SCTL55
SCTL55
    CARLOGAVAZZI
    IO LINK SMART CONFIGURATOR
SCTL55 数据手册
CARLO GAVAZZI Au t o m a t i o n C o m p o n e n t s SCTL55 - Smart configurator SCTL55 Smart configurator for IO-Link sensors The SCTL55 is the Industry 4.0 portable, self-powered and user friendly smart configurator for IO-Link sensors, which accesses the sensor data and manages its parameters. With the SCTL55 smart configurator you can modify and optimize your sensor very quickly and use available data to improve your processes and predictive maintenance. Through a 5.5” HD touchscreen display and dedicated Apps you can access advanced diagnostics, showing operating hours, number of detections, operating cycles and alarms. There is no need for a PC and dedicated software. Industry 4.0 is now in your hands Powerful configuration • Plug your sensor to one of the three connectors or by using the dedicated accessory for cable version • If IODD file is not present in the internal memory, the SCTL55 will automatically download it, through Wi-Fi and it will display all sensor data in an instant. • Quickly change any parameter without the need to read the sensor documentation • Easy management of configuration files via the internal memory or external micro SD card User friendly • 5.5” HD touchscreen display • Dedicated app with quick access to sensor data and easy management of parameters • Intuitive GUI that allows easy control of your sensor even for the more complex ones LED indication • 5 LEDs to verify the main battery status • Additional LEDs for device information: Power, IO-Link, Error, SIO2 and USB CARLO GAVAZZI Automation Components. Specifications are subject to change without notice. Illustrations are for example only. Structure M8 4-wire M12 M8 3-wire LED of the battery charge level LED of the configurator status Battery status Power 5.5” HD touchscreen display Micro SD card port Micro USB port Benefits Full mobility • Handheld portable device with no need for power or laptop with dedicated software • Self-powered thanks to the built-in high capacity LI-ION rechargeable battery • 5 hours duration in full operation with the sensor connected and 22 hours with the screen off • Possibility to use a battery pack to recharge the device via the micro USB port • Lanyard or clip belt for easy transportation Advanced sensor diagnostics for small to large scale applications • Connect the sensor directly from the machine, inside the application • Check parameters, operating hours, number of detections, operating cycles and alarms • Verify sensor status with current temperature, quality of run, frequency detection • Adjust and fine tune the parameters to get the best out of your sensor for the specific application Troubleshooting • Read the relevant process data and sensor status • Check the number of detection, maximum and minimum temperature since start up, actual temperature and quality of run CARLO GAVAZZI Automation Components. Specifications are subject to change without notice. Illustrations are for example only. M8 and ectors nn 2 plug co M1 CG inductive sensor connected Easy to configure CG capacitive sensor connected CARLO GAVAZZI Automation Components. Specifications are subject to change without notice. Illustrations are for example only. sensors for th cable wi Accessor y Wi-Fi Automatically download IODD files Mi tter y cap ba ity ac Hig h t or SD card p o r c ✔ Ready CARLO GAVAZZI Automation Components. Specifications are subject to change without notice. Illustrations are for example only. OUR SALES NETWORK IN EUROPE AUSTRIA Carlo Gavazzi GmbH Ketzergasse 374, A-1230 Wien Tel: +43 1 888 4112 Fax: +43 1 889 10 53 office@carlogavazzi.at FRANCE Carlo Gavazzi Sarl Zac de Paris Nord II, 69, rue de la Belle Etoile, F-95956 Roissy CDG Cedex Tel: +33 1 49 38 98 60 Fax: +33 1 48 63 27 43 french.team@carlogavazzi.fr ITALY Carlo Gavazzi SpA Via Milano 13, I-20020 Lainate Tel: +39 02 931 761 Fax: +39 02 931 763 01 info@gavazziacbu.it SPAIN Carlo Gavazzi SA Avda. Iparraguirre, 80-82, E-48940 Leioa (Bizkaia) Tel: +34 94 480 4037 Fax: +34 94 431 6081 gavazzi@gavazzi.es BELGIUM Carlo Gavazzi NV/SA Mechelsesteenweg 311, B-1800 Vilvoorde Tel: +32 2 257 4120 Fax: +32 2 257 41 25 sales@carlogavazzi.be GERMANY Carlo Gavazzi GmbH Pfnorstr. 10-14 D-64293 Darmstadt Tel: +49 6151 81000 Fax: +49 6151 81 00 40 info@gavazzi.de NETHERLANDS Carlo Gavazzi BV Wijkermeerweg 23, NL-1948 NT Beverwijk Tel: +31 251 22 9345 Fax: +31 251 22 60 55 info@carlogavazzi.nl SWEDEN Carlo Gavazzi AB V:a Kyrkogatan 1, S-652 24 Karlstad Tel: +46 54 85 1125 Fax: +46 54 85 11 77 info@carlogavazzi.se DENMARK Carlo Gavazzi Handel A/S Over Hadstenvej 40, DK-8370 Hadsten Tel: +45 89 60 6100 Fax: +45 86 98 15 30 handel@gavazzi.dk GREAT BRITAIN Carlo Gavazzi UK Ltd 4.4 Frimley Business Park, Frimley, Camberley, Surrey GU16 7SG Tel: +44 1 276 854 110 Fax: +44 1 276 682 140 sales@carlogavazzi.co.uk NORWAY Carlo Gavazzi AS Melkeveien 13, N-3919 Porsgrunn Tel: +47 35 93 0800 Fax: +47 35 93 08 01 post@gavazzi.no SWITZERLAND Carlo Gavazzi AG Verkauf Schweiz/Vente Suisse Sumpfstrasse 3, CH-6312 Steinhausen Tel: +41 41 747 4535 Fax: +41 41 740 45 40 info@carlogavazzi.ch FINLAND Carlo Gavazzi OY AB Ahventie, 4 B FI-02170 Espoo Tel: +358 9 756 2000 myynti@gavazzi.fi PORTUGAL Carlo Gavazzi Lda Rua dos Jerónimos 38-B, P-1400-212 Lisboa Tel: +351 21 361 7060 Fax: +351 21 362 13 73 carlogavazzi@carlogavazzi.pt OUR SALES NETWORK IN THE AMERICAS USA Carlo Gavazzi Inc. 750 Hastings Lane, Buffalo Grove, IL 60089, USA Tel: +1 847 465 6100 Fax: +1 847 465 7373 sales@carlogavazzi.com CANADA Carlo Gavazzi Inc. 2660 Meadowvale Boulevard, Mississauga, ON L5N 6M6, Canada Tel: +1 905 542 0979 Fax: +1 905 542 22 48 gavazzi@carlogavazzi.com MEXICO Carlo Gavazzi Mexico S.A. de C.V. Circuito Puericultores 22, Ciudad Satelite Naucalpan de Juarez, Edo Mex. CP 53100 Mexico Tel +52 55 5373 7042 Fax +52 55 5373 7042 mexicosales@carlogavazzi.com BRAZIL Carlo Gavazzi Automação Ltda. Av. Francisco Matarazzo, 1752 Conj 2108 - Barra Funda - São Paulo/SP Tel: +55 11 3052 0832 Fax: +55 11 3057 1753 info@carlogavazzi.com.br OUR SALES NETWORK IN ASIA AND PACIFIC SINGAPORE Carlo Gavazzi Automation Singapore Pte. Ltd. 61 Tai Seng Avenue #05-06 Print Media Hub @ Paya Lebar iPark Singapore 534167 Tel: +65 67 466 990 Fax: +65 67 461 980 info@carlogavazzi.com.sg MALAYSIA Carlo Gavazzi Automation (M) SDN. BHD. D12-06-G, Block D12, Pusat Perdagangan Dana 1, Jalan PJU 1A/46, 47301 Petaling Jaya, Selangor, Malaysia. Tel: +60 3 7842 7299 Fax: +60 3 7842 7399 sales@gavazzi-asia.com CHINA Carlo Gavazzi Automation (China) Co. Ltd. Unit 2308, 23/F., News Building, Block 1,1002 Middle Shennan Zhong Road, Shenzhen, China Tel: +86 755 83699500 Fax: +86 755 83699300 sales@carlogavazzi.cn HONG KONG Carlo Gavazzi Automation Hong Kong Ltd. Unit 3 12/F Crown Industrial Bldg., 106 How Ming St., Kwun Tong, Kowloon, Hong Kong Tel: +852 23041228 Fax: +852 23443689 MALTA Carlo Gavazzi Ltd Zejtun ITALY Carlo Gavazzi Controls SpA Belluno CHINA Carlo Gavazzi Automation (Kunshan) Co., Ltd. Kunshan HEADQUARTERS Carlo Gavazzi Automation SpA Via Milano, 13 I-20020 - Lainate (MI) - ITALY Tel: +39 02 931 761 info@gavazziautomation.com Printed on 100% recycled paper produced using post consumer de-inked waste. www.gavazziautomation.com LITHUANIA Uab Carlo Gavazzi Industri Kaunas Kaunas 15029xxx BRO SCTL55 ENG 01/19 DENMARK Carlo Gavazzi Industri A/S Hadsten Specifications are subject to change without notice. Illustrations are for example only. OUR COMPETENCE CENTRES AND PRODUCTION SITES
SCTL55 价格&库存
很抱歉,暂时无法提供与“SCTL55”相匹配的价格&库存,您可以联系我们找货
