective Tape Model MST-50-10 (50×50mm) 80% MST-100-5 (100×100mm) 120% MST-200-2 (200×200mm) 140% SENSORS CONTROLLERS ※This reflectivity is based on the reflector (MS-2). ※Reflectivity may vary depending on usage environment and installation conditions. The sensing distance and minimum sensing target size increase as the size of the tape increases. Please check the reflectivity before using reflective tapes. ※For using reflective tape, installation distance should be min. 20mm. MOTION DEVICES SOFTWARE Adjust Up/Down (A) Photoelectric Sensors Retroreflective type 1. Supply the power to the photoelectric sensor, after setting the photoelectric sensor and the reflector (MS-2) or reflective tape face to face. 2. Set the photoelectric sensor in the position which indicator turns on, as adjusting the reflector or the sensor right and left, up and down. 3. Fix both units tightly after checking that the unit detects the target. Adjust Right/Left (C) LiDAR (D) Door/Area Sensors (E) Vision Sensors Reflector (MS-2) Reflective tape (MST Series) Optical axis Photoelectric sensor (B) Fiber Optic Sensors (F) Proximity Sensors (G) Pressure Sensors Adjust Up/Down (H) Rotary Encoders ※If using more than 2 photoelectric sensors in parallel, the space among them should be more than 30cm. ※If reflectance of target is higher than non-glossy white paper, it might cause malfunction by reflection from the target when the target is near to photoelectric sensor. Therefore put enough space between the target and the photoelectric sensor or the surface of the target should be installed at angle of 30 to 45° against optical axis. (when a sensing target with high reflectance near by, photoelectric sensing with the polarizing filter should be used.) ※Sensitivity adjustment: R  efer to the diffuse reflective/ narrow beam reflective type’s. (I) Connectors/ Connector Cables/ Sensor Distribution Boxes/ Sockets 30 to 45° L Sensing target ※If the mounting place is too narrow, please use MS-4 instead of MS-2. ※Please use reflective tape (MST Series) for where a reflector is not installed. Reflector (MS-2) Reflective tape (MST Series) A-107
BRP200-DDTN 价格&库存
很抱歉,暂时无法提供与“BRP200-DDTN”相匹配的价格&库存,您可以联系我们找货
