SCD-PRO-4GVZSD
SCD-PRO-4GVZSD
    SENSAPHONE(Sensaphone)
    SENSAPHONE SENTINEL PRO CELLULAR
SCD-PRO-4GVZSD 数据手册
Sentinel Pro Technical Specifications alarM notIFIcatIon MEtHodS: E-Mail, Text Messages, Voice Phone Calls Programmable alarm escalation levels Comprehensive scheduling per input, profile, and alarm destination Unlimited number of User Profiles Multiple contact types per user data loGGInG: Unlimited samples securely stored on the Sentinel servers Programmable sampling Interval - 5 min to 24 hrs User programmable channel selection BattErY BacKuP: 4.8V 2000mAHr NiMh Battery pack (included) InPutS: 12 Universal Inputs • Normally Open / Normally Closed Dry Contact • 2.8K / 10K Thermistor 12V 3000 mAHR SLA Battery (included) Provides 8 hours of backup local IndIcatorS: • 4-20mA Current Loop 12 Alarm Status LEDs • Pulse Count • Power LED • Online LED • 12 Bit Resolution • Standby LED • Ethernet link and Activity LEDs ModBuS: • Modbus RTU via RS485 • Up to 64 registers tEMPEraturE SEnSInG ranGE: -109° to 168°F | -85° to 76°C rElaY outPut: 2 programmable relay outputs Rated for 1A 30VAC/ 1A 30VDC cEllular coMMunIcatIon : 4G Cellular Modem for use on Verizon, AT&T or Rogers PoWEr rEQuIrEMEntS: Power Requirement: 12-24DC • Comes with 12VDC plug-in power supply • International power options available Current Draw: 300mA at 24VDC EnVIronMEntal: Operating Humidity: 0-90% RH, non–condensing Operating Temperature: 32° to 122°F | 0° to 50°C PHYSIcal: Dimensions: 12.5 x 12.2 x 7.0” | 318 x 310 x 178mm Weight: 10.5lbs. | 4.7kg Continued on back Standards: FCC Part 15 – Class A Compliant Enclosure: NEMA 4X rated plastic weatherproof enclosure Antenna: 2G/3G/4G Frequencies: 698-960/1710-2700MHz Peak gain: 5dBi Pattern: Omni-directional Height: 6.45” (164mm) Diameter: 1.90” (48mm) IP Rating: IP-66 901 Tryens Road • Aston, PA 19014 • PH: 877-373-2700 • F: 610-558-0222 • www.sensaphone.com
SCD-PRO-4GVZSD 价格&库存
很抱歉,暂时无法提供与“SCD-PRO-4GVZSD”相匹配的价格&库存,您可以联系我们找货
