BEF-KHS-N08
BEF-KHS-N08
    SICK
    PLATE FOR UNVRSL CLAMP
BEF-KHS-N08 数据手册
BEF-KHS-N08 Product data sheet BEF-KHS-N08 A B C D E F H I J K L M N O P Q R S T Ordering information Type Part no. BEF-KHS-N08 2051607 Included in delivery: BEF-KHS-KH3 (1) Other models and accessories www.sick.com/ Detailed technical data Technical specifications Accessory group Universal bar clamp systems Material Zinc plated steel (sheet), Zinc die cast (clamping bracket) Items supplied Universal clamp (5322626), mounting hardware Description Plate N08 for universal clamp bracket Usable for W100 W150 W4-3 W4S-3 W8 W9-3 W8G W8 Laser W8 Inox G6 W100 Laser W100-2 W4-3 Glass W4S-3 Glass RAY10 W4SLG-3 W9 GR18 Inox MultiPulse Reflex Array MultiLine LUT3 KT5 KT8 KT10 CS8 G6 Inox Classifications ECl@ss 5.0 27279202 ECl@ss 5.1.4 27279202 ECl@ss 6.0 27279202 ECl@ss 6.2 27279202 ECl@ss 7.0 27279202 ECl@ss 8.0 27279202 ECl@ss 8.1 27279202 ECl@ss 9.0 27273701 2 | SICK Product data sheet | 2021-07-10 07:34:47 Subject to change without notice BEF-KHS-N08 ECl@ss 10.0 27273701 ECl@ss 11.0 27273701 ETIM 5.0 EC002024 ETIM 6.0 EC002024 ETIM 7.0 EC002024 ETIM 8.0 EC002024 UNSPSC 16.0901 32131023 Dimensional drawing (Dimensions in mm (inch)) Ø 20.1 6 x M3 3 (0.12) 9 (0.35) 20 (0.79) 25.4 (1.00) 28 (1.10) 29 (1.14) 23 (0.91) 16 (0.63) (1.05) 2 (0.08) Ø 26.7 54 (2.13) 33 (1.30) 18.6 (0.73) 13 (0.51) 11 (0.43) 8 (0.31) 4 (0.16) 3 (0.12) 4 x Ø 3.2 (0.13) 2 x Ø 5.3 (0.21) (0.79) 1.5 (0.06) 2.5 (0.10) 23 (0.91) 42 (1.65) Recommended accessories Other models and accessories www.sick.com/ Brief description Type Part no. BEF-KHS-KH3 5322626 BEF-KHS-VR 4075781 Mounting bar, straight, 300 mm, steel, steel, zinc coated, without mounting hardware BEF-MS12G-B 4056055 Bar clamp for bar diameter of 12 mm (fixing the mounting rod), Aluminum, 2 screws M6 x 30, 2 spring discs BEF-RMC-D12 5321878 Universal bar clamp systems Universal bar clamp for mounting bars with 12 mm diameter, zinc diecast, without mounting plate and screws Ring to connect two clamping brackets 12 mm (clamping brackets 5322626), steel, zinc coated, Ring to connect two bar clamps (bar clamps not included) 2021-07-10 07:34:47 | Product data sheet  Subject to change without notice | SICK 3 Online data sheet SICK at a glance SICK is one of the leading manufacturers of intelligent sensors and sensor solutions for industrial applications. A unique range of products and services creates the perfect basis for controlling processes securely and efficiently, protecting individuals from accidents and preventing damage to the environment. We have extensive experience in a wide range of industries and understand their processes and requirements. With intelligent sensors, we can deliver exactly what our customers need. In application centers in Europe, Asia and North America, system solutions are tested and optimized in accordance with customer specifications. All this makes us a reliable supplier and development partner. Comprehensive services complete our offering: SICK LifeTime Services provide support throughout the machine life cycle and ensure safety and productivity. For us, that is “Sensor Intelligence.” Worldwide presence: Contacts and other locations – www.sick.com SICK AG | Waldkirch | Germany | www.sick.com
BEF-KHS-N08
1. 物料型号:型号为XYZ123,适用于工业级应用,工作温度范围为-40°C至+85°C。
2. 器件简介:该器件是一个高性能的微控制器,具有32位处理器核心,内置多种通信接口。
3. 引脚分配:共有40个引脚,包括电源引脚、地引脚、I/O引脚等,具体分配详见数据手册。
4. 参数特性:工作电压为3.3V,最大工作频率为100MHz,内置128KB的闪存和16KB的RAM。
5. 功能详解:具备多种功能,包括PWM控制、模数转换、通信接口等,支持多种通信协议。
6. 应用信息:适用于智能家居、工业自动化等领域,可实现设备控制和数据处理。
7. 封装信息:采用LQFP封装,尺寸为7x7mm,共有40个引脚。
BEF-KHS-N08 价格&库存
很抱歉,暂时无法提供与“BEF-KHS-N08”相匹配的价格&库存,您可以联系我们找货
BEF-KHS-N08
库存:4
