SRBC-CA3-YR90-MW-22A-1W-C2P20
    FESTO(费斯托)
    SENSOR BOX
SRBC-CA3-YR90-MW-22A-1W-C2P20 数据手册
Sensor box SRBC-CA3-YR90-MW-22A-1W-C2P20 Part number: 3482805 Data sheet Feature Value Certification c CSA us (OL) CE marking (see declaration of conformity) As per EU low voltage directive As per EU RoHS directive KC characters KC EMC Note on materials RoHS-compliant Safety integrity level (SIL) SIL 2 Measuring principle Mechanical/electrical Ambient temperature -20 °C ... 80 °C Switching output Contact-based Switching element function Toggle switch, single-pin Max. output current AC 3000 mA Max. output current DC 3000 mA Operating voltage range AC 0 V ... 250 V DC operating voltage range 0 V ... 30 V Electrical connection Screw terminal Closable nominal conductor cross-section 0.25 mm² ... 2.5 mm² Cable fitting M20x1.5 Approved cable diameter 5 mm ... 13 mm Type of mounting On flange as per ISO 5211 With mounting bracket Connection for valve positioner and position sensor conforms to standard VDI/VDE 3845 size AA 1 Mounting position Any Product weight 800 g Housing colour Gray Housing material Die-cast aluminum Seals material NBR Shaft material High-alloy stainless steel Material of screws High-alloy stainless steel Blanking plug material PA Material of mounting bracket High-alloy stainless steel Pointer material PC Material for cable connector PA Circlip material High-alloy stainless steel Disc material High-alloy stainless steel Cover cap material PC 12/16/21 - Subject to change - Festo AG & Co. KG 1/2 Feature Value Position indicator Yellow/red Angle detection setting range 0 deg ... 90 deg Storage temperature -20 °C ... 50 °C Degree of protection IP67 NEMA 4/4X Shock resistance Shock test with severity level 2 as per FN 942017-5 and EN 60068-2-27 Vibration resistance Transport application test with severity level 2 as per FN 942017-4 and EN 60068-2-6 LABS conformity VDMA24364 zone III Contamination level 3 12/16/21 - Subject to change - Festo AG & Co. KG 2/2
SRBC-CA3-YR90-MW-22A-1W-C2P20 价格&库存
很抱歉,暂时无法提供与“SRBC-CA3-YR90-MW-22A-1W-C2P20”相匹配的价格&库存,您可以联系我们找货
  • 1+967.726811+125.20130
库存:4
库存:10
