MH 01-M18
MH 01-M18
    PEPPERL+FUCHS(倍加福)
    M18 DIA MOUNTING BRACKET
MH 01-M18 数据手册
Mounting aid MH 01-M18 < Suitable for M18 sensors < Simple and fast mounting Mounting brackets for sensors Dimensions 34 20 28 ∅18.5 13 66.5 20 34 3 ∅12 4 Release date: 2020-06-15 Date of issue: 2020-06-29 Filename: 096532_eng.pdf Technical Data General specifications Inside diameter 18 mm Mechanical specifications Material Clamping cylinder: Diecast zinc Support bracket: Steel Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1 Mounting aid MH 01-M18 Mounting 1 3 2 (a) (c) (d) (b) (b) (b) Attach the mounting bracket (d) and then Tighten the screw fully tighten the screw (b) in after the sensor has been such a way that the mounted and aligned. bracket can still be turned. Release date: 2020-06-15 Date of issue: 2020-06-29 Filename: 096532_eng.pdf Fasten the two parts of the mounting clamp (a) loosely by means of the screw (b) and the nut (c) supplied. Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com fa-info@de.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 2
MH 01-M18 价格&库存
很抱歉,暂时无法提供与“MH 01-M18”相匹配的价格&库存,您可以联系我们找货
