E40096
E40096
    IFM(易福门)
    SCREW-IN ADAPTER FOR PROCESS SEN
E40096 数据手册
E40096 Screw-in adapter for process sensors ADAPTER SI1/G1/2/VA Application Application for industrial applications Media liquids and gases Pressure rating [bar] 100 Tests / approvals A possible classification to PED depends on the application and has to be carried out by the user / operator. Pressure Equipment Directive The compatibility between medium and product material has to be checked in all applications. Safety instructions Mechanical data Weight [g] Dimensions [mm] Thread designation M18 x 1.5 M18 x 1.5 Materials Tightening torque 57.9 stainless steel (1.4404 / 316L) [Nm] 50 Sensor connection M18 x 1,5 internal thread Process connection threaded connection G 1/2 Insertion depth [mm] 21; (measuring probe SID, SFD, TN) Accessories Items supplied sealings: 1, NBR reinforced fibre Remarks In applications >30 bar use a suitable high-pressure adapter. Remarks Pack quantity In drinking water applications, replace the supplied gaskets by gaskets suitable for the application. 1 pcs. ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — E40096-00 — 10.12.2014 —
E40096 价格&库存
很抱歉,暂时无法提供与“E40096”相匹配的价格&库存,您可以联系我们找货
