2000035929
2000035929
    BASLER
    CABLE USB 3.0, MICRO B 90 A3 / A
2000035929 数据手册
DRAFT Basler Accessories Technical Specification CABLE USB 3.0, MICRO-B 90° A3/A Order Numbers 2000035891 2000035892 2000035929 Document Number: DG001617 Version: 01 Language: 000 (English) Release Date: 14 January 2016 Contacting Basler Support Worldwide Europe, Middle East, Africa Basler AG An der Strusbek 60–62 22926 Ahrensburg Germany Tel. +49 4102 463 515 Fax +49 4102 463 599 support.europe@baslerweb.com The Americas Basler, Inc. 855 Springdale Drive, Suite 203 Exton, PA 19341 USA Tel. +1 610 280 0171 Fax +1 610 280 7608 support.usa@baslerweb.com Asia-Pacific Basler Asia Pte. Ltd. 35 Marsiling Industrial Estate Road 3 #05–06 Singapore 739257 Tel. +65 6367 1355 Fax +65 6367 1255 support.asia@baslerweb.com www.baslerweb.com All material in this publication is subject to change without notice and is copyright Basler AG. DG00161701000 Basler Technical Specification Order Number Description Applicable Cameras 2000035891 Data cable USB 3.0, Type A plug to Micro-B plug, 90° angled, 1 m dart, pulse 2000035892 Data cable USB 3.0, Type A plug to Micro-B plug, 90° angled, 3 m dart, pulse 2000035929 Data cable USB 3.0, Type A plug to Micro -B plug, 90° angled, 5 m dart, pulse 17 Table 1: Cable Types 8 37 28 16 25.5 8.5 Length depending on order number Dimensions in mm Fig. 1: Cable Overview dart pulse Fig. 2: Cable Connected to dart and pulse Cameras Basler Cable USB 3.0, Micro-B 90° A3/A 1 Basler Technical Specification DG00161701000 Transfer Rates 2000035891 2000035892 USB 2.0 480 Mbps USB 3.0 5 Gbps 2000035929 Table 2: Transfer Rates Physical Specifications 2000035891 Camera-Side Connector 2000035892 2000035929 Micro-B, USB-IF-compliant Host-Side Connector Type A connector, USB-IF-compliant Cable Diameter 5.7 mm max. Minimum Bending Radius 57 mm (10 x cable diameter), fixed installation Minimum Number of Bending Cycles None (fixed installation only) Suitable for Drag Chain Applications No Suitable for Robotics Applications No Table 3: Physical Specifications Electrical Specifications 2000035891 2000035892 Nominal Operating Voltage See camera user’s manual Maximum Operating Voltage See camera user’s manual 2000035929 Table 4: Electrical Specifications Environmental Specifications 2000035891 Operating Temperature 2000035892 2000035929 +80 °C max. (not moving) Table 5: Environmental Specifications 2 Basler Cable USB 3.0, Micro-B 90° A3/A DG00161701000 Basler Technical Specification General Information 2000035891 RoHS Compliance 2000035892 Yes CE Conformity Yes (RoHS compliance) UL Conformity Yes Warranty 2000035929 1 year Table 6: General Information The cables are intended for use with the cameras specified in Table 1 only. When connecting the cable to the camera, consider that the position of the camera’s USB 3.0 connector defines the direction the cable is guided within your installation. Read the camera user’s manual including the safety warnings before connecting the cable to the camera. The user’s manual also contains further information about pin assignments, power requirements, as well as comprehensive information about installing and using the camera. You can download the user’s manual and related documents for your camera free of charge from the Basler website: www.baslerweb.com. Basler Cable USB 3.0, Micro-B 90° A3/A 3 Basler Technical Specification DG00161701000 Revision History Doc. ID Number Date Changes DG00161701000 14 Jan 2016 Initial release of this document. 4 Basler Cable USB 3.0, Micro-B 90° A3/A
2000035929 价格&库存
很抱歉,暂时无法提供与“2000035929”相匹配的价格&库存,您可以联系我们找货
