HPF-D001-H
HPF-D001-H
    PEPPERL+FUCHS(倍加福)
    M6 THREAD FIBER OPTIC
HPF-D001-H 数据手册
Signal output Switching current Voltage drop Switching frequency Photoelectric Sensors Housing Standards Approvals Photographs Fiber Optic Diffuse and Thru-Beam Mode Plastic Fibers In applications involving small targets or unfavorable conditions, fiber optic cables may be the sensible solution. Glass fiber optic cables are constructed from tiny strands of glass that are bundled together inside an application-specific sheath. Plastic fiber optic cables are manufactured from a light conductive plastic monofilament material, which is protected by a PVC jacket. .3 Diffuse When attached to the end of certain photoelectric sensors, they guide the light through the cable and out at the sensing head. A separate fiber attached to the receiver returns the light. Pepperl+Fuchs offers both glass and plastic fiber optic cables. The diameter of the glass fiber optic cables is generally larger than plastic and provides a longer sensing range. Pepperl+Fuchs’ glass cables can withstand temperatures as high as 900 °F while the plastic cables are rated as high as 221 °F. The plastic cables are typically used due to their small size and narrow beam diameter. This enables easy detection of small parts such as pins on an IC chip. Plastic cables can be “cut-to-length” in the field; therefore, the correct length doesn’t have to be specified when ordering. Obtaining the maximum light intensity possible in each application is accomplished by customizing the plastic cables to the shortest possible length. This reduces the inherent “light losses” that occur inside the cable. Pepperl+Fuchs offers three standard types of sheaths: stainless steel, silicone, and PVC. Photoelectric Sensors, Standard Sensors, Fiber optic cables Fiber optic cables Timer function Ambient temperature Protection degree Connection Introduction to Fiber Optic Cables 2 1 push-pull output NPN/PNP , short-circuit proof max. 100 mA , resistive load  2 V DC at 100 mA ;  0.7 V at 10 mA High speed mode: 16 kHz , Standard mode: 3 kHz , High resolution: 250 Hz ~ 3 kHz (selection by the sensor), Automatic: 250 Hz , Glass mode: 250 Hz ON-delay, OFF-delay, one shot, pulse extension ; adjustable 0 ... 999 ms in 1 ms increments -10 ... 55 °C (14 ... 131 °F) IP50 2 m fixed cable , 1 x 0.25 mm² , PVC 2 m PVC cable, 4 x 0,14 mm² PC EN 60947-5-2 CE, cULus Listed 57M3 (Only in association with UL Class 2 power supply; Type 1 enclosure) Thru-Beam Glass Fibers Diffuse Thru-Beam In diffuse mode sensing, a bifurcated cable (2 in 1) is used. Thru-beam requires two individual cables. Threaded Mounting Cylinder Mounting and Fitting When positioning plastic fiber optic cable, a minimum bending radius of 15 mm must be maintained. In addition, a straight section of ≥15 mm must be maintained at both ends of fiber optic cable between the threaded mounting cylinder and optical sensor. Some fiber optic cables have a flexible stainless steel pickup attached. In such a case, a minimum bending radius of 10 mm must be maintained. Also, to avoid damage to the pickup head light guide, a straight section of 10 mm must be maintained at both ends. Plastic Fiber Optic Cable 15 mm Fiber Sensor 15 mm R R 15 mm Stainless Steel Pickup Head Threaded Mounting Cylinder 10 mm Plastic Fiber Optic Cable 15 mm Fiber Sensor R R R 10 mm 15 mm R 15 mm R 10 mm Please Note! Do not twist or kink plastic fiber optic cables. 550 Refer to General Notes Relating to Product Information Pepperl+Fuchs Group www.pepperl-fuchs.com USA: +1 330 486 0001 fa-info@us.pepperl-fuchs.com Avoid contact with petroleum or organic solvents. Germany: +49 621 776-4411 fa-info@de.pepperl-fuchs.com Excessive pulling will lead to severe damage. Copyright Pepperl+Fuchs Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com Photoelectric Sensors Fiber optic cables Specifications for Glass Fiber Optic Cables -58 °F to +248 °F IP40 -58 °F to +572 °F .5 .6 Minimum Bend Radius for HPF and FE Cables .6 To help prevent possible damage to fiber optic cables, do not exceed the minimum bend radius. Glass Stainless Steel Sheathing Cables Glass PVC Sheathing Cables Plastic Cables - 1 mm diameter core Plastic Cables - 0.5 mm diameter core 1 inch (25 mm) 0.75 inch (19 mm) 1 inch (25 mm) 0.5 inch (12.5 mm) Temperature Ranges for HPF and FE Cables Plastic Fiber Optic Sensor Head Plastic Cable Plastic Cable Lens Accessories Glass Cable (PVC Sheathing) Glass Cable (Stainless Steel Sheathing) Glass Cable (High Temperature) Glass Cable End Tips 2 Glass Cable for SU18, SU19, SU17.1, and ML17-LL (Stainless Steel Sheathing) Glass Cable for SU18, SU19, SU17.1, and ML17-LL (PVC Sheathing) 2 2 2 IP67 ≤ 25 mm -58 °F to +356 °F .7 -22 °F to +158 °F (-30 °C to +70 °C) -22 °F to +158 °F (-30 °C to +70 °C) -22 °F to +158 °F (-30 °C to +70 °C) -40 °F to +250 °F (-40 °C to +120 °C) -40 °F to +450 °F (-40 °C to +232 °C) -40 °F to +900 °F (-40 °C to +482 °C) -40 °F to +585 °F (-40 °C to +307 °C) -67 °F to +392 °F (-55 °C to +200 °C) -67 °F to +149 °F (-55 °C to +65 °C) Note: SU19 Series sensing ranges are reduced by 50% in high-speed or glass modes. Refer to General Notes Relating to Product Information Pepperl+Fuchs Group www.pepperl-fuchs.com USA: +1 330 486 0001 fa-info@us.pepperl-fuchs.com Germany: +49 621 776-4411 fa-info@de.pepperl-fuchs.com .8 Copyright Pepperl+Fuchs Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 2 .9 .3 Photoelectric Sensors, Standard Sensors, Fiber optic cables .4 2 Photoelectric Sensors, Accessories .2 2 Photoelectric Sensors, Optical Data Couplers .3 ≤ 20 mm IP67 Silicone Sheathing Photoelectric Sensors, Light Grids Working Temperature Range ≤ 30 mm Photoelectric Sensors, Standard Sensors, Slot sensors Bending Radius Stainless Steel Sheathing Photoelectric Sensors, Standard Sensors, Slot sensors 2 Protection (IEC) PVC Sheathing Photoelectric Sensors, Standard Sensors, Color sensors 2 Photoelectric Sensors, Standard Sensors, Contrast and luminescence sensors Photoelectric Sensors, Standard Sensors, Fiber optic sensors .3 2 Photoelectric Sensors, Standard Sensors, Distance sensors 2 Photoelectric Sensors, Standard Sensors, Fiber optic sensors (with Model Numbers L...) 551 Photoelectric Sensors Fiber optic cables Plastic Fiber Optic Cables Diffuse Plastic Fiber Optic Cables for SU18, SU19, SU17.1, ML17-LL, and MHP-FR Sensors KLR-C02-2.2-2.0-K85 KLR-C16-2.2-2.0-K72 552 2m 2m 1.25 mm 2.2 mm 2.2 mm MHP-FR not compatible SU18 High Power 118 mm SU18 High Speed 14 mm Black SU19 14 mm polyethylene SU17.1 100 mm ML17-LL 18 mm MHP-FR not compatible SU18 High Power 280 mm SU18 High Speed 80 mm SU19 80 mm SU17.1 238 mm ML17-LL 45 mm MHP-FR not compatible PVC SU18 High Power 110 mm SU18 High Speed 30 mm SU19 30 mm PVC SU17.1 94 mm ML17-LL 18 mm MHP-FR not compatible SU18 High Power 280 mm SU18 High Speed 80 mm SU19, 80 mm SU17.1 238 mm ML17-LL 45 mm MHP-FR 18 mm SU18 High Power 300 mm SU18 High Speed 85 mm PVC PVC USA: +1 330 486 0001 fa-info@us.pepperl-fuchs.com SU19 85 mm SU17.1 255 mm ML17-LL 48 mm MHP-FR 20 mm Germany: +49 621 776-4411 fa-info@de.pepperl-fuchs.com ø1 ø0.25 fiber optic core x 2 (receiver) Connector ø3 ø2.2 4 mm 15 Adapter included 17 2000 ø1 fiber optic core x 2 10.5 ø1.3 15 ø1.3 ø2.2 21 mm 60 10.5 ø4 SU17.1 ML17-LL 15 ø1.25 PVC Refer to General Notes Relating to Product Information Pepperl+Fuchs Group www.pepperl-fuchs.com 7 mm 1925 15 ø0.5 fiber optic core x 1 (emitter) l 10.5 ø1.25 15 ø1.25 ø0.25 fiber optic core x 9 (receiver) 17 ø1 fiber optic core x 2 ø2.2 2m 1.3 mm SU19 10 ø0.25 fiber optic core x 2 (emitter) 2000 ø2.2 KLR-C09-1.25-2.0-K77 2m 1.0 mm 7 mm 17 ø1.0 fiber optic core x 1 (emitter) l ø0.25 fiber optic core x 16 (receiver) Copyright Pepperl+Fuchs Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com ø2.2 KLR-C02-1.3-2.0-K86 2m 1 mm 25 mm ø4 HPF-D005-H 2m SU18 High Power SU18 High Speed Dimensions (mm) ø1.5 KLR-C04-1.0-2.0-K133 Sensing Range ø4 Photoelectric Sensors, Standard Sensors, Fiber optic cables .3 Compatible Sensors ø3 Cable Fiber Sheathing Length Diameter Material ø3 Model Number ø5 2 ø5 Nonthreaded Cylindrical Photoelectric Sensors Fiber optic cables Plastic Fiber Optic Cables Diffuse Plastic Fiber Optic Cables for SU18, SU19, SU17.1, ML17-LL, and MHP-FR Sensors HPF-D002-HL5 5m 2.2 mm 2.2 mm Refer to General Notes Relating to Product Information Pepperl+Fuchs Group www.pepperl-fuchs.com 80 mm SU19 80 mm 238 mm 45 mm not compatible SU18 High Power 100 mm SU18 High Speed 30 mm SU19 30 mm SU17.1 ML17-LL MHP-FR 85 mm 16 mm ø1 fiber optic core x 2 SU18 High Power 471 mm SU18 High Speed 66 mm SU19 66 mm SU17.1 400 mm ML17-LL 60 mm MHP-FR 18 mm SU18 High Power 471 mm SU18 High Speed 50 mm SU19 50 mm polyethylene SU17.1 400 mm ML17-LL 60 mm MHP-FR 18 mm Germany: +49 621 776-4411 fa-info@de.pepperl-fuchs.com 5 ø1.25 Conduit ø3.3 10 3 5 ø3 ø0.25 fiber optic core x 9 (receiver) 2000 10.5 ø1.3 ø1.3 Conduit ø3.5 M4x0.7 14.8 3 10.5 ø1.25 ø3 M3x0.5 ø0.5 fiber optic core x 1 (emitter) l 5 ø3 ø1.25 ø2.2 18 1 not compatible Black USA: +1 330 486 0001 fa-info@us.pepperl-fuchs.com ø 0.25 fiber optic core x 9 (receiver) not compatible 280 mm SU17.1 ø 0.5 fiber optic core x 1 (emitter) 15 ø2.2 16 mm SU18 High Power MHP-FR Black 85 mm SU18 High Speed ML17-LL polyethylene 30 mm 2000 min Nut and washer: M3 x 0.5 l 10.5 15 ø1.25 M4x0.7 Conduitø3.3 Brass, nickel plated ø2.2 SU19 SU17.1 11 .3 Photoelectric Sensors, Accessories 30 mm .9 2 – C0.3 ø4 SU18 High Speed .8 Detection head M3 SUS303 ø4 100 mm MHP-FR PVC 13 mm not compatible SU18 High Power ML17-LL PVC 100 mm .7 2 Adapter included ø4 PVC 16 mm 2 Photoelectric Sensors, Standard Sensors, Fiber optic cables 2m 1.25 mm MHP-FR .6 16 mm 2 2 – ø 0.5 (Core) Photoelectric Sensors, Optical Data Couplers 2m 1.3 mm SU17.1 ML17-LL .6 118 mm Dimensions (mm) ø2.6 2m 1.25 mm polyethylene SU19 2 ø2 Photoelectric Sensors, Light Grids 2m 1.0 mm SU18 High Speed Black 2 Sensing Range SU18 High Power .5 2 M2.6 KLR-C09-1.25-2.0-K74 HPF-D002-H 2m Compatible Sensors Photoelectric Sensors, Standard Sensors, Slot sensors KLR-C09-1.25-2.0-K76 KLR-C02-1.3-2.0-K84 .4 2 Photoelectric Sensors, Standard Sensors, Slot sensors .2 Photoelectric Sensors, Standard Sensors, Contrast and luminescence sensors .3 HPF-D004-H 2 Cable Fiber Sheathing Length Diameter Material Photoelectric Sensors, Standard Sensors, Color sensors 2 Photoelectric Sensors, Standard Sensors, Distance sensors Photoelectric Sensors, Standard Sensors, Fiber optic sensors .3 2 Model Number Photoelectric Sensors, Standard Sensors, Fiber optic sensors 2 Threaded Cylindrical Nut and washer: M6 x 0.75 Nut and washer: M6 x 0.75 Copyright Pepperl+Fuchs Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 553 Photoelectric Sensors Fiber optic cables Plastic Fiber Optic Cables Diffuse Plastic Fiber Optic Cables for SU18, SU19, SU17.1, ML17-LL, and MHP-FR Sensors 2m HPF-D001-H 2m HPF-D001-HL03 Bendable Probe Model Number 3m 2.2 mm 2.2 mm 300 mm 85 mm SU19 85 mm SU17.1 255 mm ML17-LL 48 mm MHP-FR 20 mm SU18 High Power 647 mm SU18 High Speed 88 mm PVC Black SU19 88 mm polyethylene SU17.1 550 mm ML17-LL 85 mm MHP-FR 33 mm SU18 High Power 647 mm SU18 High Speed 88 mm KLR 00-2.2-2.0-K57 2m 2m 1 mm 2.2 mm 88 mm polyethylene SU17.1 550 mm ML17-LL 85 mm MHP-FR 33 mm Compatible Sensors Sensing Range SU18 High Power 122 mm SU18 High Speed 23 mm Black SU19 23 mm polyethylene SU17.1 104 mm ML17-LL 20 mm MHP-FR not compatible SU18 High Power 210 mm SU18 High Speed 60 mm PVC USA: +1 330 486 0001 fa-info@us.pepperl-fuchs.com SU19 60 mm SU17.1 179 mm ML17-LL 34 mm MHP-FR 6 mm Germany: +49 621 776-4411 fa-info@de.pepperl-fuchs.com l 3 ø0.25 fiber optic core x 16 (receiver) SU19 Refer to General Notes Relating to Product Information Pepperl+Fuchs Group www.pepperl-fuchs.com 17 ø1.0 fiber optic core x 1 (emitter) Black Cable Fiber Sheathing Length Diameter Material HPF-D006 554 2.2 mm SU18 High Power SU18 High Speed Dimensions (mm) M6x0.75 ø2.2 KLR-C16-2.2-2.0-K71 Sensing Range Dimensions (mm) Adapter included 80 5 18 13 2000 2 - ø 2.2 Photoelectric Sensors, Standard Sensors, Fiber optic cables .3 Compatible Sensors ø4 Cable Fiber Sheathing Length Diameter Material ø 2.5 Model Number 11 2 ø4 Threaded Cylindrical (cont.) Copyright Pepperl+Fuchs Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com M6 (P=0.75) Photoelectric Sensors Fiber optic cables Plastic Fiber Optic Cables Diffuse Plastic Fiber Optic Cables for SU18, SU19, SU17.1, ML17-LL, and MHP-FR Sensors 1.0 mm Refer to General Notes Relating to Product Information Pepperl+Fuchs Group www.pepperl-fuchs.com 30 mm SU19 30 mm SU17.1 81 mm 15 mm SU18 High Power 45 mm SU18 High Speed 27 mm SU19 27 mm SU17.1 38 mm ML17-LL 6 mm MHP-FR not compatible Germany: +49 621 776-4411 fa-info@de.pepperl-fuchs.com M6 x 0.75 ø4 M3P0.5 ø2 ø1.25 8.1 Copyright Pepperl+Fuchs Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com ø1.5 2000 10.5 ø1.25 ø2.2 ø4 2000 .3 15 ø2.2 3 5 4 2 ø1 fiber optic core x 2 ø 0.5 fiber optic core x 1 ø 0.25 fiber optic core x 10 not compatible Conduit ø3.5 .9 2 15 ø2.2 SU18 High Speed ø1.0 ø2 2 Photoelectric Sensors, Accessories 95 mm 10.5 ø4 14 mm 2000 .8ø1.0 Photoelectric Sensors, Optical Data Couplers 34 mm SU18 High Power MHP-FR USA: +1 330 486 0001 fa-info@us.pepperl-fuchs.com 179 mm 5 ø3 11 SU17.1 Photoelectric Sensors, Light Grids 60 mm 15 12 SU19 18.5 60 mm ø11.5 10 SU18 High Speed ML17-LL polyethylene not compatible 210 mm MHP-FR Black 8 mm SU18 High Power ML17-LL PVC 44 mm 2 6 PVC 15 mm .7 ø0.5 fiber optic 3 MHP-FR .6 core x 2 15 mm 17 SU17.1 ML17-LL .6 52 mm Dimensions (mm) Photoelectric Sensors, Standard Sensors, Fiber optic cables 2 mm 1.25 mm PVC 2 ø7 2m 2.2 mm SU18 High Speed SU19 2 Sensing Range Photoelectric Sensors, Standard Sensors, Slot sensors KLR-C10-1.25-2.0-K144 2m .5 2 Photoelectric Sensors, Standard Sensors, Slot sensors KHR-C02-2.2-2.0-K131 1 mm Compatible Sensors SU18 High Power .4 2m 2 Photoelectric Sensors, Standard Sensors, Color sensors .2 KHR-C02-1.0-2.0-K132 HPF-D011 2 Cable Fiber Sheathing Length Diameter Material Photoelectric Sensors, Standard Sensors, Contrast and luminescence sensors .3 2 Photoelectric Sensors, Standard Sensors, Distance sensors Photoelectric Sensors, Standard Sensors, Fiber optic sensors .3 2 Model Number Photoelectric Sensors, Standard Sensors, Fiber optic sensors 2 Side-view/Periscope Adapter included 555 Photoelectric Sensors Fiber optic cables Plastic Fiber Optic Cables Diffuse Plastic Fiber Optic Cables for SU18, SU19, SU17.1, ML17-LL, and MHP-FR Sensors Model Number 8 mm MHP-FR not compatible SU18 High Power 10 mm SU18 High Speed 10 mm SU19 10 mm SU17.1 10 mm ML17-LL 10 mm MHP-FR not compatible SU18 High Power 175 mm SU18 High Speed 50 mm SU19 50 mm SU17.1 149 mm ML17-LL 28 mm MHP-FR 12 mm Compatible Sensors Sensing Range KLR-A32-2.2-2.0-K141 2m 2m 2.2 mm 2.2 mm 120 mm 35 mm SU19 35 mm PVC SU17.1 102 mm ML17-LL 19 mm MHP-FR 8 mm SU18 High Power 120 mm SU18 High Speed 35 mm SU19 35 mm SU17.1 102 mm ML17-LL 19 mm MHP-FR 8 mm PVC Refer to General Notes Relating to Product Information Pepperl+Fuchs Group www.pepperl-fuchs.com SU18 High Power SU18 High Speed USA: +1 330 486 0001 fa-info@us.pepperl-fuchs.com Germany: +49 621 776-4411 fa-info@de.pepperl-fuchs.com Convergent beam for background blanking 4.5 ø1 fiber optic core x 2 4 20 2000 13 2.5 ø2.2 PVC Convergent beam for background blanking 5 PVC Cable Fiber Sheathing Length Diameter Material KLR-A32-2.2-2.0-K83 556 2.2 mm 8 mm ML17-LL 3 x M3 x 0.5 Dimensions (mm) 20 5 l 2.5 13 2 x (0.25 x 16) 38 ø 3.2 (2x) 3.6 3 x (M3 x 0.5) l 30.8 ø 0.25 (32x) 24.8 Copyright Pepperl+Fuchs Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com ø 2.2 Array 2m 8 mm 2.5 KHR-A02-2.2-2.0-K127 1 mm SU19 SU17.1 PVC 15 2m 8 mm 20 KHR-C02-1.0-2.0-K129 1.3 mm 8 mm 19 2m SU18 High Power SU18 High Speed Dimensions (mm) 2.5 KLR-C02-1.3-2.0-K130 Sensing Range 5.1 Photoelectric Sensors, Standard Sensors, Fiber optic cables .3 Compatible Sensors 15 Cable Fiber Sheathing Length Diameter Material 20 Model Number 2.5 2 11 Rectangular ø2.2x2 10 20 Photoelectric Sensors Fiber optic cables Plastic Fiber Optic Cables Diffuse Plastic Fiber Optic Cables HPF-D012 Cable Fiber Sheathing Length Diameter Material 2m 2m 2m 2.2 mm 1.0 mm 2.2 mm Black polyethylene Black polyethylene ML17-LL MHP-FR Compatible Sensors SU18 High Power SU18 High Speed SU19 SU17.1 ML17-LL MHP-FR SU18 High Power SU18 High Speed SU19 SU17.1 46 mm 162 mm 52 mm 21 mm Sensing Range 214 mm 34 mm 34 mm 182 mm 46 mm 12 mm 29 mm 5 mm 5 mm 25 mm ML17-LL 11 mm MHP-FR not compatible SU18 High Power 294 mm SU18 High Speed 47 mm Black SU19 47 mm polyethylene SU17.1 250 mm ML17-LL 51 mm MHP-FR 18 mm Refer to General Notes Relating to Product Information Pepperl+Fuchs Group www.pepperl-fuchs.com SU19 SU17.1 USA: +1 330 486 0001 fa-info@us.pepperl-fuchs.com Germany: +49 621 776-4411 fa-info@de.pepperl-fuchs.com .6 20.3 2 Photoelectric Sensors, Accessories Plastic 46 mm 2 Dimensions (mm) .7 .8 Dimensions (mm) 8.9 ø 4.1 3 15.7 Nut and washer: M6 x 0.75 Copyright Pepperl+Fuchs Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com .9 (Inches) Very elastic: Bend radius = 0.5 mm M6 X 0.75 (STAINLESS STEEL) 990 2 ø 2.2 .3 Photoelectric Sensors, Standard Sensors, Fiber optic cables HPF-D029 2.2 mm .6191 mm 2 Photoelectric Sensors, Optical Data Couplers HPF-D070-H 2m .5 SU18 High Power SU18 High Speed 2 Photoelectric Sensors, Light Grids Model Number .4 2 Sensing Range Photoelectric Sensors, Standard Sensors, Slot sensors High Flex Cable .2 2 Compatible Sensors Photoelectric Sensors, Standard Sensors, Color sensors HPF-D032 2 Photoelectric Sensors, Standard Sensors, Contrast and luminescence sensors .3 2 Cable Fiber Sheathing Length Diameter Material Photoelectric Sensors, Standard Sensors, Distance sensors Photoelectric Sensors, Standard Sensors, Fiber optic sensors .3 2 Model Number Photoelectric Sensors, Standard Sensors, Fiber optic sensors 2 Array (cont.) Photoelectric Sensors, Standard Sensors, Slot sensors for SU18, SU19, SU17.1, ML17-LL, and MHP-FR Sensors Very elastic: Bend radius = 4mm for moving equipment 557 Photoelectric Sensors Fiber optic cables Plastic Fiber Optic Cables Diffuse Plastic Fiber Optic Cables for SU18, SU19, SU17.1, ML17-LL, and MHP-FR Sensors Specialty Versions 2 Model Number Cable Fiber Sheathing Length Diameter Material Compatible Sensors Sensing Range SU18 High Power 29 mm SU18 High Speed 29 mm Black SU19 29 mm polyethylene SU17.1 17 mm ML17-LL 29 mm MHP-FR not compatible SU18 High Power 274 mm SU18 High Speed 44 mm SU19 44 mm Photoelectric Sensors, Standard Sensors, Fiber optic cables .3 HPF-D025 2m 1.0 mm Dimensions (mm) Chemical-resistant Nut and washer: M5 x 0.5 Narrow beam: Max. 4 mm light spot diameter Adapter included 4 2 - ø2.2 Fiber head ø1 mm 4 8 2000 20 10 233 mm ø 3. 2 11 SU17.1 8 PVC 2 2.2 mm M2 10 2 2m 4 3.3 KLR 00-2.2-2.0-K40 2 3.5 ø 2.5 8 8 5 20 HPF-D014 558 5m 2m 2.2 mm 2.2 mm Refer to General Notes Relating to Product Information Pepperl+Fuchs Group www.pepperl-fuchs.com Fluorine Fluorine USA: +1 330 486 0001 fa-info@us.pepperl-fuchs.com N/A N/A ø 6.35 SU18 High Power SU18 High Speed Thru-beam operation SU19 N/A SU17.1 N/A ML17-LL N/A MHP-FR not compatible SU18 High Power N/A SU18 High Speed N/A SU19 N/A SU17.1 N/A ML17-LL N/A MHP-FR N/A SU18 High Power 224 mm SU18 High Speed 36 mm SU19 36 mm SU17.1 109 mm ML17-LL 36 mm MHP-FR 15 mm Germany: +49 621 776-4411 fa-info@de.pepperl-fuchs.com 2.53 3 1 30 l 100 10.5 15 ø1.25 2 ø 2.2 PTFE 19 mm ø1.25 ø4 ø4 1.25 mm MHP-FR Convergent operation Diffuse operation Fluid detection 6.4 8 20 5000 200 Chemical-resistant level indication l 2 16 1900 ø5 HPF-D027-L05 2m 52 mm ø6 KLR-C02-1.25-2.0-K147 ML17-LL 2xø1 Copyright Pepperl+Fuchs Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com Chemical-resistant level indication Photoelectric Sensors Fiber optic cables Plastic Fiber Optic Cables Diffuse Plastic Fiber Optic Cables for SU18, SU19, SU17.1, ML17-LL, and MHP-FR Sensors 2.2 mm Threaded Cylindrical Model Number HPF-T004-H PVC Cable Fiber Sheathing Length Diameter Material 2m 2.2 mm MHP-FR SU18 High Power SU18 High Speed ø2.2 Photoelectric Sensors, Accessories ø4 ø1.25 22 5 Sensing Range 80 mm 20 mm Liquid level measurement Thru-beam Plastic Fiber Optic Cables 68 mm 13 mm not compatible 1360 mm 400 mm SU19 400 mm SU17.1 1156 mm ML17-LL 218 mm MHP-FR 90 mm Compatible Sensors Sensing Range SU18 High Power 1294 mm SU18 High Speed 190 mm 190 mm polyethylene SU17.1 1100 mm ML17-LL 263 mm MHP-FR 90 mm Germany: +49 621 776-4411 fa-info@de.pepperl-fuchs.com Dimensions (mm) ø2.5 fiber optic core x 1 20 mm SU19 USA: +1 330 486 0001 fa-info@us.pepperl-fuchs.com .3 15 ø1.5 fiber optic core x 1 l 10.5 15 15 ø 2.2 SU17.1 ML17-LL Photoelectric Sensors, Optical Data Couplers SU19 .9 2 for SU18, SU19, SU17.1, ML17-LL, and MHP-FR Sensors Black Refer to General Notes Relating to Product Information Pepperl+Fuchs Group www.pepperl-fuchs.com SU18 High Power SU18 High Speed not compatible ø4 PVC Compatible Sensors 26 mm 2 15 2000 Photoelectric Sensors, Standard Sensors, Fiber optic cables 2m 1 mm MHP-FR 12.8 10.5 ø 2.2 KLE-C01-2.2-2.0-K117 2m ML17-LL 26 mm .8 25° ø1 KLE-C01-1.0-2.0-K105 Cable Fiber Sheathing Length Diameter Material SU17.1 26 mm .7 150° Photoelectric Sensors, Light Grids Model Number SU19 .6 2000 ø2 Nonthreaded Cylindrical PVC .626 mm 2 Dimensions (mm) ø3 All thru-beam mode plastic fiber optic cables are sold as pairs. .5 SU18 High Speed 6 1.25 mm 26 mm 2 15.5 5 2m SU18 High Power 2 Photoelectric Sensors, Standard Sensors, Slot sensors .4 2 Sensing Range Photoelectric Sensors, Standard Sensors, Slot sensors .2 2 Compatible Sensors Photoelectric Sensors, Standard Sensors, Color sensors KLR-C02-1.25-2.0-K128 2 Photoelectric Sensors, Standard Sensors, Contrast and luminescence sensors .3 2 Cable Fiber Sheathing Length Diameter Material Photoelectric Sensors, Standard Sensors, Distance sensors Photoelectric Sensors, Standard Sensors, Fiber optic sensors .3 2 Model Number Photoelectric Sensors, Standard Sensors, Fiber optic sensors 2 Specialty Versions (cont.) Dimensions (mm) Copyright Pepperl+Fuchs Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 559 Photoelectric Sensors Fiber optic cables Plastic Fiber Optic Cables Thru-beam Plastic Fiber Optic Cables for SU18, SU19, SU17.1, ML17-LL, and MHP-FR Sensors Model Number Cable Fiber Sheathing Length Diameter Material .3 Photoelectric Sensors, Standard Sensors, Fiber optic cables HPF-T003 HPF-T001 FEF-PLT1 FEF-PLT1-L2 FEF-PLT1-L5 FEF-PLT1-L10 KLE-C01-2.2-2.0-K116 560 2m 2m 1m 2m 5m 10 m 2m 2.2 mm 2.2 mm 2.2 mm 2.2 mm 2.2 mm 2.2 mm Sensing Range SU18 High Power 1294 mm SU18 High Speed 213 mm Black SU19 213 mm polyethylene SU17.1 1100 mm ML17-LL 123 mm MHP-FR 63 mm SU18 High Power 2470 mm SU18 High Speed 370 mm SU19 370 mm polyethylene SU17.1 2100 mm ML17-LL 363 mm MHP-FR 170 mm SU18 High Power 25620 mm SU18 High Speed 2867 mm Nut and washer: M4 x 0.7 Black SU19 2867 mm polyethylene SU17.1 10488 mm ML17-LL 3528 mm MHP-FR 1300 mm Black polyethylene SU18 High Power 22859 mm SU18 High Speed 2558 mm SU19 2558 mm SU17.1 19430 mm ML17-LL 3148 mm MHP-FR 1160 mm SU18 High Power 15853 mm SU18 High Speed 1774 mm 1774 mm 13475 mm ML17-LL 2183 mm MHP-FR 804 mm SU18 High Power, 6503 mm SU18 High Speed, 1049 mm Black SU19 1049 mm polyethylene SU17.1 5530 mm ML17-LL 1291 mm MHP-FR 476 mm SU18 High Power 1500 mm SU18 High Speed 450 mm USA: +1 330 486 0001 fa-info@us.pepperl-fuchs.com 450 mm 1275 mm ML17-LL 241 mm MHP-FR 99 mm Germany: +49 621 776-4411 fa-info@de.pepperl-fuchs.com 25.4 17.5 ø 2.2 SU19 SU19 M8 x P1 ø 6.35 SU17.1 SU17.1 17.5 ø 2.2 Black PVC 25.4 ø 6.35 polyethylene 2.2 mm Dimensions (mm) Nut and washer: M4 x 0.7 Black Refer to General Notes Relating to Product Information Pepperl+Fuchs Group www.pepperl-fuchs.com Compatible Sensors M8 x P1 25.4 17.5 ø 2.2 ø 6.35 M8 x P1 25.4 17.5 ø 2.2 ø 6.35 M8 x P1 12 ø1.5 fiber optic core x 1 1 ø2 2 M3 x 0.5 2000 5 ø2.8 ø2.2 Threaded Cylindrical (cont.) All thru-beam mode plastic fiber optic cables are sold as pairs. Conduit ø3.3 Copyright Pepperl+Fuchs Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com Photoelectric Sensors Fiber optic cables Plastic Fiber Optic Cables Thru-beam Plastic Fiber Optic Cables for SU18, SU19, SU17.1, ML17-LL, and MHP-FR Sensors HPF-T010 KHE-C01-2.2-2.0-K136 PVC Cable Fiber Sheathing Length Diameter Material 2m 2m 2.2 mm Black polyethylene 2.2 mm Refer to General Notes Relating to Product Information Pepperl+Fuchs Group www.pepperl-fuchs.com PVC USA: +1 330 486 0001 fa-info@us.pepperl-fuchs.com SU19 SU17.1 ML17-LL MHP-FR Compatible Sensors SU18 High Power SU18 High Speed SU19 SU17.1 ML17-LL MHP-FR Compatible Sensors 450 mm 450 mm 1275 mm 241 mm 99 mm Sensing Range 872 mm 228 mm 228 mm 1208 mm 157 mm 74 mm Sensing Range SU18 High Power 964 mm SU18 High Speed 150 mm SU19 150 mm SU17.1 820 mm ML17-LL 116 mm MHP-FR 73 mm SU18 High Power 200 mm SU18 High Speed 50 mm SU19 50 mm SU17.1 170 mm ML17-LL 32 mm MHP-FR 13 mm Germany: +49 621 776-4411 fa-info@de.pepperl-fuchs.com Conduit ø3.3 14 3 M6 x 0.75 2000 Dimensions (mm) 80 17 5 2000 12 ø 2.5 M4 (P=0.7) ø2.2 ø4 ø2 ø1.5 fiber optic core x 1 .3 15 Dimensions (mm) ø2.2 SU18 High Speed 1500 mm .9 10.5 Photoelectric Sensors, Accessories SU18 High Power 48 mm not compatible ø3 M3 x 0.5 ø4 MHP-FR .8 5 2 Photoelectric Sensors, Standard Sensors, Fiber optic cables 2.2 mm ML17-LL 255 mm .7 1 2 l Nut and washer: M4 x 0.7 19,56 0,51 ø 0,5 Copyright Pepperl+Fuchs Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com l 2,54 Conduit ø3.5 ø 2,2 2m SU17.1 70 mm ø0.25 fiber optic .6 core x 4 12 ø 2.2 Cable Fiber Sheathing Length Diameter Material Side-view/Periscope Model Number PVC SU19 .670 mm 2 Dimensions (mm) Photoelectric Sensors, Light Grids 2.2 mm PVC .5 SU18 High Speed 2 Photoelectric Sensors, Optical Data Couplers ø1 KLE 00-2.2-2.0-K55 2m 1 mm 300 mm ø 1.5 Model Number 2m SU18 High Power 2 ø 4,75 Bendable Probe .4 2 Sensing Range Photoelectric Sensors, Standard Sensors, Slot sensors KLE-C01-2.2-2.0-K115 .2 2 Compatible Sensors Photoelectric Sensors, Standard Sensors, Color sensors KLE-C04-1.0-2.0-K104 2 Photoelectric Sensors, Standard Sensors, Contrast and luminescence sensors .3 2 Cable Fiber Sheathing Length Diameter Material Photoelectric Sensors, Standard Sensors, Distance sensors Photoelectric Sensors, Standard Sensors, Fiber optic sensors .3 2 Model Number Photoelectric Sensors, Standard Sensors, Fiber optic sensors 2 Threaded Cylindrical (cont.) 8.5 Photoelectric Sensors, Standard Sensors, Slot sensors All thru-beam mode plastic fiber optic cables are sold as pairs. 561 Photoelectric Sensors Fiber optic cables Plastic Fiber Optic Cables Thru-beam Plastic Fiber Optic Cables for SU18, SU19, SU17.1, ML17-LL, and MHP-FR Sensors Rectangular Model Number KHE-A01-1.0-2.0-K138 562 2m 2.2 mm 1.0 mm PVC Black polyethylene Cable Fiber Sheathing Length Diameter Material 2m 1 mm Refer to General Notes Relating to Product Information Pepperl+Fuchs Group www.pepperl-fuchs.com PVC USA: +1 330 486 0001 fa-info@us.pepperl-fuchs.com (Inches) SU19 153 mm SU17.1 810 mm ML17-LL 153 mm MHP-FR not compatible SU18 High Power 600 mm SU18 High Speed 150 mm 150 mm 510 mm ML17-LL 96 mm MHP-FR 39 mm SU18 High Power 475 mm SU18 High Speed 115 mm SU19 115 mm 5 2000 ø2 Conduit ø3.5 2 Operating temperature: -55 °C to +115 °C SU17.1 404 mm ML17-LL 76 mm MHP-FR 31 mm SU18 High Power 171 mm SU18 High Speed 28 mm SU19 28 mm SU17.1 145 mm ML17-LL 41 mm MHP-FR not compatible Compatible Sensors Sensing Range SU18 High Power 100 mm SU18 High Speed 25 mm Adapter included Dimensions (mm) 9.96 ø0.5 SU19 25 mm SU17.1 85 mm ML17-LL 16 mm MHP-FR not compatible Germany: +49 621 776-4411 fa-info@de.pepperl-fuchs.com 15 5 SU19 SU17.1 ø1 fiber optic core x 1 ø2.2 PVC 153 mm 2.5 2000 2 x ø2.2 10.5 15 4 Copyright Pepperl+Fuchs Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com ø2.2 HPF-T007 2m 2.2 mm SU18 High Speed ø4 KHTE-C01-2.2-2.0-K118 2m Plastic 953 mm 3 KHE-C01-2.2-2.0-K140 330 mm 2.2 mm SU18 High Power Dimensions (mm) 4 Photoelectric Sensors, Standard Sensors, Fiber optic cables HPF-T050 Sensing Range 1.98 .3 Compatible Sensors 6 Cable Fiber Sheathing Length Diameter Material 2.41 Model Number 2.96 2 9.96 Side-view/Periscope (cont.) All thru-beam mode plastic fiber optic cables are sold as pairs. Photoelectric Sensors Fiber optic cables Plastic Fiber Optic Cables Thru-beam Plastic Fiber Optic Cables for SU18, SU19, SU17.1, ML17-LL, and MHP-FR Sensors Model Number HPF-T022-H 2m 2.2 mm 2.2 mm Refer to General Notes Relating to Product Information Pepperl+Fuchs Group www.pepperl-fuchs.com 100 mm ML17-LL MHP-FR SU18 High Speed 100 mm SU19 100 mm MHP-FR USA: +1 330 486 0001 fa-info@us.pepperl-fuchs.com 357 mm 67 mm 28 mm SU18 High Power 140 mm SU18 High Speed 35 mm SU19 35 mm SU17.1 polyethylene 28 mm 420 mm SU17.1 Black 67 mm SU18 High Power ML17-LL PVC 357 mm 119 mm 22 mm MHP-FR 9 mm Compatible Sensors Sensing Range SU18 High Power 10.7 mm 10.7 mm SU19 10.7 mm SU17.1 10.7 mm ML17-LL 10.7 mm MHP-FR 10.7 mm Germany: +49 621 776-4411 fa-info@de.pepperl-fuchs.com 10 M2 x 0.4 Thru-hole thread 2 x ø3.2 4 x 90° l ø0.25 fiber optic core x 16 15 2.5 4 x ø6 3.5 2.5 5.3 l M3 x 0.5 Thru-hole thread 2.5 10 .3 ø2.2 23 18 3 5 Array fiber core 0.25 x 16 ML17-LL SU18 High Speed PMMA resin .9 Heat resistant ABS resin (black) ø2.2 SU19 30 18.5 .8 Photoelectric Sensors, Accessories 100 mm 45 2 L 2.5 420 mm 2 2.5 SU18 High Power SU18 High Speed SU17.1 PVC 54 mm .7 10 PVC 568 mm 5 MHP-FR 3600 mm 12 5 1 ML17-LL 682 mm .6 5.44 SU17.1 Cable Fiber Sheathing Length Diameter Material 2m SU19 682 mm 71.3 64 ø2.2 2.2 mm PVC .6 2 Dimensions (mm) Photoelectric Sensors, Light Grids 2m 2.2 mm .5 SU18 High Speed 4235 mm 4.5 2m 2.2 mm 2 Photoelectric Sensors, Standard Sensors, Fiber optic cables KLE-A32-2.8-2.0-K142 2m 2 Sensing Range SU18 High Power .4 2 2.5 KLE-A16-2.2-2.0-K110 Compatible Sensors Photoelectric Sensors, Standard Sensors, Slot sensors KLE-A16-2.2-2.0-K109 Slot 2 Photoelectric Sensors, Standard Sensors, Color sensors .2 Photoelectric Sensors, Standard Sensors, Contrast and luminescence sensors .3 HPF-T021WT 2 Cable Fiber Sheathing Length Diameter Material Photoelectric Sensors, Standard Sensors, Slot sensors 2 Photoelectric Sensors, Standard Sensors, Distance sensors Photoelectric Sensors, Standard Sensors, Fiber optic sensors .3 2 Model Number Photoelectric Sensors, Standard Sensors, Fiber optic sensors 2 Array Photoelectric Sensors, Optical Data Couplers All thru-beam mode plastic fiber optic cables are sold as pairs. Dimensions (mm) 10.2 33 7.9 6.6 10.7 8-32 tapped thru hole Copyright Pepperl+Fuchs Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 2032 28.4 14.2 19.1 563 Photoelectric Sensors Fiber optic cables Plastic Fiber Optic Cables Thru-beam Plastic Fiber Optic Cables for SU18, SU19, SU17.1, ML17-LL, and MHP-FR Sensors High Flex Cable Model Number SU18 High Power 5 mm SU18 High Speed 5 mm PVC Cable Fiber Sheathing Length Diameter Material HPF-T009 2m HPF-T008 2m HPF-T024 2m 1.0 mm 1.0 mm 1.0 mm SU19 5 mm 5 mm ML17-LL 5 mm MHP-FR not compatible Compatible Sensors Sensing Range SU18 High Power 194 mm 63 mm SU19 63 mm SU17.1 165 mm Black polyethylene ML17-LL 57 mm MHP-FR not compatible SU18 High Power 194 mm SU18 High Speed 31 mm Black SU19 31 mm polyethylene SU17.1 165 mm ML17-LL 49 mm MHP-FR not compatible SU18 High Power 165 mm SU18 High Speed 27 mm SU19 27 mm Black polyethylene SU17.1 140 mm ML17-LL 26 mm MHP-FR not compatible SU18 High Power 957 mm SU18 High Speed 154 mm SU19 154 mm SU17.1 813 mm ML17-LL 164 mm MHP-FR 67 mm Conduit ø3.5 40.7 2000 29 SU17.1 SU18 High Speed ø 2.2 not compatible ø4 MHP-FR 4 10 mm 12 ML17-LL 15 ø 1.25 2 x ø 3.2 4.5 10.5 2.5 10 mm 5 10 mm 10 SU19 SU17.1 PVC 10.5 ø 1.25 15 ø1.25 ø1.25 2 x ø3.2 Conduit ø3.5 ø2.2 1.25 mm 10 mm l 3.5 ø4 2m SU18 High Speed 31.7 20 10 KLE-C02-1.25-2.0-K134 1.25 mm 10 mm 5 2m SU18 High Power Dimensions (mm) 7 KLE-C02-1.25-2.0-K135 Sensing Range 5 Photoelectric Sensors, Standard Sensors, Fiber optic cables .3 Compatible Sensors 5 Cable Fiber Sheathing Length Diameter Material 5 Model Number 7 2 Slot (cont.) All thru-beam mode plastic fiber optic cables are sold as pairs. Dimensions (mm) Elastic: Bend radius = 4 mm for moving equipment Adapter included Elastic: Bend radius = 4 mm for moving equipment Adapter included Very elastic: Bend radius = 1 mm for stationary equipment ø 0.5 (Core) Adapter included Detection head M3 2 – C0.3 11 2000 min Nut and washer: M3 x 0.5 Very elastic: Bend radius = 0.5 mm 7.1 M2.6 x 0.45 HPF-T070-H 564 990 mm 2.2 mm Black polyethylene Refer to General Notes Relating to Product Information Pepperl+Fuchs Group www.pepperl-fuchs.com USA: +1 330 486 0001 fa-info@us.pepperl-fuchs.com Germany: +49 621 776-4411 fa-info@de.pepperl-fuchs.com 3 16.8 M4 X 0.7 (STAINLESS STEEL) 13 ø 2.2 990 Copyright Pepperl+Fuchs Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com Photoelectric Sensors Fiber optic cables Plastic Fiber Optic Cables Threaded Cylindrical Model Number LMR 00-1.5-1.0-K154 LMR 00-2.0-1.0-K156 polyethylene Black polyethylene Cable Fiber Sheathing Length Diameter Material 990 mm 2.2 mm 1m 2.29 mm Refer to General Notes Relating to Product Information Pepperl+Fuchs Group www.pepperl-fuchs.com Stainless Steel Stainless Steel USA: +1 330 486 0001 fa-info@us.pepperl-fuchs.com .6 127 mm Compatible Sensors Sensing Range SU19 SU17.1 ML17-LL MHP-FR SU18 High Power SU18 High Speed SU19 SU17.1 ML17-LL MHP-FR 127 mm 670 mm 118 mm .7 .8 Nut and washer: M4 x 0.7 59 mm 4205 mm 677 mm 677 mm 3400 mm 467 mm not compatible Sharp narrow beam 2 .9 .3 Heat resistant to 221°F Adapter included Glass Fiber Optic Cables Diffuse Mode Glass Fiber Optic Cables SU18, SU19, SU17.1 and ML17-LL Sensors SU18 High Power 185 mm SU18 High Speed 30 mm Dimensions (mm) 990 190.5 12.7 13.2 SU19 30 mm SU17.1 157 mm ML17-LL 109 mm MHP-FR not compatible SU18 High Power 190 mm SU18 High Speed 116 mm SU19 116 mm SU17.1 152 mm ML17-LL 86 mm MHP-FR not compatible Germany: +49 621 776-4411 fa-info@de.pepperl-fuchs.com .6 2 Photoelectric Sensors, Standard Sensors, Fiber optic cables 1.0 mm Black .5 SU18 High Speed 2 Dimensions (mm) Photoelectric Sensors, Accessories 2m 2.2 mm 788 mm 2 Photoelectric Sensors, Optical Data Couplers 2m SU18 High Power 2 Photoelectric Sensors, Light Grids .4 2 Sensing Range Photoelectric Sensors, Standard Sensors, Slot sensors HPF-T023 .2 2 Compatible Sensors Photoelectric Sensors, Standard Sensors, Color sensors HPF-T012 2 Photoelectric Sensors, Standard Sensors, Contrast and luminescence sensors .3 2 Cable Fiber Sheathing Length Diameter Material Photoelectric Sensors, Standard Sensors, Distance sensors Photoelectric Sensors, Standard Sensors, Fiber optic sensors .3 2 Model Number Photoelectric Sensors, Standard Sensors, Fiber optic sensors 2 Specialty Versions Photoelectric Sensors, Standard Sensors, Slot sensors Thru-beam Plastic Fiber Optic Cables for SU18, SU19, SU17.1, ML17-LL, and MHP-FR Sensors All thru-beam mode plastic fiber optic cables are sold as pairs. 2.2 Ø 3.3 STAINLESS STEEL (3X) M3 X 0.5 (STAINLESS STEEL) L 30 50.8 152.4 20.3 3 3x ø5.97 2x ø2.16 M6 x P0.75 ø 2.29 glass fiber bundle ø5 17.8 30 Copyright Pepperl+Fuchs Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 565 Photoelectric Sensors Fiber optic cables Glass Fiber Optic Cables Diffuse Mode Glass Fiber Optic Cables SU18, SU19, SU17.1 and ML17-LL Sensors Model Number Cable Fiber Sheathing Length Diameter Material Photoelectric Sensors, Standard Sensors, Fiber optic cables .3 LMR 00-2.0-2.0-K156 Bendable Probe Model Number LMR 00-1.5-1.1-K155 2m 2.29 mm Compatible Sensors Sensing Range SU18 High Power 190 mm 116 mm SU19 116 mm SU17.1 152 mm ML17-LL 86 mm MHP-FR not compatible Compatible Sensors Sensing Range SU18 High Power 160 mm SU18 High Speed 76 mm SU19 76 mm SU17.1 136 mm ML17-LL 85 mm Cable Fiber Sheathing Length Diameter Material 1143 mm 2.2 mm Stainless Steel LMR 00-1.5-1.0-K157 LCR 00-2.0-0.9-K158 566 990 mm 2.2 mm 914 mm 2 mm Pepperl+Fuchs Group www.pepperl-fuchs.com M6 x P0.75 ø 2.29 glass fiber bundle 1143 2.2 Ø 3.3 STAINLESS STEEL (3X) M6 X 0.75 (STAINLESS STEEL) 76 mm SU19 76 mm SU17.1 136 mm ML17-LL 85 mm MHP-FR not compatible SU18 High Power 190 mm SU18 High Speed 116 mm USA: +1 330 486 0001 fa-info@us.pepperl-fuchs.com 152 mm ML17-LL 86 mm MHP-FR not compatible Germany: +49 621 776-4411 fa-info@de.pepperl-fuchs.com 12.7 ø3 SU18 High Speed SU17.1 190.5 17 160 mm 116 mm Dimensions (mm) 89 SU18 High Power SU19 17.8 ø5 30 Sensing Range PVC 3x ø5.97 2x ø2.16 Compatible Sensors Stainless Steel Refer to General Notes Relating to Product Information 3 not compatible Cable Fiber Sheathing Length Diameter Material 152.4 50.8 20.3 MHP-FR Side-view / Periscope Model Number L 30 SU18 High Speed Stainless Steel Dimensions (mm) Dimensions (mm) 990 190.5 12.7 40.1 2.2 36.6 Ø 3.3 STAINLESS STEEL (3X) 20 12.5 R 3 ø 4.1 M6 X 0.75 (STAINLESS STEEL) l 152.4 35 17.8 7.4 2 Threaded Cylindrical (cont.) 3.2 ø 2.2 Copyright Pepperl+Fuchs Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com Photoelectric Sensors Fiber optic cables Glass Fiber Optic Cables Thru-Beam Mode Glass Fiber Optic Cables for SU18, SU19, SU17.1 and ML17-LL Sensors Array Model Number LCE 00-1.6-0.5-K152 520.7 mm 2.2 mm USA: +1 330 486 0001 fa-info@us.pepperl-fuchs.com Compatible Sensors 616 mm 197 mm not compatible M4 x P0.7 990 88.9 ø 1.8 12.7 4.75 M4 X 0.7 (STAINLESS STEEL) 892 mm SU18 High Speed 144 mm SU19 144 mm 616 mm 197 mm not compatible Compatible Sensors Sensing Range SU18 High Power 2681 mm SU18 High Speed 432 mm ø 1.02 glass fiber bundle ø 3.3 STAINLESS STEEL 12.7 ø 2.2 Dimensions (mm) 990 49 26.2 12.7 12.7 R ø 3.3 12.7 ø 3.3 STAINLESS STEEL ø 2.2 M4 X 0.7 (STAINLESS STEEL) 15.2 3.3 M2.6 X 0.45 Dimensions (mm) 520.7 40.6 8.9 SU19 432 mm SU17.1 761 mm ML17-LL 246 mm MHP-FR not compatible Germany: +49 621 776-4411 fa-info@de.pepperl-fuchs.com ø 2.16 tube 31.8 MHP-FR .3 30 Dimensions (mm) 22.9 2 .917.8 2x ø 5.97 collar M2.6 x P0.45 Sensing Range SU18 High Power SU17.1 .8 ø5 2 Photoelectric Sensors, Accessories 892 mm 144 mm SU17.1 3 Sensing Range 144 mm ML17-LL PVC 197 mm SU19 MHP-FR Stainless Steel 616 mm SU18 High Speed ML17-LL Cable Fiber Sheathing Length Diameter Material Refer to General Notes Relating to Product Information Pepperl+Fuchs Group www.pepperl-fuchs.com Stainless Steel 144 mm 1016 .7 28 17.8 not compatible SU18 High Power Cable Fiber Sheathing Length Diameter Material 990 mm 2.2 mm Compatible Sensors .6 144 mm 2 Dimensions (mm) Photoelectric Sensors, Standard Sensors, Fiber optic cables LME 00-1.2-1.0-K153 MHP-FR 2 Photoelectric Sensors, Light Grids 990 mm 2.2 mm SU17.1 ML17-LL Cable Fiber Sheathing Length Diameter Material Side-view /Periscope Model Number 1.02 mm SU19 .6 892 mm Photoelectric Sensors, Standard Sensors, Slot sensors LME 00-1.2-1.0-K150 1m SU18 High Speed Stainless Steel 2 Sensing Range SU18 High Power .5 2 34.3 12.7 12.7 17.8 15.2 Bendable Probe Model Number .4 Compatible Sensors Photoelectric Sensors, Standard Sensors, Slot sensors .2 2 Photoelectric Sensors, Standard Sensors, Color sensors LME 00-1.0-1.0-K151 2 Cable Fiber Sheathing Length Diameter Material Photoelectric Sensors, Standard Sensors, Contrast and luminescence sensors .3 2 Photoelectric Sensors, Standard Sensors, Distance sensors Photoelectric Sensors, Standard Sensors, Fiber optic sensors .3 2 Model Number Photoelectric Sensors, Standard Sensors, Fiber optic sensors 2 Threaded Cylindrical Photoelectric Sensors, Optical Data Couplers Sold individually. To complete a thru-beam pair, two units are required. 2x ø 5.97 collar 3.3 7.9 Copyright Pepperl+Fuchs Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com Optical fiber bundle 0.15 x 14.7 567 Photoelectric Sensors Fiber optic cables Glass Fiber Optic Cables Diffuse Mode Glass Fiber Optic Cables for RL(K)61-LL, MPG and MHP-F Sensors Cylindrical Sensing Head 2 Photoelectric Sensors, Standard Sensors, Fiber optic cables .3 Model Number FE-BHS1S-3* Cable Fiber Length Diameter 3 ft FE-BHS3S-3* FE-BFS6S-3* FE-BTS6S-3* 3 ft FE-BTS6S-5 FE-BTS6S-5HT† FE-BTS6M-3* 5 mm L 27.9 25.4 50.8 MHP-F Infrared 11 mm RL(K)61-LL 20 mm 6.4 1.1 4.6 7.9 MPG Infrared 23 mm MHP-F Visible Red 10 mm 12.7 Optical fiber bundle ø .69 27.9 L 27.9 25.4 50.8 Stainless Steel MHP-F Infrared 30 mm 3 ft Stainless Steel 5 ft 3 ft 3.2 mm Stainless Steel 5 ft 3 ft PVC 5 ft Refer to General Notes Relating to Product Information Pepperl+Fuchs Group www.pepperl-fuchs.com 152.4 RL(K)61-LL 46 mm 6.4 1.5 4.6 7.9 MPG Infrared 51 mm MHP-F Visible Red 48 mm MHP-F Infrared 95 mm RL(K)61-LL 170 mm MPG Infrared 190 mm MHP-F Visible Red 45 mm MHP-F Infrared 90 mm RL(K)61-LL 160 mm MPG Infrared 180 mm MHP-F Visible Red 45 mm MHP-F Infrared 90 mm RL(K)61-LL 160 mm MPG Infrared 180 mm 12.7 Optical fiber bundle ø 1.2 27.9 L 27.9 50.8 152.4 12.7 6.4 4.6 7.9 SST end tip 12.7 Optical fiber bundle ø 3.2 27.9 L 38.1 50.8 15 USA: +1 330 486 0001 fa-info@us.pepperl-fuchs.com Germany: +49 621 776-4411 fa-info@de.pepperl-fuchs.com 152.4 6.4 5/16 x 24 SST Thd 2 jam nuts included 12.7 Optical fiber bundle ø 3.2 27.9 L 38.1 50.8 15 152.4 6.4 5/16 x 24 SST Thd 2 jam nuts included Optical fiber bundle ø 3.2 * Sensing ranges based on this model. † High-temperature model. 568 152.4 SST end tip 3.2 mm FE-BTS6M-5 MHP-F Visible Red Dimensions (mm) 12.7 5 ft FE-BTS6S-3HT† Sensing Range SST end tip 3.2 mm FE-BFS6S-5 Stainless Steel 5 ft 1.2 mm FE-BHS3S-5 Compatible Sensors 12.7 0.69 mm FE-BHS1S-5 Sheathing Material Copyright Pepperl+Fuchs Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 12.7 27.9 Photoelectric Sensors Fiber optic cables Glass Fiber Optic Cables Diffuse Mode Glass Fiber Optic Cables for RL(K)61-LL, MPG and MHP-F Sensors FE-BNSRA5S-3* FE-BNSRA5S-5 FE-BNSRA5M-3 Cable Fiber Length Diameter 3 ft 2.3 mm 5 ft 3 ft Sheathing Material Stainless Steel 2.3 mm PVC MHP-F Infrared 39 mm RL(K)61-LL 69 mm MPG Infrared 77 mm Compatible Sensors Sensing Range MHP-F Visible Red 32 mm MHP-F Infrared 62 mm RL(K)61-LL 155 mm MPG Infrared 170 mm MHP-F Visible Red 32 mm MHP-F Infrared 62 mm RL(K)61-LL 155 mm MPG Infrared 170 mm .6 76.2 L .7 35.6 2 50.8 6.4 2.3 2 Dimensions (mm) 7.9 SST end tip Optical fiber bundle ø 1.5 .8 25.4 15.2 L 50.8 6.4 3.1 ø 5.3 7.9 SST end tip 4.75 Optical fiber bundle ø 2.3 L 50.8 27.9 15.2 .9 152.4 12.7 27.9 Dimensions (mm) 152.4 12.7 27.9 152.4 6.4 3.1 ø 5.3 7.9 SST end tip 4.75 Optical fiber bundle ø 2.3 2 12.7 27.9 .3 Photoelectric Sensors, Standard Sensors, Fiber optic cables Side View/Periscope Sensing Head Model Number 12 mm .6 2 Photoelectric Sensors, Accessories 5 ft Stainless Steel MHP-F Visible Red 2 Photoelectric Sensors, Optical Data Couplers 1.5 mm .5 Sensing Range Photoelectric Sensors, Light Grids .4 3 ft 2 Compatible Sensors Photoelectric Sensors, Standard Sensors, Slot sensors .2 2 Sheathing Material Photoelectric Sensors, Standard Sensors, Slot sensors FE-BPS4S-5 2 Cable Fiber Length Diameter Photoelectric Sensors, Standard Sensors, Color sensors .3 FE-BPS4S-3* 2 Photoelectric Sensors, Standard Sensors, Contrast and luminescence sensors Model Number Photoelectric Sensors, Standard Sensors, Distance sensors Photoelectric Sensors, Standard Sensors, Fiber optic sensors .3 2 Photoelectric Sensors, Standard Sensors, Fiber optic sensors 2 Bendable Sensing Tip * Sensing ranges based on this model. Refer to General Notes Relating to Product Information Pepperl+Fuchs Group www.pepperl-fuchs.com USA: +1 330 486 0001 fa-info@us.pepperl-fuchs.com Germany: +49 621 776-4411 fa-info@de.pepperl-fuchs.com Copyright Pepperl+Fuchs Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 569 Photoelectric Sensors Fiber optic cables Glass Fiber Optic Cables Diffuse Mode Glass Fiber Optic Cables for RL(K)61-LL, MPG and MHP-F Sensors FE-BAS6S-3* 5 ft 3 ft 3.2 mm FE-BAS6S-5 FE-BTSAS6S-3* FE-BTSAS6M-3* 3 ft FE-BASTS6S-3* 3 ft PVC 5 ft 3 ft 3.2 mm FE-BASTS6S-5 Stainless Steel 5 ft 3.2 mm FE-BTSAS6M-5 Stainless Steel 5 ft 3.2 mm FE-BTSAS6S-5 Stainless Steel Stainless Steel Compatible Sensors Sensing Range MHP-F Visible Red 6 mm MHP-F Infrared 12 mm RL(K)61-LL 27 mm MPG Infrared 30 mm MHP-F Visible Red 45 mm MHP-F Infrared 97 mm RL(K)61-LL 160 mm MPG Infrared 180 mm MHP-F Visible Red 36 mm MHP-F Infrared 80 mm RL(K)61-LL 155 mm MPG Infrared 170 mm MHP-F Visible Red 36 mm MHP-F Infrared 80 mm RL(K)61-LL 155 mm MPG Infrared 170 mm MHP-F Visible Red 52 mm MHP-F Infrared 100 mm RL(K)61-LL 170 mm 5 ft MPG Infrared 190 mm Dimensions (mm) L 25.4 35.6 50.8 6.4 7.9 4.8 SST end tip Optical fiber bundle ø 1.2 12.7 27.9 L 27.9 50.8 15.2 Refer to General Notes Relating to Product Information Pepperl+Fuchs Group www.pepperl-fuchs.com USA: +1 330 486 0001 fa-info@us.pepperl-fuchs.com Germany: +49 621 776-4411 fa-info@de.pepperl-fuchs.com 152.4 6.4 SST end tip 9.7 R 12.7 27.9 Optical fiber bundle ø 3.2 L 18.3 12.7 35 50.8 152.4 6.4 4.75 5/16 x 24 SST Thd 2 jam nuts included 9.7 R Optical fiber bundle ø 3.2 12.7 27.9 L 15.7 38.1 50.8 12.7 4.75 152.4 6.4 5/16 x 24 SST Thd 2 jam nuts included 9.7 R Optical fiber bundle ø 3.2 12.7 27.9 L 27.9 50.8 15.2 152.4 6.4 ø 4.75 9.7 R 5/16 x 24 SST Thd 2 jam nuts included Optical fiber bundle ø 3.2 * Sensing ranges based on this model. 570 152.4 19 3 ft 1.2 mm FE-BHSRA3S-5 Sheathing Material 19 FE-BHSRA3S-3* Cable Fiber Length Diameter 19 Photoelectric Sensors, Standard Sensors, Fiber optic cables .3 Model Number 20.3 2 38.1 Right Angle Sensing Head Copyright Pepperl+Fuchs Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 12.7 27.9 Photoelectric Sensors Fiber optic cables Glass Fiber Optic Cables Diffuse Mode Glass Fiber Optic Cables for RL(K)61-LL, MPG and MHP-F Sensors 5 ft 3 ft Stainless Steel Stainless Steel 0.01” x 1.5” PVC MPG Infrared 212 mm MHP-F Visible Red 40 mm MHP-F Infrared 86 mm RL(K)61-LL 190 mm MPG Infrared 210 mm MHP-F Visible Red 46 mm MHP-F Infrared 104 mm RL(K)61-LL 205 mm MPG Infrared 230 mm MHP-F Visible Red 46 mm MHP-F Infrared 104 mm RL(K)61-LL 205 mm MPG Infrared 12.7 3.2 Optical fiber bundle 0.02" x 0.5" L 50.8 6.4 6.4 6.4 3.6 ø 3.18 Sensing tip, aluminum 9.7 .81 7.9 38.1 L 12.7 50.8 6.4 12.7 27.9 152.4 Sensing tip, aluminum 6.4 ø 4.75 thru hole (2) Optical fiber bundle 0.01" x 1.5" L 38.1 7.9 12.7 27.9 127 12.7 50.8 12.7 27.9 152.4 6.4 230 mm Sensing tip, aluminum 6.4 ø 4.75 thru hole (2) Optical fiber bundle 0.01" x 1.5" 2 .9 152.4 Sensing tip, aluminum 6.4 ø 6.4 thru hole (2) 19 2 Photoelectric Sensors, Accessories 0.01” x 1.5” 190 mm 6.4 .8 Photoelectric Sensors, Optical Data Couplers 3 ft RL(K)61-LL 50.8 12.7 Photoelectric Sensors, Light Grids 5 ft 92 mm .7 L 25.4 7.9 12.7 25.4 0.81 mm x 9.7 mm MHP-F Infrared .6 2 Dimensions (mm) 12.7 27.9 .3 Photoelectric Sensors, Standard Sensors, Fiber optic cables FE-BRL7M-3 3 ft Stainless Steel 42 mm .6 2 25.4 FE-BRL7S-5 5 ft MHP-F Visible Red 2 50.8 FE-BRL7S-3* 0.02” x 0.5” .5 Sensing Range 50.8 FE-BRL6S-5RA .4 3 ft 2 Compatible Sensors 19.1 Photoelectric Sensors, Standard Sensors, Slot sensors 25.4 FE-BRL6S-3RA* .2 2 Sheathing Material Photoelectric Sensors, Standard Sensors, Slot sensors FE-BRL6S-5 2 Cable Fiber Length Diameter Photoelectric Sensors, Standard Sensors, Color sensors .3 FE-BRL6S-3* 2 Photoelectric Sensors, Standard Sensors, Contrast and luminescence sensors Model Number Photoelectric Sensors, Standard Sensors, Distance sensors Photoelectric Sensors, Standard Sensors, Fiber optic sensors .3 2 Photoelectric Sensors, Standard Sensors, Fiber optic sensors 2 Array Sensing Head * Sensing ranges based on this model. Refer to General Notes Relating to Product Information Pepperl+Fuchs Group www.pepperl-fuchs.com USA: +1 330 486 0001 fa-info@us.pepperl-fuchs.com Germany: +49 621 776-4411 fa-info@de.pepperl-fuchs.com Copyright Pepperl+Fuchs Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 571 Photoelectric Sensors Fiber optic cables Glass Fiber Optic Cables Thru-Beam Mode Glass Fiber Optic Cables for RL(K)61-LL, MPG and MHP-F Sensors 2 Photoelectric Sensors, Standard Sensors, Fiber optic cables .3 Cylindrical Sensing Head Model Number FE-IHS1S-3* Cable Fiber Length Diameter 3 ft 0.69 mm FE-IHS1S-5 5 ft FE-IHS3S-3* 3 ft 1.2 mm FE-IHS3S-5 FE-IFS6S-3* FE-ITS6S-3* FE-ITS6S-3HT† FE-ITS6S-5 FE-ITS6S-5HT† FE-ITS6M-3* FE-IPS4S-3* 3 ft 3.2 mm Stainless Steel 5 ft 3 ft PVC 5 ft Cable Fiber Length Diameter 3 ft 1.5 mm FE-IPS4S-5 Stainless Steel 5 ft Bendable Sensing Tip Model Number Stainless Steel 3 ft 3.2 mm FE-ITS6M-5 Stainless Steel 5 ft 3.2 mm FE-IFS6S-5 Sheathing Material Sheathing Material Stainless Steel 5 ft Sold individually. To complete a thru-beam pair, two units are required. Compatible Sensors Sensing Range MHP-F Visible Red 90 mm MHP-F Infrared 210 mm RL(K)61-LL 460 mm MPG Infrared 510 mm MHP-F Visible Red 95 mm MHP-F Infrared 220 mm RL(K)61-LL 470 mm 1.5 MPG Infrared 520 mm Optical fiber bundle ø 1.2 MHP-F Visible Red 320 mm MHP-F Infrared 770 mm RL(K)61-LL 470 mm MPG Infrared 1300 mm MHP-F Visible Red 300 mm MHP-F Infrared 825 mm RL(K)61-LL 1305 mm MPG Infrared 1450 mm MHP-F Visible Red 300 mm MHP-F Infrared 825 mm RL(K)61-LL 1305 mm 5/16 x 24 SST Thd 2 jam nuts included MPG Infrared 1450 mm Optical fiber bundle ø 3.2 Compatible Sensors Sensing Range MHP-F Visible Red 190 mm MHP-F Infrared 560 mm RL(K)61-LL 900 mm MPG Infrared 1000 mm Dimensions (mm) L 27.9 25.4 6.4 12.7 1.1 12.7 7.9 27.9 SST end tip Optical fiber bundle ø .69 L 27.9 25.4 6.4 12.7 12.7 7.9 4.57 27.9 SST end tip L 27.9 6.4 12.7 12.7 7.9 27.9 SST end tip Optical fiber bundle ø 3.2 L 38.6 15 6.4 12.7 5/16 x 24 SST Thd 2 jam nuts included 27.9 Optical fiber bundle ø 3.2 L 38.1 15 6.4 12.7 27.9 Dimensions (mm) L 76.2 35.6 2.3 6.4 7.9 SST end tip Optical fiber bundle ø 1.5 * Sensing ranges based on this model. † High temperature model. 572 Refer to General Notes Relating to Product Information Pepperl+Fuchs Group www.pepperl-fuchs.com USA: +1 330 486 0001 fa-info@us.pepperl-fuchs.com Germany: +49 621 776-4411 fa-info@de.pepperl-fuchs.com Copyright Pepperl+Fuchs Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 12.7 27.9 Photoelectric Sensors Fiber optic cables Glass Fiber Optic Cables Thru-Beam Mode Glass Fiber Optic Cables Sold individually. To complete a thru-beam pair, two units are required. FE-IHSRA3S-5 FE-IAS6S-3* FE-IAS6S-5 FE-ITSAS6S-3* FE-ITSAS6S-5 FE-ITSAS6M-3* 3 ft 1.2 mm 5 ft 3 ft 3.2 mm 5 ft 3 ft 3.2 mm 5 ft 3 ft Sheathing Material Stainless Steel Stainless Steel Stainless Steel 3.2 mm FE-ITSAS6M-5 FE-IASTS6S-3* 5 ft 730 mm ø 5.3 3.1 .7 15.2 .8 6.4 7.9 SST end tip ø 4.75 Optical fiber bundle ø 2.3 MPG Infrared 810 mm Compatible Sensors Sensing Range MHP-F Visible Red 90 mm MHP-F Infrared 190 mm RL(K)61-LL 485 mm MPG Infrared 540 mm MHP-F Visible Red 340 mm MHP-F Infrared 950 mm RL(K)61-LL 1305 mm MPG Infrared 1450 mm MHP-F Visible Red 260 mm MHP-F Infrared 660 mm RL(K)61-LL 1150 mm MPG Infrared 1280 mm MHP-F Visible Red 260 mm MHP-F Infrared 660 mm RL(K)61-LL 1150 mm 5/16 x 24 SST Thd 2 jam nuts included MPG Infrared 1280 mm Optical fiber bundle ø 3.2 MHP-F Visible Red 300 mm MHP-F Infrared 800 mm Dimensions (mm) 25.4 35.6 7.9 4.8 L 6.4 SST end tip Optical fiber bundle ø 1.2 27.9 15.2 L 6.4 7.9 SST end tip 9.7 R Optical fiber bundle ø 3.2 L 18.3 35 12.7 4.75 .9 12.7 27.9 12.7 25.4 12.7 27.9 6.4 12.7 5/16 x 24 SST Thd 2 jam nuts included 2 27.9 9.7 R Optical fiber bundle ø 3.2 .3 L 15.7 38.1 4.75 12.7 6.4 12.7 27.9 9.7 R 3 ft 3.2 mm FE-IASTS6S-5 PVC RL(K)61-LL 25.4 2 Photoelectric Sensors, Standard Sensors, Fiber optic cables FE-IHSRA3S-3* Cable Fiber Length Diameter 400 mm .6 L Photoelectric Sensors, Accessories Model Number MHP-F Infrared .6 2 Dimensions (mm) Photoelectric Sensors, Optical Data Couplers Right Angle Sensing Head 180 mm 2 Photoelectric Sensors, Light Grids 5 ft Stainless Steel MHP-F Visible Red 2 Photoelectric Sensors, Standard Sensors, Slot sensors 19 19 2.3 mm .5 Sensing Range 19 .4 3 ft 2 Compatible Sensors Stainless Steel 5 ft RL(K)61-LL 1170 mm MPG Infrared 1300 mm L 27.9 15 20.3 .2 2 Sheathing Material 38.1 FE-INSRA5S-5 2 Cable Fiber Length Diameter Photoelectric Sensors, Standard Sensors, Slot sensors .3 FE-INSRA5S-3* 2 Photoelectric Sensors, Standard Sensors, Color sensors Model Number Photoelectric Sensors, Standard Sensors, Contrast and luminescence sensors 2 Photoelectric Sensors, Standard Sensors, Distance sensors Photoelectric Sensors, Standard Sensors, Fiber optic sensors .3 Side View/Periscope Sensing Head Photoelectric Sensors, Standard Sensors, Fiber optic sensors 2 for RL(K)61-LL, MPG and MHP-F Sensors 6.4 7.9 9.7 R 12.7 27.9 5/16 x 24 SST Thd 2 jam nuts included Optical fiber bundle ø 3.2 * Sensing ranges based on this model. Refer to General Notes Relating to Product Information Pepperl+Fuchs Group www.pepperl-fuchs.com USA: +1 330 486 0001 fa-info@us.pepperl-fuchs.com Germany: +49 621 776-4411 fa-info@de.pepperl-fuchs.com Copyright Pepperl+Fuchs Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 573 Photoelectric Sensors Fiber optic cables Glass Fiber Optic Cables Thru-Beam Mode Glass Fiber Optic Cables for RL(K)61-LL, MPG and MHP-F Sensors FE-IRL7S-3* 3 ft 0.01” x 1.5” FE-IRL7S-3R Stainless Steel 5 ft 3 ft 0.01” x 1.5” Stainless Steel MHP-F Infrared 700 mm RL(K)61-LL 1080 mm MPG Infrared 1200 mm MHP-F Visible Red 310 mm MHP-F Infrared 750 mm RL(K)61-LL 1125 mm MPG Infrared 1250 mm MHP-F Visible Red 300 mm MHP-F Infrared 740 mm RL(K)61-LL 1080 mm MPG Infrared 574 Refer to General Notes Relating to Product Information Pepperl+Fuchs Group www.pepperl-fuchs.com USA: +1 330 486 0001 fa-info@us.pepperl-fuchs.com 1200 mm Germany: +49 621 776-4411 fa-info@de.pepperl-fuchs.com L 7.9 25.4 3.2 12.7 280 mm 19.1 MHP-F Visible Red Dimensions (mm) 12.7 6.4 12.7 Sensing tip, aluminum 6.4 ø 3.18 thru hole (2) Optical fiber bundle 0.02" x 0.5" 27.9 L 7.9 38.1 12.7 6.4 12.7 25.4 5 ft Sensing Range 12.7 Sensing tip, aluminum 6.4 ø 4.75 thru hole (2) 27.9 Optical fiber bundle 0.01" x 1.5" L 28 15.4 FE-IRL6S-5 Stainless Steel Compatible Sensors 50.8 3 ft 0.02” x 0.5” FE-IRL7S-5 Sheathing Material 12.7 FE-IRL6S-3* Cable Fiber Length Diameter 38.1 Photoelectric Sensors, Standard Sensors, Fiber optic cables .3 Model Number 15 2.54 ø 5.54 6.4 2 7.92 Array Sensing Head Sold individually. To complete a thru-beam pair, two units are required. 12.7 Tubing Metal 9.7 R Collar ø 7.92 2X ø 4.75 25.4 50.8 Sensing Tip Optical fiber bundle 0.01" x 1.5" Copyright Pepperl+Fuchs Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 28 Photoelectric Sensors Fiber optic cables Glass Fiber Optic Cables 2m LMR 18-3.2-3.0-K1 1m 3m LCR 18-3.2-0.5-K2* 0.5 m LCR 18-3.2-2.0-K2 2m LMR 18-2.3-0.5-K2 LMR 18-2.3-0.5-K7 LMR 18-3.2-2.0-K4 0.5 m 0.5 m 2m PVC Stainless Steel 3.2 mm 2.3 mm 2.3 mm 3.2 mm PVC Stainless Steel OCT500-M1A 85 mm OCT300-M1K 37 mm VL18LL 25 mm OJ500-M1K OCT500-M1A 85 mm VL18LL 25 mm OCT300-M1K OJ500-M1K OCT500-M1A OCT300-M1K VL18LL OJ500-M1K 300 mm 300 mm 85 mm variable 153 mm 153 mm VL18LL 43 mm OJ500-M1K 62 mm 185 mm OCT500-M1A 185 mm VL18LL 44 mm OCT300-M1K OJ500-M1K 74 mm 80 mm OCT500-M1A 80 mm VL18LL 23 mm OCT300-M1K 30 mm 80 mm OCT500-M1A 80 mm VL18LL 23 mm OCT300-M1K OJ500-M1K Stainless Steel 37 mm OCT500-M1A OCT300-M1K OJ500-M1K Stainless Steel 85 mm 30 mm 173 mm OCT500-M1A 173 mm VL18LL 40 mm OCT300-M1K ø8 ø8 85 mm 35 20 35 ø8 OJ500-M1K M4 5 mm .7 20 20 35 ø8 Stainless Steel 3.2 mm 3.2 mm VL18LL .6 20 35 20 500 .8 250 500 500 500/1000/2000/3000 35 500/2000 20 35 500 20 35 500 2 .9 .3 Photoelectric Sensors, Standard Sensors, Fiber optic cables LMR 18-3.2-2.0-K1 LMR 18-3.2-1.0-K1* 9 mm 2 Photoelectric Sensors, Accessories 0.5 m OCT300-M1K 2 Dimensions (mm) Photoelectric Sensors, Light Grids LMR 18-3.2-0.5-K1 24 mm ø8 0.5 m 2.3 mm Stainless Steel .6 OCT500-M1A M8 x 1 LCR 18-3.2-0.5-K1 0.5 m 2.3 mm 24 mm 2 M8 x 1 LMR 18-2.3-0.5-K3 0.25 m .5 Stainless Steel OJ500-M1K 2 Photoelectric Sensors, Slot sensors ø 4.5Standard ø 4.5 Sensors, ø 4.5 M4 M4 ø 4.5 LMR 18-2.3-0.25-K3 .4 1.1 mm Sensing Range ø 6 0.5 m 2 Compatible Sensors 35 M10 x 1 .2 LMR 18-1.1-0.5-K3 2 Sheathing Material Photoelectric Sensors, Standard Sensors, Slot sensors 2 Cable Fiber Length Diameter Photoelectric Sensors, Standard Sensors, Color sensors .3 2 Photoelectric Sensors, Standard Sensors, Contrast and luminescence sensors Model Number Photoelectric Sensors, Standard Sensors, Distance sensors Photoelectric Sensors, Standard Sensors, Fiber optic sensors .3 2 Photoelectric Sensors, Standard Sensors, Fiber optic sensors 2 Cylindrical Sensing Head (cont.) Photoelectric Sensors, Optical Data Couplers Diffuse Mode Glass Fiber Optic Cables for OCT300-M1K and VL18LL Sensors 2000 65 mm 35 * Sensing ranges based on this model. Refer to General Notes Relating to Product Information Pepperl+Fuchs Group www.pepperl-fuchs.com USA: +1 330 486 0001 fa-info@us.pepperl-fuchs.com Germany: +49 621 776-4411 fa-info@de.pepperl-fuchs.com Copyright Pepperl+Fuchs Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 575 Photoelectric Sensors Fiber optic cables Glass Fiber Optic Cables Diffuse Mode Glass Fiber Optic Cables for OCT300-M1K and VL18LL Sensors LMR 18-2.7-0.5-K9 LSR 18-2.3-0.5-K12 0.5 m 0.5 m 2.7 mm 2.7 mm 2.3 mm PVC Stainless Steel Silicone Sensing Range OJ500-M1K 95 mm OCT500-M1A 95 mm OCT300-M1K 38 mm VL18LL 25 mm OJ500-M1K 95 mm OCT500-M1A 95 mm OCT300-M1K 38 mm VL18LL 25 mm OJ500-M1K 75 mm OCT500-M1A 75 mm OCT300-M1K 30 mm VL18LL 21 mm Dimensions (mm) ø8 Compatible Sensors 1000 14 10 1m Sheathing Material ø4 ø8 LCR 18-2.7-1.0-K9 Cable Fiber Length Diameter 500 14 ø4 500 32 15 ø 4 Thru-Beam Mode Glass Fiber Optic Cables for OCT300-M1K and VL18LL Sensors LCE 18-2.3-0.5-K2 0.5 m LME 18-2.3-0.5-K2 0.5 m LME 18-2.3-1.0-K2* 1m LME 18-2.3-2.0-K2 2m LME 18-2.3-0.5-K4 0.5 m 2.3 mm 2.3 mm 2.3 mm 2.3 mm Stainless Steel PVC Stainless Steel Stainless Steel OJ500-M1K 1300 mm OCT500-M1A 1300 mm OCT300-M1K 410 mm VL18LL 360 mm OJ500-M1K 1300 mm OCT500-M1A 1300 mm OCT300-M1K 410 mm VL18LL 360 mm OJ500-M1K 1300 mm OCT500-M1A 1300 mm OCT300-M1K 410 mm VL18LL 360 mm OJ500-M1K 1300 mm OCT500-M1A 1300 mm OCT300-M1K 410 mm VL18LL not compatible Dimensions (mm) 500 ø8 Sensing Range M4 Compatible Sensors 20 35 M8 x 1 0.5 m Sheathing Material 500 20 35 M8 x 1 LME 18-2.3-0.5-K3 Cable Fiber Length Diameter ø 4.5 Model Number ø 4.5 Cylindrical Sensing Head 500/1000/2000 20 35 500 M10 x 1 Photoelectric Sensors, Standard Sensors, Fiber optic cables .3 Model Number 10 2 32 Right Angle Sensing Head 35 * Sensing ranges based on this model. 576 Refer to General Notes Relating to Product Information Pepperl+Fuchs Group www.pepperl-fuchs.com USA: +1 330 486 0001 fa-info@us.pepperl-fuchs.com Germany: +49 621 776-4411 fa-info@de.pepperl-fuchs.com Copyright Pepperl+Fuchs Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com Photoelectric Sensors Fiber optic cables Glass Fiber Optic Cables Thru-Beam Mode Glass Fiber Optic Cables Refer to General Notes Relating to Product Information Pepperl+Fuchs Group www.pepperl-fuchs.com Stainless Steel USA: +1 330 486 0001 fa-info@us.pepperl-fuchs.com OJ500-M1K 275 mm OCT500-M1A 275 mm OCT300-M1K 97 mm VL18LL 89 mm OJ500-M1K 1050 mm OCT500-M1A 1050 mm OCT300-M1K 310 mm VL18LL 270 mm OJ500-M1K 830 mm OCT500-M1A 830 mm OCT300-M1K 308 mm VL18LL not compatible Germany: +49 621 776-4411 fa-info@de.pepperl-fuchs.com 10 ø8 240 mm .7 ø4 14 10 VL18LL ø8 240 mm 500 ø4 14 ø4 20 ø6 Copyright Pepperl+Fuchs Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com .8 500 500 500 2 .9 .3 Photoelectric Sensors, Standard Sensors, Fiber optic cables 2.3 mm Stainless Steel OCT300-M1K .6 2 Dimensions (mm) Photoelectric Sensors, Light Grids 1.9 mm Silicone 830 mm .6 2 Photoelectric Sensors, Accessories 0.5 m 1.1 mm OCT500-M1A 14 Photoelectric Sensors, Optical Data Couplers LME 18-2.3-0.5-K10 0.5 m PVC 830 mm 2 10 LME 18-1.9-0.5-K9 0.5 m 2.3 mm OJ500-M1K 2 ø8 LSE 18-1.1-0.5-K9 0.5 m .5 Sensing Range 10 LCE 18-2.3-0.5-K9 .4 2 Compatible Sensors Photoelectric Sensors, Standard Sensors, Slot sensors .2 2 Sheathing Material Photoelectric Sensors, Standard Sensors, Slot sensors 2 Cable Fiber Length Diameter Photoelectric Sensors, Standard Sensors, Color sensors .3 2 Photoelectric Sensors, Standard Sensors, Contrast and luminescence sensors Model Number Photoelectric Sensors, Standard Sensors, Distance sensors Photoelectric Sensors, Standard Sensors, Fiber optic sensors .3 2 Photoelectric Sensors, Standard Sensors, Fiber optic sensors 2 Right Angle Sensing Head ø8 for OCT300-M1K and VL18LL Sensors 577 Photoelectric Sensors Fiber optic cables Glass Fiber Optic Cables Diffuse Mode Glass Fiber Optic Cables for MLV41-LL-IR and MLV41-LL-RT Sensors 2 Model Number Cable Fiber Length Diameter Sheathing Material Photoelectric Sensors, Standard Sensors, Fiber optic cables .3 LLR 04-1.6-0.5-G LLR 04-1.9-1.0-WC5 LMR 04-0.5-0.5-Z1 LMR 04-1.9-0.5-Z1 LCR 04-1.6-0.5-Z1 LCR 04-1.6-1.0-Z1 578 0.5 m 1.0 m 0.5 m 0.5 m 0.5 m 1.0 m Sensing Range MLV41-LL-IR 90 mm MLV41-LL-RT 40 mm MLV41-LL-IR 100 mm MLV41-LL-RT 50 mm MLV41-LL-IR 7 mm MLV41-LL-RT 6 mm MLV41-LL-IR 90 mm MLV41-LL-RT 40 mm MLV41-LL-IR 80 mm MLV41-LL-RT 40 m MLV41-LL-IR 100 mm MLV41-LL-RT 50 mm Dimensions (mm) 1.6 mm Metal-Silicone 1.9 mm Metal-Silicone 0.5 mm 1.9 mm Metal Metal 1.6 mm 1.6 mm Refer to General Notes Relating to Product Information Pepperl+Fuchs Group www.pepperl-fuchs.com Compatible Sensors PVC PVC USA: +1 330 486 0001 fa-info@us.pepperl-fuchs.com Germany: +49 621 776-4411 fa-info@de.pepperl-fuchs.com Copyright Pepperl+Fuchs Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com Photoelectric Sensors Fiber optic cables Glass Fiber Optic Cables 1.0 m 1.0 m 1.1 mm 1.6 mm PVC 1.6 mm Metal-Silicone Refer to General Notes Relating to Product Information Pepperl+Fuchs Group www.pepperl-fuchs.com PVC USA: +1 330 486 0001 fa-info@us.pepperl-fuchs.com 100 mm MLV41-LL-RT 50 mm MLV41-LL-IR 280 mm MLV41-LL-RT 80 mm MLV41-LL-IR 280 mm MLV41-LL-RT 40 mm Germany: +49 621 776-4411 fa-info@de.pepperl-fuchs.com .6 .7 Copyright Pepperl+Fuchs Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 2 2 Dimensions (mm) .8 2 .9 .3 Photoelectric Sensors, Standard Sensors, Fiber optic cables 0.5 m .6 2 Photoelectric Sensors, Accessories LLE 04-1.6-1.0-G MLV41-LL-IR 2 Photoelectric Sensors, Optical Data Couplers LCE 04-1.6-1.0-Z1 .5 .4 Sensing Range Photoelectric Sensors, Light Grids LCE 04-1.1-0.5-WC3 2 Compatible Sensors Photoelectric Sensors, Standard Sensors, Color sensors .2 2 Sheathing Material Photoelectric Sensors, Standard Sensors, Contrast and luminescence sensors .3 2 Cable Fiber Length Diameter Photoelectric Sensors, Standard Sensors, Slot sensors 2 Model Number Photoelectric Sensors, Standard Sensors, Distance sensors Photoelectric Sensors, Standard Sensors, Fiber optic sensors .3 2 Photoelectric Sensors, Standard Sensors, Fiber optic sensors 2 Photoelectric Sensors, Standard Sensors, Slot sensors Thru-Beam Mode Glass Fiber Optic Cables for MLV41-LL-IR and MLV41-LL-RT Sensors 579 Photoelectric Sensors Fiber optic cables Fiber Optic Cables Accessories (Dimensions in mm) Accessories for Plastic Fiber Optic Cables MHP-FOA One-piece adapter that allows use of 2.2 mm diameter plastic fiber optic cables with MHP-FR sensors. 2 Photoelectric Sensors, Standard Sensors, Fiber optic cables .3 PFA-1MM This adapter must be used to ensure proper connection of all 1 mm bundle diameter plastic fiber optic cables. Sold individually. Two units are required for a fiber optic cable. Adapter included with all 1 mm bundle diameter fiber optic cables. K-LA01 Lens for M2.6 threaded tip thru-beam plastic fiber optics, stainless steel, increases operating distance. Sold individually. 9.3 ø4 K-LA02 Right–angled lens for M2.6 threaded tip thru-beam plastic fiber optics, stainless steel. Sold individually. 9.3 ø4 5.5 KL-CUT2 Plastic fiber optic cable cutter. 5.5 ø4 M2.6 ø3 M2.6 K-LA04 Lens for M4 threaded tip diffuse plastic fiber optics, plastic. Focuses light spot to 0.7 mm diameter. K-LA03 Lens for M3 threaded tip diffuse plastic fiber optics, plastic. Focuses light spot to 0.5 mm diameter. 20 15.5 5 ø 1.8 ø 4.1 M3 ø 3.1 ø5 ø 3.2 5 K-LA06 Collimation lens for M4 threaded tip diffuse fiber optics, plastic. Increases operating range up to eight times. 19.5 ø 6.4 4 ø3 M4 580 ø 6.4 Refer to General Notes Relating to Product Information Pepperl+Fuchs Group www.pepperl-fuchs.com USA: +1 330 486 0001 fa-info@us.pepperl-fuchs.com Germany: +49 621 776-4411 fa-info@de.pepperl-fuchs.com ø6 M4P0.7 11 ø4 Copyright Pepperl+Fuchs Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com
HPF-D001-H 价格&库存
很抱歉,暂时无法提供与“HPF-D001-H”相匹配的价格&库存,您可以联系我们找货
