TSH248
Micropower Omni-Polar Hall Effect Switch
TSOT-23
Pin Definition:
1. VCC
2. Output
3. GND
Description
TSH248 Hall-effect sensor is a temperature stable, stress-resistant, micro-power switch. Superior hightemperature performance is made possible through a dynamic offset cancellation that utilizes chopperstabilization. This method reduces the offset voltage normally caused by device over-molding, temperature
dependencies and thermal stress.
TSH248 includes the following on a single silicon chip: voltage regulator, Hall voltage generator, small-signal
amplifier, chopper stabilization, Schmitt trigger, open-drain output. Advanced CMOS wafer fabrication processing
is used to take advantage of low-voltage requirements, component matching, very low input-offset errors and
small component geometries.
Features
CMOS Hall IC Technology
Solid-State Reliability
Low power consumption for battery applications
Operation voltage range from 2.5V~3.5V
Ordering Information
Part No.
TSH248CX RFG
Package
Packing
TSOT-23
3kpcs / 7” Reel
Note: “G” denote for Halogen Free Product
Application
Solid state switch
Lid close sensor for power supply devices
Magnet proximity sensor for reed switch
replacement in high duty cycle applications.
Handheld Wireless Handset Awake Switch (Flip
Cell/PHS Phone/Note Book/Flip Video Set)
Absolute Maximum Ratings (TA = 25oC unless otherwise noted)
Characteristics
Limit
Value
Unit
Supply voltage
VCC
5
V
Output Voltage
VOUT
5
V
Reverse voltage
VCC/OUT
-0.3
V
Unlimited
G
mA
Magnetic flux density
Output current
IOUT
2
Operating Temperature Range
TOPR
-40 to +85
Storage temperature range
TSTG
Maximum Junction Temp
Thermal Resistance - Junction to Ambient
Thermal Resistance - Junction to Case
Package Power Dissipation
o
C
o
C
-55 to +150
o
C
TJ
150
RθJA
543
o
RθJC
410
o
PD
230
C/W
C/W
mW
Note: Exceeding the absolute maximum ratings may cause permanent damage. Exposure to absolute maximumrated conditions for extended periods may affect device reliability.
1/8
Version: B14
TSH248
Block Diagram
Note: Static sensitive device; please observe ESD precautions. Reverse VCC protection is not included. For reverse
voltage protection, a 100Ω resistor in series with VCC is recommended.
Typical Application Circuit
C1:10nF
C2:100pF
R1:100kΩ
2/8
Version: B14
TSH248
Electrical Specifications (DC Operating Parameters: TA=+25oC, VCC=3V)
Parameters
Test Conditions
Min
Typ
Max
Units
2.5
3.5
V
Awake State
2.5
4.0
mA
Sleep State
8.0
12
µA
Average
10
16
µA
Output Low Voltage
IOUT=1mA
0.3
V
Output Leakage Current
Output off
1
µA
Awake Mode Time
Operating
70
µs
Sleep Mode Time
Operating
70
ms
0.1
Min.
Typ.
Max.
Units
Supply Voltage
Operating
Supply Current
Duty Cycle
Magnetic Specifications
o
DC Operating Parameters TA=25 C, VCC=3.0V
Parameter
Symbol
Test Conditions
Operating
Point
BOPS
N pole to branded side, B > BOP, VOUT On
6
60
G
BOPN
S pole to branded side, B > BOP, VOUT On
-60
-6
G
Release
Point
BRPS
N pole to branded side, B < BRP, VOUT Off
5
-59
G
BRPN
S pole to branded side, B < BRP, VOUT Off
-60
-5
G
Hysteresis
BHYS
|BOPx - BRPx|
7
G
Note: 1G (Gauss) = 0.1mT (millitesla)
3/8
Version: B14
TSH248
Output Behavior versus Magnetic Pole
o
DC Operating Parameters: TA = -40 to 85 C, VCC = 2.5V ~ 3.5V
Parameter
Test condition
OUT
South pole
B
很抱歉,暂时无法提供与“TSH248CX RFG”相匹配的价格&库存,您可以联系我们找货
