FGD-W600
FGD-W600
    SENSAPHONE(Sensaphone)
    SENSAPHONE WEB600
FGD-W600 数据手册
WEB600 Technical Specifications ALERT ZONES COMMUNICATION TYPES: Number of Zones: 6 E-Mail – SMTP Zone Connector: terminal block Text Messages Zone Types: N.O./N.C. contact, 2.8K Thermistor ( -109° to 115ºF, -85º to 57ºC) 10K Thermistor (-87° to 168°F; -66° to 76°C) 4-20mA (-80,000.0 to 80,000.0 Web page – Supported formats HTTP, and XML SNMP – MIB with Traps, GET, GETNEXT, and SET Zone Characteristics: 28.7KΩ to 3.3V (temperature/contact) or 250 Ohms to ground (4-20mA) Ethernet 10/100 Base–T A/D Converter Resolution: 12 bits ±2 LSB Zone Protection: 5.5VDC Metal Oxide Varistor with fast acting diode clamps RELAY OUTPUT Rated for 1A 30VAC/ 1A 30VDC Maximum DATA LOGGING 100,000 Samples (all samples include data date and time) 1 second to 1 month sampling rate User programmable channel selection Zones 1 – 6 Battery Input Power LED INDICATORS Power On: On steady when the unit is powered on MODBUS®/TCP Slave Conformance Class 0 and 1 POWER SUPPLY Power Supply: 120VAC 50/60Hz / 5VDC 6W wall plug-in transformer w/6’ cord Power Consumption: 2 Watts Power Protection: Metal Oxide Varistor Battery Backup: Optional 2hr battery backup module (Part #FGD-W610-B) ENVIRONMENTAL Operating Temperature: 32° to 122°F | 0° to 50°C Operating Humidity: 0 to 90% RH non-condensing Storage Temperature: 32° to 140°F | 0° to 60°C PHYSICAL Alarm: Off when no alarm exists. Dimensions: 1.4” x 5.5” x 3.7” | 36 x 140 x 94mm Ethernet Link and Activity LEDs Weight: 1.5 lbs. | 6.8kg 901 Tryens Road • Aston, PA 19014 • PH: 877-373-2700 • F: 610-558-0222 • www.sensaphone.com Enclosure: Indoor-rated plastic housing suitable for wall or desktop installation.
FGD-W600 价格&库存
很抱歉,暂时无法提供与“FGD-W600”相匹配的价格&库存,您可以联系我们找货
