PZ-30-NVCN
PZ-30-NVCN
    NIDEC(尼得科)
    PRESSURE INDICATORS
PZ-30-NVCN 数据手册
PZ-30 PRESSURE INDICATORS ϚʔΩϯά &.$ࢦྩద߹ marking Compatible with EMC directive 11 kinds of display multiplier Full 3-digit red LED ※ Except for Current output type Small 30 mm square face Compatible with our analog sensors ■ FEATURES ● Pressure indicators separated from sensor   - Can be used with variety of sensors ● Wide range of applications such as pneu­mat­ic  equipment or semiconductor equipment ● Any range of pressure sensors is available ● Low power consumption by non display mode ● Set data protection by panel lock function ■ MODEL NUMBER DESIGNATION P Z - 3 0 - N V S T I Series name Switch output interface Analog output N:NPN open collector P:PNP open collector Blank:Voltage output I:Current output Input signal type Sensor connection type V:1 ~ 5 V I:4 ~ 20 mA ST:One-touch type terminal CN:Connector type terminal ■ LIST OF MODEL NUMBERS Sensor connection type Analog output Switch output type NPN Analog output PNP NPN Analog Current output PNP Input signal type 1~5V 4 ~ 20 mA 1~5V 4 ~ 20 mA 1~5V 4 ~ 20 mA 1~5V 4 ~ 20 mA ※ Verify the above model numbers when placing orders. One-touch type terminal PZ-30-NVST PZ-30-NIST PZ-30-PVST PZ-30-PIST PZ-30-NVSTI PZ-30-NISTI PZ-30-PVSTI PZ-30-PISTI Marked Connector type terminal PZ-30-NVCN PZ-30-NICN PZ-30-PVCN PZ-30-PICN is manufactured upon receipt of order basis. PZ-30 PRESSURE INDICATORS ■ STANDARD SPECIFICATIONS ● Unless otherwise specified, the specs are defined at an ambient temperature of 25±5 °C and excitation voltage of 24 V DC. Imput General specifications Item PZ-30 Model number Operating temp. range Operating humidity − 10 ~ 50 °C 35 ~ 85 %RH IP40 Protection grade Storage temp. Net weight °C − 20 ~ 70 g Approx. 80 (Including 2 m cable) 100 MΩ minimum Insulation resistance 500 V DC 1 minute Dielectric strength 10.8 ~ 30 V DC(Including ripple percentage)※ Supply voltage Consumption current 50 mA maximum 1 ~ 5 V (V) / 4 ~ 20 mA (I) Input signal Input impedance 10 kΩ (V) / 250 Ω (I) kΩ 3 No. of digit LED Display Display element Approx. 4 times/s Display cycle “–” LED is ON Negative pressure display ± 1 %F.S. (Without sensor's error) Display accuracy ± 0.5 % (0 ~ 50 °C, Reference temp. 25 °C) Thermal error 1 count Resolution NPN/PNP Output status 2-point output (Transistor, Open collector output) Switching capacity 30 V DC 100 mA maximum 1.2 V maximum (NPN), 2.2 V maximum (PNP) Switch Residual voltage 0 ~ 300 counts Adjustable Hysteresis setting ± 0.2 %F.S. ± 1 count Repeatability With pretection function Short circuit protection Approx. 5 ms (“F – 0”) (Selectable 5 ms ~ 2.5 s) Response ± 0.5 %F.S. (0 ~ 50 °C, Refernce temp. 25°C) Analog output Thermal error State indication Output 1 (Green LED), Output 2 (Red LED)  Lighted when output is ON. Voltage output 1~5V Current output 4 ~ 20 mA(500 Ω) ※ When analog current output type of PZ30 is chosen or when a sensor of current output type is connected, supply voltage is 24 V DC ± 10% ■ ENVIRONMENTAL CHARACTERISTICS Test item Test conditions Vibration 10 ~ 500 Hz, 98.1 m/s or 1.5 mm P-P, 3 directions for 2 hours each Shock Moisture resistance EMC Permissible change 2 490 m/s2, 3 directions for 3 times each 40 °C, 90 ~ 95 %RH, 240 hrs. EMI : EN55011: 2007, A2 : 2007 Group 1, class B EMS : EN61326-1: 2006 Table 2 Pressure indication, switch operating points and analog output variation : ± 1 %F.S. maximum each after test Pressure indication, switch operating pressure and analog output: ± 5 %F.S. maximum during test PZ-30 PRESSURE INDICATORS ■ INTERNAL ELECTRICAL SCHEMATICS ● Voltage analog output ・Current input NPN output 1 ・Current input PNP output LED Indicator 2 LED Indicator Power 1 〉〉 V+ Load Load Is 2 〉〉 Sensor Main circuit 3 〉〉 Com 1 + Is Sensor Common A.Output Com 1 2 Sensor Pressure indication ・Voltage input PNP output LED Indicator LED Indicator 1 Com Main circuit 3 〉〉 2 Power + Load Load Vs 2 〉〉 Common A.Output Pressure indication 1 〉〉 S.Output1 S.Output2 Load Load 3 〉〉 LED Power V+ Main circuit 2 〉〉 LED ・Voltage input NPN output + Power 1 〉〉 V+ S.Output1 S.Output2 2 V+ S.Output1 S.Output2 Sensor Common A.Output Com 1 〉〉 + S.Output1 Vs 2 〉〉 Main circuit S.Output2 Load Load 3 〉〉 Common A.Output LED LED Pressure indication Pressure indication ※ When connecting the 2-wire type of current output sensors, please do not connect the 3 (Com.) terminal. ● Current analog output ・ Current input NPN output ・Current input PNP output LED Indicator LED Indicator 1 1 2 Power V+ Sensor Com A.Output 1 〉〉 Is 2 〉〉 Main circuit 2 Power + V+ Load Load S.Output1 S.Output2 Sensor 3 〉〉 Common Com 1 〉〉 S.Output1 Is 2 〉〉 Main circuit Common Pressure indication ・Voltage input NPN output ・Voltage input PNP output LED Indicator LED Indicator 1 2 Power Sensor Com 1 〉〉 Vs 2 〉〉 A.Output Main circuit 3 〉〉 Load Load LED LED V+ S.Output2 A.Output 3 〉〉 Pressure indication 1 + 2 Power + V+ Load Load S.Output1 S.Output2 Common Sensor Com 1 〉〉 + S.Output1 Vs 2 〉〉 Main circuit S.Output2 A.Output 3 〉〉 Load Load Common LED LED Pressure indication Pressure indication ※ When connecting the 2-wire type of current output sensors, please do not connect the 3 (Com.) terminal. (Note)Refer to the PIN allocation for the rear terminal number of the PZ-30 and the connector pin terminal number. (Please from the table on dimension drawing) PZ-30 PRESSURE INDICATORS ■ ANALOG OUTPUT MODE Analog output Code ● Analog output setting : The second figure in triple digits LED indicates output mode in the initial setting. Output mode is fixed by rated pressure. −Pr 0 Pr Output mode “1” R mode (Compound) 1 V (Vzero) (4 mA) 5V (20 mA) “2” G mode (Positive) 1 V (4 mA) 5V (20 mA) “3” V mode (Negative) 5 V (20 mA) 1V (4 mA) ■ SWITCH OUTPUT MODE ● Switch output can be set when blinking red LED indicates (SW2) in the intial setting. ● The mode is set at “Separate (H/H), 1” prior to shipment. The mode is initialized at “Separate (L/L), 4” when rated pressure is set at “-12P” or “-12F” (negative pressure). Output Mode Operation SW1 Separate HI LO Window comparator A B Separate HI LO ( HI operation ) Window comparator A B S- 1 S- 2 S- 3 S- 4 C- 5 C- 6 C- 7 C- 8 Pressure setting (Operating point) Window comparator mode Separate mode SW2 ( A operation ) ON OFF ON ON OFF P1: SW1 P2: SW2 H H -Pr P1 Pr P2 -Pr Pr H ( LO operation) ( B operation) ON ON P1: SW1 -Pr P2: SW2 H H OFF Pr OFF (Lower limit) : Setting 1 (Upper limit) : Setting 2 Setting 2 (Lower limit) : Setting 1 (Upper limit) : Setting 2 H : Switch hysteresis P1= Setting 1 P1 P2 -Pr P1≦P2 or P1≧P2 Setting 1 H OFF Pr H H P1≦P2–2H P2= Setting 2 Note 1. In the Separate Mode, setting 1 corresponds to SW1, and Setting 2 corresponds to SW2. Note 2. In the Window Comparator Mode, the minimum value for SW1 and SW2 corresponds to Setting 1 and the maximum value corresponds to Setting 2. PZ-30 PRESSURE INDICATORS ■ SELECTION OF DISPLAY MULTIPLIER/RATED PRESSURE ● Selection of display multiplier ● Selection of rated pressure pressure in the initial setting. ● Display multiplier is set at “1” (kPa) prior to shipment. ● Rated pressure is set at “12P” (0 ~ 100 kPa) prior to ● Please set any code when blinking red LED indicates negative Mode (1/3) Display multiplier Code Multiplier “1” × 1 (kPa) “2” × 0.0102 “3” × 10.2 “4” × 7.501 “5” × 102 “6” × 0.01 “7” × 10 “8” × 0.145 “9” × 0.000145 ● Please set any code when blinking red LED indicates negative pressure, SW1, SW2 in the initial setting. shipment. Pressure reference Pressure unit Rated pressure range 0 ~ 10 0 ~ 35 0 ~ 50 Setting code “11P” “41P” “51P” “-12P” “12P” “42P” “52P” “62P” “72P” “13P” “23P” 0.00 9.99 0.00 0.10 0.0 99.9 0.0 75.0 0 999 0.00 0.10 0.0 99.9 0.00 1.45 0.0 35.0 0.00 0.35 0 357 0 262 0.0 50.0 0.00 0.51 0 510 0 375 0.0 -99.9 0.00 -1.02 0 -999 0 -750 0.0 99.9 0.00 1.02 0 999 0 750 0 350 0.00 3.57 0 500 0.00 5.10 0 600 0.00 6.12 0 700 0.00 7.14 0 999 0.00 9.99 0.0 20.4 0.00 0.35 0 350 0.00 5.07 0.00 0.50 0 500 0.00 7.25 0.00 -1.02 0 -999 0.0 -14.5 0.00 1.02 0 999 0.0 14.5 0.00 3.50 0.00 5.00 0.00 6.00 0.00 7.00 0.00 9.99 0.0 20.0 0.0 50.7 0.0 72.5 0.0 87.0 0 101 0 145 0 206 0.00 1.00 0 295 0 290 0.00 0.29 0.00 2.00 0 590 Rated pressure display (PL ~ PH) Gauge/Absolute kPa MPa 0 ~ -100 0 ~ 100 0 ~ 350 0 ~ 500 0 ~ 600 0 ~ 700 0 ~ 1000 0 ~ 2.00 “A” × 0.001 (MPa) “b” Mode (2/3) Display multiplier Code Multiplier “1” × 1 (kPa) “2” × 0.0102 “3” × 10.2 “4” × 7.501 “5” × 102 “6” × 0.01 “7” × 10 “8” × 0.145 “9” × 0.000145 “A” × 0.001 (MPa) “b” 0.00 2.95 × 0.2953 × 0.2953 Pressure reference Pressure unit Rated pressure range Setting code Rated pressure display (PL ~ PH) 0.0 10.3 0.0 14.7 0 -29.5 0 29.5 0 103 0 147 0 177 Gauge/Absolute MPa Compound kPa 0 ~ 3.50 0 ~ 5.00 0 ~ 10.0 0 ~ 20.0 0 ~ 35.0 -10 ~ 10 -100 ~ 100 -100 ~ 200 -100 ~ 300 -100 ~ 500 -100 ~ 600 -100 ~ 1000 “43P” “53P” “14P” “24P” “44P” 0.0 35.7 0.0 51.0 0 102 0 204 0 357 0.0 35.0 0.0 50.0 0.0 99.9 0 200 0 350 0 507 0.00 0.50 0.00 3.50 0 999 0 725 0.00 0.72 0.00 5.00 0.00 1.45 0.00 9.99 0.00 2.90 0.00 20.0 0.00 5.07 0.00 35.0 “11r” “12r” “22r” “32r” “52r” “62r” “13r” -9.99 9.99 -0.10 0.10 -99.9 99.9 -75.0 75.0 -999 999 -0.10 0.10 -99.9 99.9 -1.45 1.45 -99.9 99.9 -1.02 1.02 -999 999 -750 750 -100 200 -1.02 2.04 -100 300 -1.02 3.06 -100 500 -1.02 5.10 -100 600 -1.02 6.12 -100 999 -1.02 9.99 -1.00 1.00 -999 999 -14.5 14.5 -1.00 2.00 -1.00 3.00 -1.00 5.00 -1.00 6.00 -1.00 9.99 -14.5 29.0 -14.5 43.5 -14.5 72.5 -14.5 87.0 -0.10 0.10 -29.5 29.5 -0.10 0.20 -29.5 59.0 -0.10 0.30 -29.5 88.5 -0.10 0.50 -29 147 -0.10 0.60 -29 177 -14 145 -0.01 0.14 -0.10 1.00 -29 295 -2.95 2.95 PZ-30 PRESSURE INDICATORS ■ SELECTION OF DISPLAY MULTIPLIER/RATED PRESSURE Pressure reference Pressure unit Rated pressure range Mode (3/3) Display multiplier Code Multiplier “1” × 1 (kPa) “2” × 0.0102 “3” × 10.2 “4” × 7.501 “5” × 102 “6” × 0.01 “7” × 10 “8” × 0.145 “9” × 0.000145 Setting code Rated pressure display (PL ~ PH) Gauge/Absolute (× 1 / 0.0102) kPa 0 ~ 0.10 0 ~ 0.35 0 ~ 0.50 0 ~ -1.00 0 ~ 1.00 0 ~ 3.50 0 ~ 5.00 0 ~ 7.00 0 ~ 10.0 “11F” “41F” “51F” “-12F” “12F” “42F” “52F” “72F” “13F” 0.00 9.80 0.00 0.10 0.0 99.9 0.0 73.5 0 999 0.00 0.09 0.0 98.0 0.00 1.42 0.0 34.3 0.00 0.35 0 350 0 257 0.0 49.0 0.00 0.50 0 500 0 367 0.0 -98.0 0.00 -1.00 0 -999 0 -735 0.0 98.0 0.00 1.00 0 999 0 735 0 343 0.00 3.50 0 490 0.00 5.00 0 686 0.00 7.00 0 980 0.00 9.99 0.00 0.34 0 340 0.00 4.97 0.00 0.49 0 490 0.00 7.10 0.00 -0.98 0 -980 0.0 -14.2 0.00 0.98 0 980 0.0 14.2 0.00 3.43 0.00 4.90 0.00 6.86 0.00 9.80 0.0 49.7 0.0 71.0 0.0 99.5 0 142 0 202 0.00 0.98 0 289 “A” × 0.001 (MPa) “b” 0.00 2.89 × 0.2953 0.0 10.1 0.0 14.4 0.0 -28.9 0.0 28.9 ■ OUTLINE DIMENSION 0 101 0 144 Unless otherwise specified, tolerance: ± 0.5 (Unit: mm) ● One-touch type terminal □31.4 35 □30 20 21 Window SW1 5 core cable L = 2000 ± 100 36.4 +/– SW2 20 kPa 10 PZ-30 2 – M3 Depth 6 1 3 AWG26 UL No.2844 Push button Wire input Terminal : OCN-051 manufactured by Osada Wire : AWG16 26 Wire strip length : 9 10 mm 8.5 ● Connector type terminal □31.4 □30 35 7.5 2-M3 Depth 6 123 Rear Terminal No. kPa 20 36.4 10 7.8 PZ-30 20 2 26.5 21 5 core cable L = 2000 ± 100 AWG26 UL No.2844 3 2 1 Connector Pin No. Connector : 0-171826-3 (Pitch 2.5) manufactured by AMP (Housing : 0-171822-3) 8.5 Wire color Brown Gray Black White Blue Connection Power ⊕ Analog output Switch output 1 Switch output 2 Common Connector pin No. Rear terminal No. Connection of pressure sensor 3 1 V+:Power supply voltage output (Input voltage) 2 2 Sensor signal: Voltage output Vs (1 ~ 5V) /Current output Is (4 ~ 20mA) 1 3 COMMON(※) ※ When connecting the 2-wire type of current output sensors, please do not connect the 3 (Com.) terminal. PZ-30 PRESSURE INDICATORS ■ HOW TO MOUNT OPTIONAL ACCESSORIES Unless otherwise specified, tolerance: ± 0.5 (Unit: mm) ● Rear panel mounting bracket set ● Panel mounting bracket set (51) 35 7 35 35 7 φ4.2 12 (51) 35 φ4.2 12 35 Material : SUS304 (t = 1.5) 25 Material : SUS304 (t = 1.5) 35 Material : SUS304 (t = 1.5) 25 Material : SUS304 (t = 1.5) φ4.2x5.2 Slot 2-M3x4 φ4.2x5.2 Slot Associated screw 2-M3x4 Associated screw 2-M3x4 Associated screw φ4.2 15.5 (5.7) 4.5 31.2 36 +0.5 0 36 +0.5 0 36 +0.5 0 43 maximum 43 maximum □40 □40 kPa Recommended : 50 minimum 36 +0.5 0 6 maximum 24.7 kPa PZ-30 Panel cut dimension (Recommended board thickness : 5 maximum) Panel cut dimension (Recommended board thickness : 5 maximum) Name Series Name Contents (PG-30/PG-35) ACPG-003 Panel holder cover Panel holder Panel stopper (2 pcs.) Holder cover set ACPG-004 Panel holder cover Panel holder Holder stopper set ACPG-007 Panel holder Panel stopper (2 pcs.) Rear panel bracket set (Z) ACPG-011 Rear panel bracket set (Z) and M3 × 4, male screw (2 pcs.) Panel bracket set (Z) ACPG-012 Panel panel bracket set (Z) and M3 × 4, male screw (2 pcs.) Panel holder set (46) (46) Recommended : 50 minimum 6 maximum PZ-30 (30) φ4.2x5.2 Slot 24.7 (5.7) □42.6 (30) (20.5) 20 31.2 4.5 (14) 6 φ4.2x5.2 Slot 30 30 □42.6 (20.5) 9 20 (14) (46) (46) 6 24 9 24 φ4.2 15.5 ● Panel holder set 2-M3x4 Associated screw
PZ-30-NVCN 价格&库存
很抱歉,暂时无法提供与“PZ-30-NVCN”相匹配的价格&库存,您可以联系我们找货
