FGD-1400-CD
FGD-1400-CD
    SENSAPHONE(Sensaphone)
    SENSAPHONE 1400
FGD-1400-CD 数据手册
Sensaphone 1400 & 1800 Technical Specifications INPUT ZONES Number of Zones: 1400 - 4, 1800 - 8 Zone Connector: terminal block Zone Types: N.O./N.C. contact, 2.8K Thermistor ( -109° to 115ºF, -85º to 57ºC ), 10K Thermistor (-87° to 168°F; -66° to 76°C), 4-20mA (-10,000.0 to 10,000.0 Zone Characteristics: 2.87KΩ to 3V (temperature/contact) or 250 Ohms to ground (4-20mA) A/D Converter Resolution: 10 bits ±2 LSB (1400) | 12 bits ±2 LSB (1800) RELAY OUTPUT Rated for 2A 120VAC/ 2A 24VDC Maximum. Programmable for manual or automatic switching LED INDICATORS Zone Alarms (4 or 8), Sound, Power, Battery OK, Phone in Use, Output On, System On MICROPHONE Internal: for recording custom voice messages External (optional): For listening in to on-site sounds and high sound level alarms • Mic Connector: terminal block POWER SUPPLY Power Supply: 120VAC 50/60Hz / 12V wall plug-in transformer w/6’ cord 1400 Battery Backup: 6V 1.3 AH sealed gel cell, provides up to 24 hours of battery backup. PHONE INTERFACE Line RJ11 Terminal: For connection to a twowire analog telephone line. Extension RJ11 Terminal w/ Line Seizure: For connecting other devices on the same telephone line, devices connected to this jack are disconnected in the event that the unit must dial out for an alarm. Phone Line Protection: Metal Oxide Varistor & self-resetting fuse ENVIRONMENTAL Operating Temperature: 32° to 122°F | 0° to 50°C Operating Humidity: 0–90% RH non-condensing Storage Temperature: 32° to 140°F | 0° to 60°C PHYSICAL 1400 Dimensions: 12.1 x 7.3 x 4.5” | 307 x 185 x 114mm 1400 Weight: 5 lbs. | 2.2kg 1800 Dimensions: 12.1”h x 8.0”w x 5.50” | 307 x 203 x 140mm 1800 Weight: 8 lbs. | 3.6kg Enclosure: NEMA-4 rated plastic housing Power Consumption: 5 Watts Power Protection: Metal Oxide Varistor 1800 Battery Backup: 6V 3 AH sealed gel cell, provides up to 24 hours of battery backup. 901 Tryens Road • Aston, PA 19014 • PH: 877-373-2700 • F: 610-558-0222 • www.sensaphone.com
FGD-1400-CD 价格&库存
很抱歉,暂时无法提供与“FGD-1400-CD”相匹配的价格&库存,您可以联系我们找货
