C-K15
C-K15
    ROCHESTER(罗切斯特)
    CONNECTOR KIT 3-WAY MP 150
C-K15 数据手册
C-K15 3-way Metri-pack 150 mating connector kit Document ref.: DDS_C-K15_R1.DOCX 25-Jan-21 Rev. 1 The C-K15 is a 3-way Metri-pack 150 mating connector kit to suit harness wires with a cross sectional area of 0.8 to 1.0 mm² and sleeve Ø1.60 to 2.15 mm Part Description Prod. Group Comprises For use with: 5 C-K15 3-way Metri-pack 150 mating connector kit Connector Kit Female Connector Assembly Loose Cable Seal Female terminal, wire range 0.50-1.00 mm² Lock Secondary TPA M/P 3 CRM S298-202 x1 x3 x3 x1 Rochester Gauges, LLC 11616 Harry Hines Blvd., P.O. Box 29242, Dallas, TX 75229, USA +1(972) 241-2161 rochestergauges.com info@rochestergauges.com E. & O. E. Rochester Gauges LLC and Fozmula Limited expects that you will conduct the testing and evaluation necessary to determine that these products are suitable for your application. Materials and specifications are subject to change without notice. JP 10-Jan-21 5.10 Rev. 1
C-K15 价格&库存
很抱歉,暂时无法提供与“C-K15”相匹配的价格&库存,您可以联系我们找货
