12317
12317
    ALLIEDVISION
    CABLE CSI-2 220MM
12317 数据手册
DATA SHEET Product code 12317 MIPI CSI-2 FPC cable 220 mm V1.0.0 2019-May-29 Connecting Alvium CSI-2 cameras to embedded board adapters NOTICE Malfunctions and short circuits by damaged cables and connectors Provide sufficient strain relief for all cable connections. i Accessories information For embedded board adapters, see https://www.alliedvision.com/en/products/ accessories. For the Alvium Cameras Accessory Guide, see https://www.alliedvision.com/en/ support/technical-documentation/alvium-documentation.html. Dimensions Connector Connector Connector thickness 11.5 mm 12.65 mm Length Connection direction The arrow print indicates the direction between camera and host (embedded board) to prevent short circuits by reverse polarity, destroying the camera or the embedded board. Page 1 of 2 MIPI CSI-2 FPC cable 220 mm Specifications Feature Specification Length × width [mm] (220 ± 0.1) × (11.5 ± 0.1) Connector thickness [mm] 0.3 ± 0.03 Cable thickness [mm] ~ 0.2 Static bending radius (min.) 10.0 mm Dynamic bending radius (min.) For static applications only Bending cycles (max.) 300 Differential impedance ZDiff 100 Ω Shielding Impedance controlled (100 Ω) Number of connectors 22 Connector pitch 0.5 mm Compatible connector Hirose FH55-22S-0.5SH Supported devices Alvium CSI-2 cameras, Allied Vision embedded board adapters Operating temperature range +5 °C to +65 °C Regulations 2011/65/EU, incl. amendment 2015/863/EU (RoHS), China RoHS, REACH Allied Vision Technologies GmbH, Taschenweg 2a, D-07646 Stadtroda, Germany info@alliedvision.com, https://www.alliedvision.com Page 2 of 2 © Allied Vision 2019
12317 价格&库存
很抱歉,暂时无法提供与“12317”相匹配的价格&库存,您可以联系我们找货
    库存:201
