LC10FBS-PUR
LC10FBS-PUR
    SENSATA(森萨塔)
    M12-M12 4P STR PUR CBL SHTH 10M
LC10FBS-PUR 数据手册
M12 Cable Set Series Cables for sensors with M12 round connection 4 pole M12 connector to IEC61076-2-101 IP67 protection IEC 60529 (a3) Anti-vibration system Head temperature range -40 90ºC, with good resistance to oils Choice of PVC or PUR/PVC cable insulation Technical Specification Protection degree IEC 60529 (a3) Head temperature range ºC Cable temperature range ºC Housing oil resistance Housing material Contact material Locking nut material Conductor size IP67 -40 to 90 PVC -25 to 90 PUR -25 to 80 very good TPU (polyurethane) Gold over nickel plated CuZn Nickel plated Brass 4/0.34 mm2 Electrical Specification The LC cable series can be used with sensors that have M12 round connectors (IEC61076-2-101). These are supplied as standard with choice of PVC or PUR/PVC sheath insulated cables in lengths of 2, 5 and 10 metres and with either straight or elbow connector bodies. Voltage AC Max Voltage DC Max Current Max @40ºC Voltage drop @1A x 1M V V A V 250 250 4 0.13 Standard Parts Cable sheath Wire insulation Wire cores Body type LC02FBS-PVC LC05FBS-PVC LC10FBS-PVC LC02FBS-PUR LC05FBS-PUR LC10FBS-PUR LC02FBR-PVC LC05FBR-PVC LC10FBR-PVC LC02FBR-PUR LC05FBR-PUR LC10FBR-PUR PVC PVC PVC PUR PUR PUR PVC PVC PVC PUR PUR PUR PVC PVC PVC PVC PVC PVC PVC PVC PVC PVC PVC PVC Straight Straight Straight Straight Straight Straight Elbow Elbow Elbow Elbow Elbow Elbow 4/0.34 4/0.34 4/0.34 4/0.34 4/0.34 4/0.34 4/0.34 4/0.34 4/0.34 4/0.34 4/0.34 4/0.34 Length (m) 2 5 10 2 5 10 2 5 10 2 5 10 Custom versions can be made for particular applications. Please contact Cynergy3 with your requirements. Mechanical Dimensions Cynergy3 Components Ltd. 7 Cobham Road Ferndown Industrial Estate Wimborne, Dorset BH21 7PE Telephone +44 (0) 1202 897969 Email:sales@cynergy3.com ISO9001 C E R T I F I E D Pin 3 blue wire Pin 3 black wire 3 2 Pin 2 white wire 4 1 Pin 1 brown wire www.cynergy3.com © 2014 Cynergy3 Components, All Rights Reserved. Specifications are subject to change without prior notice. Cynergy3 Components and the Cynergy3 Components logo are trademarks of Cynergy3 Components Limited.
LC10FBS-PUR 价格&库存
很抱歉,暂时无法提供与“LC10FBS-PUR”相匹配的价格&库存,您可以联系我们找货
