DT1200
Termination enclosure
Weatherproof to IP68
Machined aluminium casting
Mounting threads for terminal block
An enclosure which can be used with the Cynergy3 range of vertically mounted float switches which have an M16 mounting thread.*
Machined from an aluminium casting, the termination enclosure is weatherproof to IP68 when fitted with the correct gland, and can be fitted
with a terminal block using the 3 x M4 mounting holes in the base.
*Note - the termination enclosure wall thickness is 5mm which will reduce the allowable maximum tank wall thickness accordingly.
45.0
16.0
Ø70.0
Ø28.0
16.0
M4 x 6 DEEP
M20 x 1.5
7.0
30.0
5.0
54.0
M4 x 6 DEEP ON 45 PCD CENTRES
Ø17.0
Cynergy3 Components Ltd.
7 Cobham Road
Ferndown Industrial Estate
Wimborne, Dorset BH21 7PE
Telephone +44 (0) 1202 897969
Email:sales@cynergy3.com
ISO9001 C E R T I F I E D
www.cynergy3.com
© 2014 Cynergy3 Components, All Rights Reserved. Specifications are subject to change without prior notice. Cynergy3 Components and the Cynergy3 Components logo are trademarks of Cynergy3 Components Limited.
很抱歉,暂时无法提供与“DT1200”相匹配的价格&库存,您可以联系我们找货
