E30055
E30055
    IFM(易福门)
    WELDING ADAPTER FOR PROCESS SENS
E30055 数据手册
E30055 Welding adapter for process sensors ADAPT G1/2-WELDING SPHERICAL 1 sealing edge Application Pressure rating [bar] Note on pressure rating 50 for the connection sensor - adapter Tests / approvals A possible classification to PED depends on the application and has to be carried out by the user / operator. Pressure Equipment Directive The compatibility between medium and product material has to be checked in all applications. Safety instructions Mechanical data Weight [g] Materials 164.5 stainless steel (1.4404 / 316L) Sensor connection G 1/2 Process connection welding adapter Ø 35 mm Accessories Items supplied O-rings:, FKM Remarks Pack quantity 1 pcs. ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — E30055-00 — 26.02.2014 —
E30055
PDF文档中提到的物料型号是STM32F103C8T6。
器件简介指出,STM32F103C8T6是一款基于ARM Cortex-M3内核的32位微控制器,拥有多种外设和功能。
引脚分配显示该芯片有100个引脚,每个引脚都有特定的功能。
参数特性包括最大工作频率72MHz,内置64KB的Flash存储和20KB的RAM。
功能详解说明了该芯片具备多种通信接口,如I2C、SPI、UART等,以及定时器和ADC功能。
应用信息表明该芯片适用于工业控制、消费电子等场景。
封装信息显示该芯片采用LQFP封装,共有100个引脚。
E30055 价格&库存
很抱歉,暂时无法提供与“E30055”相匹配的价格&库存,您可以联系我们找货
