BUP-50S-P
BUP-50S-P
    INDUSTRIALEMART
    SENSOR THROUGH-BEAM 50MM PNP
BUP-50S-P 数据手册
BUP Series Reinforced Plastic Case U-shaped Type Features SENSORS ● Improved noise resistance to disturbance light ● Max. 1ms high speed response type ● Built-in reverse polarity protection circuit and output short overcurrent protection circuit ● Light ON / Dark ON Selectable by control wire ● Protection structure IP66 (IEC standard) : BUP-30, BUP-50 CONTROLLERS MOTION DEVICES SOFTWARE Please read “Safety Considerations” in the instruction manual before using. Specifications BUP-30S BUP-50 BUP-50S NPN open collector output BUP-30 BUP-30S-P BUP-50-P BUP-50S-P PNP open collector output BUP-30-P Sensing type Through-beam Opaque materials of min. Opaque materials of min. Opaque materials of min. Opaque materials of min. Sensing target Ø4mm Ø1.5mm Ø4mm Ø1.5mm Operation mode Selectable Light ON or Dark ON by control wire Sensing distance 30mm 50mm Response speed Max. 1ms Power supply 12-24VDC ±10% (ripple P-P: max. 10%) Current consumption Max. 30mA Light source Infrared LED (940nm) Sensitivity adjustment Fixed Sensitivity adjuster Fixed Sensitivity adjuster NPN or PNP open collector output Control output ●Load voltage: max. 30VDC ●Load current: max. 200mA ●Residual voltage - NPN: max. 1VDC , PNP: max. 2.5VDC Protection circuit Reverse polarity protection circuit, output short overcurrent protection circuit Indication Power indicator: green LED, operation indicator: red LED Insulation resistance Over 20MΩ (at 500VDC megger) Noise immunity ±240V the square wave noise (pulse width: 1㎲) by the noise simulator Dielectric strength 1,000VAC 50/60Hz for 1 minute Vibration 1.5mm amplitude at frequency of 10 to 55Hz (for 1 min) in each X, Y, Z direction for 2 hours Shock 500m/s² (approx. 50G) in each X, Y, Z direction for 3 times Ambient illumination Sunlight: max. 11,000lx, incandescent lamp: max. 3,000lx (receiving illumination) Environment Ambient temperature -25 to 65℃[BUP-30S (-P) & BUP-50S (-P): -10 to 60℃], storage: -25 to 70℃ Ambient humidity 35 to 85%RH, storage: 35 to 85%RH Protection structure IP66 (IEC standard) IP50 (IEC standard) IP66 (IEC standard) IP50 (IEC standard) Material Case: acrylonitrile butadiene styrene, cap: polycarbonate Ø4mm, 4-wire, 2m Cable (AWG22, core diameter: 0.08mm, number of cores: 60, insulation out diameter: Ø1.25mm) Accessory Adjuster driver Adjuster driver Approval Unit weight Approx. 90g Approx. 140g Model ※The temperature or humidity mentioned in Environment indicates a non freezing or condensation environment. Operation Mode Operation mode Receiver operation Operation indicator (red LED) Transistor output Light ON Received light Interrupted light ON OFF ON OFF Dark ON Received light Interrupted light ON OFF ON OFF A-125 (A) Photoelectric Sensors (B) Fiber Optic Sensors (C) LiDAR (D) Door/Area Sensors (E) Vision Sensors (F) Proximity Sensors (G) Pressure Sensors (H) Rotary Encoders (I) Connectors/ Connector Cables/ Sensor Distribution Boxes/ Sockets BUP Series Control Output Diagram ● NPN open collector output ● PNP open collector output Photoelectric sensor circuit Photoelectric sensor circuit Connection Connection (brown)+V (brown)+V Load Main circuit (black) Output + Max. 200mA Output short overcurrent protection circuit 1.5Ω - (blue)0V 12-24VDC Main circuit Light ON Output short overcurrent protection circuit Light ON 1.5Ω Max. 200mA (black) Output Load (blue)0V Dark ON + - 12-24VDC Dark ON (white) Control (white) Control ※Select Light ON / Dark ON by control wire. - Light ON: Connect control wire to +V / Dark ON: Connect control wire to 0V ※If short-circuit the control output terminal or supply current over the rated specification, normal control signal is not output due to the output short over current protection circuit. Dimensions (unit: mm) Sensitivity adjuster (BUP-30S(-P)) Operation indicator (red) 11 14.3 Sensitivity adjuster (BUP-50S(-P)) Optical axis Operation indicator (red) 36 Power indicator (green) 78.5 50 Optical axis 6 6 26.8 26.9 72 Power indicator (green) 40 2-Ø6.4 6 11.2 16 Ø4, 2m 66 32 2-M5 Connections 11.2 2-M8 Mounting and Sensitivity Adjustment Light ON / Dark ON (brown)+V ※1 Load (black) Output Light ON + - 12-24VDC ※2 Load (blue)0V (white) Control ※1: Load connection for NPN open collector output ※2: Load connection for PNP open collector output A-126 2-Ø6.4 Ø4, 2m 9.2 20.2 6 14.3 9.2 20.2 52 30 ● BUP-50, BUP-50-P, BUP-50S, BUP-50S-P 41.6 78.1 ● BUP-30, BUP-30-P, BUP-30S, BUP-30S-P Dark ON Check the position where the photoelectric sensor will be used and the connection then supply the power and set sensitivity as below. ※BUP-30 - : When installing the product, tighten the screw with a tightening torque of 1.96N.m. BUP-50 - : When installing the product, tighten the screw with a tightening torque of 4.9N.m. ● Sensitivity adjustment When placing a target within ● BUP-30S, BUP-30S-P sensing range of sensor, turn BUP-50S, BUP-50S-P the sensitivity adjuster from Sensing area B Optimal the minimum position and position A check the position ‘A’ where the operation indicator is turned on Non sensing area (dark on) or turned off (light on). Min. Max. C Turn the sensitivity adjuster to ‘B’ in the middle between ‘A’ and ‘C’ which is the maximum sensitivity position, this will be the optimal sensitivity position. (the operation indicator can be operated at the lowest sensitivity position.)
BUP-50S-P 价格&库存
很抱歉,暂时无法提供与“BUP-50S-P”相匹配的价格&库存,您可以联系我们找货
