EXT050M16SS
EXT050M16SS
    SENSATA(森萨塔)
    M16 500MM LONG EXTENSION TUBE
EXT050M16SS 数据手册
Extension tubes for vertical float switches Extends the reach of vertical switches Polypropylene extensions with M12 or M16 thread SS 316L extensions with G1/8, G3/8 or M16 thread Cynergy3 Part Material Thread Extension length Gasket EXT025M12PP Polypropylene M12x1.75 EXT050M12PP Polypropylene M12x1.75 EXT075M12PP Polypropylene M12x1.75 250mm 500mm 750mm Nitrile Nitrile Nitrile EXT025M16PP Polypropylene EXT050M16PP Polypropylene EXT075M16PP Polypropylene M16x2 M16x2 M16x2 250mm 500mm 750mm Nitrile Nitrile Nitrile EXT025G18SS SS 316L EXT050G18SS SS 316L EXT075G1/8SS SS 316L EXT100G1/8SS SS316L G1/8 G1/8 G1/8 G1/8 250mm 500mm 750mm 1000mm Nitrile Nitrile Nitrile Nitrile EXT025G38SS SS 316L EXT050G38SS SS 316L EXT075G3/8SS SS 316L EXT100G3/8SS SS316L G3/8 G3/8 G3/8 G3/8 250mm 500mm 750mm 1000mm Nitrile Nitrile Nitrile Nitrile EXT025M16SS SS316L EXT050M16SS SS 316L M16x2 M16x2 250mm 500mm Nitrile Nitrile Custom versions can be made for particular applications. Please contact Cynergy3 with your requirements. A range of extension tubes available in Polypropylene or Stainless Steel (316L grade), which extend the reach of the various vertical float switches. The Polypropylene tubes, with either M12 or M16 threads, are intended for use with our plastic types of float switches and are available in 250mm, 500mm and 750mm lengths. Stainless steel extension tubes, with either 1/8BSP (G1/8), 3/8BSP (G3/8) or M16 threads, are intended for use with our stainless steel float switches and are available in lengths from 250mm to 1000mm. Outline dimensions for Polypropylene versions Extension Length Email:sales@cynergy3.com ISO9001 C E R T I F I E D 20 x 2.5 mm (0.79x0.1”) Wall 10mm (0.4”) 25mm (1.0”) SS Washer M12 x 1.5 M16 x 2 Gasket M12 x 1.5 M16 x 2 Outline dimensions for Stainless steel SS 316L versions Extension Length 25mm (0.98”) Cynergy3 Components Ltd. 7 Cobham Road Ferndown Industrial Estate Wimborne, Dorset BH21 7PE Telephone +44 (0) 1202 897969 16 x 2 mm (0.6x0.08”) Wall 25mm (1.0”) 10mm (0.4”) 5mm (0.2”) 19mm (0.75”) dia for G 1/8” version 25mm (1.0”) dia for G 3/8” version 25mm (0.1”) ¯25mm (1.0”) G 1/8" 20 mm (0.75”) Full Thread G 3/8" 20 mm (0.75”) Full Thread M16 x2 thread 1/2" x 18swg Gasket G 1/8" G 3/8” M16x2 www.cynergy3.com © 2014 Cynergy3 Components, All Rights Reserved. Specifications are subject to change without prior notice. Cynergy3 Components and the Cynergy3 Components logo are trademarks of Cynergy3 Components Limited.
EXT050M16SS 价格&库存
很抱歉,暂时无法提供与“EXT050M16SS”相匹配的价格&库存,您可以联系我们找货
