FGD-6700
FGD-6700
    SENSAPHONE(Sensaphone)
    SENSAPHONE EXPRESS II
FGD-6700 数据手册
Sensaphone Express II Technical Specifications Input Zones Phone Interface Number of Zones: 8 standard | Expandable to 40 Line RJ11 Terminal: For connection to a twowire analog telephone line. Zone Connector: terminal block Phone Line Protection: Metal Oxide Varistor & self-resetting fuse Zone Types: N.O./N.C. contact, 2.8K Thermistor (-65.0° to 93.3°C, -85° F to 200° F), 10K Thermistor (-62.2° C to 148.9° C, -80° F to 300° F), 4-20mA (-10,000.0 to 10,000.0) Zone Characteristics: 6.3KΩ to 5V (temperature/contact) or 237 Ohms to ground (4-20mA) A/D Converter Resolution: 12 bits ±2 LSB Zone Protection: Fast acting diode clamps Relay Output Rated for 2A 120VAC/ 2A 24VDC Maximum. Programmable for manual or automatic switching LED Indicators Input Slot 1-8 Standard, 9-40 Optional Microphone Environmental Operating Temperature: 32° to 120°F | 0° to 50°C Operating Humidity: 0 to 90% RH non-condensing Storage Temperature: 32° to 130°F | 0° to 60°C Physical Dimensions: 14.5 x 13 x 8.5” | 368 x 330 x 216mm Weight: 19.5 lbs. | 8.8kg Enclosure: NEMA-4 rated housing with latched window cover. External: For listening in to on-site sounds and high sound level alarms • Mic Connector: terminal block Power Supply Power Supply: 90-264VAC 50/60Hz / 12VDC 2A Power Supply w/6’ cord Power Protection: Metal Oxide Varistor Battery Backup: 12V 3AH sealed gel cell, provides up to 12 hours of battery backup. 901 Tryens Road • Aston, PA 19014 • PH: 877-373-2700 • F: 610-558-0222 • www.sensaphone.com
FGD-6700 价格&库存
很抱歉,暂时无法提供与“FGD-6700”相匹配的价格&库存,您可以联系我们找货
