S15L In-Line Sensor Status Indicator
Datasheet
Bright indication of sensor power and output status
Two colors - one for power and one for sensor output status
Rugged over-molded design meets IEC IP66, IEC IP67, and IEC IP68
Connected directly to a sensor or anywhere in-line for easy visual indication
Models available with PNP or NPN inputs
Models
Power ON
(Color 1)
Models
Input Active
(Color 2)
S15LGYPQ
Input Type
PNP
Yellow
S15LGYNQ
NPN
Green
S15LGRPQ
PNP
Red
S15LGRNQ
S15LRGPQ
Red
S15LYGPQ
Yellow
Connection
4-Pin Male/Female M12 quick disconnect
NPN
Green
PNP
Wiring Diagrams
Male
Female
1
2
4
3
1
4
2
3
Pin
Wire Color
Description*
1
Brown
10 V DC to 30 V DC: Power LED will be ON (Color 1)
2
White
Not used; Passes through
3
Blue
DC Common
4
Black
Input from sensor: Color 2 overrides Color 1 when active
*Continuity between male and female connection for all four wires, including IO-link communications.
Specifications
Supply Voltage
10 V DC to 30 V DC at 15 mA maximum
Supply Protection Circuitry
Protected against reverse polarity and transient voltages
Leakage Current Immunity
400 µA
Indicators
2 colors
Connections
Integral male/female 4-pin M12 quick disconnect
Construction
Coupling Material: Nickel-plated brass
Connector Body: PUR translucent white
Vibration and Mechanical Shock
Meets IEC 60068-2-6 requirements (Vibration: 10 Hz to 55 Hz, 0.5 mm amplitude, 5
minutes sweep, 30 minutes dwell)
Meets IEC 60068-2-27 requirements (Shock: 15G 11 ms duration, half sine wave)
Certifications
Environmental Rating
IP66, IP67, IP68
NEMA/UL Type 1
Operating Conditions
Temperature: –40 °C to +50 °C (–40 °F to +122 °F)
90% at +50 °C maximum relative humidity (non-condensing)
Storage Temperature: –40 °C to +70 °C (–40 °F to +158 °F)
Required Overcurrent Protection
WARNING: Electrical connections must be made by
qualified personnel in accordance with local and
national electrical codes and regulations.
Overcurrent protection is required to be provided by end product application per the
supplied table.
Overcurrent protection may be provided with external fusing or via Current Limiting,
Class 2 Power Supply.
Supply wiring leads < 24 AWG shall not be spliced.
For additional product support, go to www.bannerengineering.com.
Supply Wiring (AWG)
Required Overcurrent Protection (Amps)
22
3.0
24
2.0
26
1.0
28
0.8
30
0.5
Safety: The S15L Indicator design and
PCB composition were evaluated and
approved for use with the Banner 4-pin
or 5-pin M12 safety products.
40 °C (104 °F) maximum
operating temperature for
applications requiring UL
Original Document
212217 Rev. I
8 December 2021
212217
Dimensions
All measurements are listed in millimeters [inches], unless noted otherwise.
57.8
[2.27]
27.9
[1.1]
15.0
[0.59]
M12 X 1 - 6H
M12 X 1 - 6g
Accessories
Cordsets
4-Pin Threaded M12 Cordsets—Single Ended
Model
Length
Style
MQDC-406
2 m (6.56 ft)
MQDC-415
5 m (16.4 ft)
MQDC-430
9 m (29.5 ft)
MQDC-450
15 m (49.2 ft)
MQDC-406RA
2 m (6.56 ft)
MQDC-415RA
5 m (16.4 ft)
MQDC-430RA
9 m (29.5 ft)
Dimensions
44 Typ.
1
Straight
32 Typ.
[1.26"]
2
30 Typ.
[1.18"]
2
3
4
M12 x 1
ø 14.5
Right-Angle
MQDC-450RA
Pinout (Female)
1
1 = Brown
2 = White
3 = Blue
4 = Black
3
4
15 m (49.2 ft)
M12 x 1
ø 14.5 [0.57"]
4-Pin Threaded M12 Cordsets—Double Ended
Model
Length
MQDEC-401SS
0.31 m (1 ft)
MQDEC-403SS
0.91 m (2.99 ft)
MQDEC-406SS
1.83 m (6 ft)
MQDEC-412SS
3.66 m (12 ft)
MQDEC-420SS
6.10 m (20 ft)
MQDEC-430SS
9.14 m (30.2 ft)
Style
2
15.2 m (49.9 ft)
Pinout
Female
40 Typ.
[1.58"]
2
1
3
4
Male Straight/Female
Straight
MQDEC-450SS
Dimensions
M12 x 1
ø 14.5 [0.57"]
44 Typ.
[1.73"]
M12 x 1
ø 14.5 [0.57"]
www.bannerengineering.com - Tel: + 1 888 373 6767
Male
2
3
1
4
1 = Brown
2 = White
3 = Blue
4 = Black
P/N 212217 Rev. I
3-pin Threaded M8 to 4-pin Threaded M12 Cordsets—Double Ended
Model
Length
Style
Dimensions
Pinout (Female)
ø 9.5
35 mm
max.
PKG3M-.5-MQDCM410
0.15 m (0.49 ft)
Female Straight/
Male Straight
M8 x 1
4
2
1
3
40 mm
max.
ø 14.5
M12 x 1
Pinout (Male)
3
1
4
1 = Brown
2 = No connection
3 = Blue
4 = Black
1 = Brown
3 = Blue
4 = Black
Brackets
LMBM12MAG
• Attaches to M12 cordset end
• Black polypropylene
• 11.8 kg (26 lb) pull force
• One piece
10
Ø7.5
LMBM12SP
• Supplied with thread forming hardware
• Pack of seven
Ø8
12
19
Ø10
Ø19
LMBS15MAG
• Attaches to S15 housing
• White polypropylene
• One piece
15
Ø15
LMBS15SP
• Clearance for M5 or #10 hardware
• Pack of five
Ø 4.9
Ø 9.5
26.2
Ø 15.0
33
15.0
23.5
Ø19
Banner Engineering Corp. Limited Warranty
Banner Engineering Corp. warrants its products to be free from defects in material and workmanship for one year following the date of shipment. Banner Engineering Corp. will repair or replace, free of charge,
any product of its manufacture which, at the time it is returned to the factory, is found to have been defective during the warranty period. This warranty does not cover damage or liability for misuse, abuse, or the
improper application or installation of the Banner product.
THIS LIMITED WARRANTY IS EXCLUSIVE AND IN LIEU OF ALL OTHER WARRANTIES WHETHER EXPRESS OR IMPLIED (INCLUDING, WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY OR
FITNESS FOR A PARTICULAR PURPOSE), AND WHETHER ARISING UNDER COURSE OF PERFORMANCE, COURSE OF DEALING OR TRADE USAGE.
This Warranty is exclusive and limited to repair or, at the discretion of Banner Engineering Corp., replacement. IN NO EVENT SHALL BANNER ENGINEERING CORP. BE LIABLE TO BUYER OR ANY OTHER
PERSON OR ENTITY FOR ANY EXTRA COSTS, EXPENSES, LOSSES, LOSS OF PROFITS, OR ANY INCIDENTAL, CONSEQUENTIAL OR SPECIAL DAMAGES RESULTING FROM ANY PRODUCT DEFECT OR
FROM THE USE OR INABILITY TO USE THE PRODUCT, WHETHER ARISING IN CONTRACT OR WARRANTY, STATUTE, TORT, STRICT LIABILITY, NEGLIGENCE, OR OTHERWISE.
Banner Engineering Corp. reserves the right to change, modify or improve the design of the product without assuming any obligations or liabilities relating to any product previously manufactured by Banner
Engineering Corp. Any misuse, abuse, or improper application or installation of this product or use of the product for personal protection applications when the product is identified as not intended for such
purposes will void the product warranty. Any modifications to this product without prior express approval by Banner Engineering Corp will void the product warranties. All specifications published in this
document are subject to change; Banner reserves the right to modify product specifications or update documentation at any time. Specifications and product information in English supersede that which is
provided in any other language. For the most recent version of any documentation, refer to: www.bannerengineering.com.
For patent information, see www.bannerengineering.com/patents.
Banner Engineering Corp. All rights reserved
很抱歉,暂时无法提供与“S15LGYNQ”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+397.172601+50.98184
