SMBFLXMAGD
SMBFLXMAGD
    BANNER(邦纳)
    MAGNETIC MOUNT KIT 3.2" DIAM
SMBFLXMAGD 数据手册
Flex Arm Mounts Datasheet • • • • 457 mm (18 in) long, vinyl coated Works with cabled and quick-disconnect models of WL50, WL50S, and LED..S50L Various mounting options Hex nut and o-ring are included (with 1/2-14 NPSM Base connection models) Models Model Base Connection Light Connection Used with FLX18-1212 WL50 WL50PB WL50-2 WL50-2PB 1/2 - 14 NPSM 1/2 - 14 NPSM (Male) FLX18-F12 (cabled and QD models) 3-Hole Flange FLX18-12M30 1/2 - 14 NPSM WL50 WL50PB WL50S WL50-2 WL50-2PB LED..S50 FLX18-DM30 2 x 1/4-20W 1.375 spacing M30 x 1.5 (Female) (cabled and QD models) FLX18-FM30 3-Hole Flange Original Document 170238 Rev. B 3 March 2014 170238 Flex Arm Mounts Base Dimensions 8.6 [.34] 34.9 [1.38] 2X 7.1 [.28] 10.7 [4.22] 6.35 [.25] Accessories Brackets 32 SMB22A • Right-angle bracket with curved slot for versatile orientation • 12-ga. stainless steel • Mounting hole for 22 mm sensor SMBFLXCLAMPD • Use with Flex Arm Mount FLX18-DM30 model C 41 51 B A 64 46 43 B A Hole center spacing: A to B = 26.0 Hole size: A = ø 4.6, B = 4.6 x 16.9, C = 22.2 · Use with Flex Arm Mount models with 1/2-14 NPSM Base Connection SMBFLXMAG • Use with Flex Arm Mount models with 1/2-14 NPSM Base Connection ø22 38 SMBFLXMAGD • Use with Flex Arm Mount FLX18-DM30 model 49 2X 1/4-20 UNC ø9.5 13 ø81 ø85 Bracket Protective Cover SMBFLXMAGR • Protective magnet cover • Prevents scratches to painted surfaces • Used with SMBFLXMAG and SMBFLXMAGD 2 www.bannerengineering.com - tel: 763-544-3164 P/N 170238 Rev. B Flex Arm Mounts LMB Sealed Right-Angle Bracket Use with Flex Arm Mount models with 1/2-14 NPSM Base Connection Model Description Construction LMBE12RA Black polycarbonate Pipe-Mount Models: Bracket kit with base, ½-14 pipe adapter, set screw, fasteners, orings, and gaskets. For use with stand-off pipe (listed and sold separately) LMBE12RAC Gray polycarbonate Power Supply Model Voltage Connection PS24W 24 V dc at 1A 4-pin Euro QD Description Non-industrial (not sealed) power supply, converts 100 - 240 V ac to 24 V dc Field Wireable Connector Model Style Pinout Dimensions 3 FIC-M12M4 4-Pin Male Straight 1 2 3 4 = = = = 60 mm 1 2 10 mm 4 Brown Not used Blue Not used 15.0 mm M12 x 1 Banner Engineering Corp. Limited Warranty Banner Engineering Corp. warrants its products to be free from defects in material and workmanship for one year following the date of shipment. Banner Engineering Corp. will repair or replace, free of charge, any product of its manufacture which, at the time it is returned to the factory, is found to have been defective during the warranty period. This warranty does not cover damage or liability for misuse, abuse, or the improper application or installation of the Banner product. THIS LIMITED WARRANTY IS EXCLUSIVE AND IN LIEU OF ALL OTHER WARRANTIES WHETHER EXPRESS OR IMPLIED (INCLUDING, WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE), AND WHETHER ARISING UNDER COURSE OF PERFORMANCE, COURSE OF DEALING OR TRADE USAGE. This Warranty is exclusive and limited to repair or, at the discretion of Banner Engineering Corp., replacement. IN NO EVENT SHALL BANNER ENGINEERING CORP. BE LIABLE TO BUYER OR ANY OTHER PERSON OR ENTITY FOR ANY EXTRA COSTS, EXPENSES, LOSSES, LOSS OF PROFITS, OR ANY INCIDENTAL, CONSEQUENTIAL OR SPECIAL DAMAGES RESULTING FROM ANY PRODUCT DEFECT OR FROM THE USE OR INABILITY TO USE THE PRODUCT, WHETHER ARISING IN CONTRACT OR WARRANTY, STATUTE, TORT, STRICT LIABILITY, NEGLIGENCE, OR OTHERWISE. Banner Engineering Corp. reserves the right to change, modify or improve the design of the product without assuming any obligations or liabilities relating to any product previously manufactured by Banner Engineering Corp. www.bannerengineering.com - tel: 763-544-3164
SMBFLXMAGD 价格&库存
很抱歉,暂时无法提供与“SMBFLXMAGD”相匹配的价格&库存,您可以联系我们找货
