MMF326346
MMF326346
    MICRO-MEASUREMENTS
    MULTI PACK (5 2GRAMS)
MMF326346 数据手册
M-Bond 200 Strain Gage Gage Adhesive Strain Adhesive OTHER ACCESSORIES USED IN AN M-BOND 200 INSTALLATION: • CSM Degreaser or GC-6 Isopropyl Alcohol • Silicon Carbide Paper • M-Prep Conditioner A • M-Prep Neutralizer 5A • GSP-1 Gauze Sponges • CSP-1 Cotton Applicators • PCT-2M Gage Installation Tape DESCRIPTION For routine experimental stress analysis applications under temperate environmental conditions, M-Bond 200 adhesive is ordinarily the best choice. This adhesive is very easy to handle, and cures almost instantly to produce an essentially creep-free, fatigue-resistant bond, with elongation capability of five percent or more. M-Bond 200 is a cyanoacrylate that has been pretested and certified for use in bonding strain gages. It is an excellent general-purpose adhesive for laboratory and short-term field applications. The procedure for making a strain gage installation with M-Bond 200 is illustrated and described in detail in Instruction Bulletin B-127 included in each kit of adhesive. The user should note that the performance of the adhesive can be degraded by the effects of time, humidity conditions, elevated temperature, and moisture absorption. Because of the latter effect, strain gage installations should always be covered with a suitable protective coating. When necessitated by more rigorous test requirements and/or environmental conditions, consideration should be given to one of the M-Bond epoxy adhesives, using the “Recommended Adhesives/ Strain Gage Series” chart. CHARACTERISTICS PARAMETER DETAILS CURE REQUIREMENTS* One-minute thumb pressure, followed by a minimum two-minute delay before tape removal. Bond strength increases rapidly during first five minutes. Cure time must be extended under conditions of low temperature [
MMF326346 价格&库存
很抱歉,暂时无法提供与“MMF326346”相匹配的价格&库存,您可以联系我们找货
