OMH-RL2-S
OMH-RL2-S
    PEPPERL+FUCHS(倍加福)
    MOUNTING AID 360 ROTATION
OMH-RL2-S 数据手册
Mounting aid OMH-RL2-S < Mounting bracket < Adjustable Bracket < Protective functions Protective Shroud Bracket with 360° Rotating Half-Clamp Dimensions 37.8 27.6 70.2 85.7 56.3 49.3 16.2 ø7.9 43.8 211.6 96.8 28.5 28.5 47.0 62.0 22.1 20.0 ø5.3 (4 x) Tool access holes (4 x) 131 16.2 19.2 Release date: 2020-03-23 Date of issue: 2020-06-30 Filename: 904798_eng.pdf Mounting holes for half-clamp (3 x) 31.7 3.0 3/8"-16 Technical Data Mechanical specifications Material Stainless steel shroud, nickel-plated zinc half-clamp, xinc-plated steel screws and nuts Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1 Mounting aid OMH-RL2-S Mounting Instructions Model OMH-RL2-S is a protective shroud bracket for Series 28 and Series 29 photoelectric sensors. This model includes the following components (as shown in Figure 1, starting at the upper left and going clockwise). Half-clamp Mounting bolt with two nuts, two flat washers, and one lock washer Metal sensor shroud Two screws, two nuts, and two washers to mount sensor to shroud Figure 1 Sensor is attached to this side of bracket using screws & nuts Figure 2 Release date: 2020-03-23 Date of issue: 2020-06-30 Filename: 904798_eng.pdf (1.) To assemble, the sensor must be mounted inside the sensor shroud. Align the sensitivity adjustment poteniometer(s) of the sensor to the holes in the top of the shroud, as shown in Figure 3. Figure 3 (2.) Slide the two screws through the shroud and sensor with the two washers and two nuts on the outside of the shroud. Tighten Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com fa-info@de.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 2 Mounting aid OMH-RL2-S the screws in place so the sensor is securely mounted inside the shroud, as shown in Figures 4 and 5. Figure 4 Figure 5 Release date: 2020-03-23 Date of issue: 2020-06-30 Filename: 904798_eng.pdf (3.) Loosen the half-clamp and observe the grooved slot inside. Place the head of the mounting bolt into this groove, as indicated in Figure 6. Figure 6 (4.) Without tightening the half-clamp over the bolt head, squeeze the half-clamp together so the smaller protrusion at the end fits together, and place it into one of the three larger holes on the side of the shroud as shown in Figure 7 and 8. Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com fa-info@de.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 3 Mounting aid OMH-RL2-S Figure 7 Figure 8 (5.) Position and align the mounting bracket as desired, then tighten the half-clamp set screw to secure the assembly as shown in Figure 9. Figure 9 The OMH-RL2-S and attached sensor are now ready for installation as shown in Figure 10. Release date: 2020-03-23 Date of issue: 2020-06-30 Filename: 904798_eng.pdf Figure 10 Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com fa-info@de.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 4
OMH-RL2-S 价格&库存
很抱歉,暂时无法提供与“OMH-RL2-S”相匹配的价格&库存,您可以联系我们找货
