FCNMRP
FCNMRP
    SENSATA(森萨塔)
    CHAMBER SWITCH UNVENTED
FCNMRP 数据手册
FCNM Series Fluid Level switches cynergycomponents The switch is based on a simple principle of a float located inside an enclosed chamber, which follows the level of the liquid in the system. When the liquid level rises, the float magnet attracts and operates a 20A 250Vac microswitch with N/O and N/C contacts. Suitable for use in water or liquids of SG equal to or greater than 1. SPECIFICATION Material: Housing : Brass Float : Polypropylene 250Vac 20A 8 bar Fluid input 1/4" BSP/GAS Air vent 3-4mm flexible 0/55°C +32/+131°F 14mm 32mm Switching voltage max. Switching current max. resistive Max working pressure Pipe connections: Temperature Range Must Close Level (S.G.=1) Must Open Level (S.G.=1) • Level control in pipes • Prevention of Dry- running of centrifugal pumps • Level control in tanks • Level control in pressurised containers (autoclaves) must close 220 level must open 1 2 3 electric cable level cable retainer cable - entry 1/4 BSP 56 60 ISO 9001C E R T I F IED Cynergy3 Components Ltd 7 Cobham Road Ferndown Industrial Estate Wimborne Dorset BH21 7PE Tel: +44 (0) 1202 897969 sales@cynergy3.com www.cynergy3.com © 2013 Cynergy3 Components, All Rights Reserved. Specifications are subject to change without prior notice. Cynergy3 Components and the Cynergy3 Components logo are trademarks of Cynergy3 Components Limited. FCNM 2013 FCNM Series Fluid Level switches cynergycomponents INSTALLATION FCNMRP type applications - solution suitable both for pressurised tubing and for deprepressurised pipes and systems horizontal pipe level control suction control for peripheral pumps supplied from below vertical pipe control water air 1/4" autoclaves water / air level control spanner adjustable pipe wrench important for tightening suction control for peripheral pumps supplied from above FCNMAS type applications - solution suitable only for pressurised tubing automatic air vent valve must be installed vertically it operates with cap loosened by one turn vertical pipe control suction control for peripheral pumps supplied from above horizontal pipe level control ISO 9001C E R T I F IED www.cynergy3.com © 2013 Cynergy3 Components, All Rights Reserved. Specifications are subject to change without prior notice. Cynergy3 Components and the Cynergy3 Components logo are trademarks of Cynergy3 Components Limited.
FCNMRP 价格&库存
很抱歉,暂时无法提供与“FCNMRP”相匹配的价格&库存,您可以联系我们找货
推荐型号
