TSH481CT B0G
TSH481CT B0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    TO226-3
    线性霍尔效应开关
TSH481CT B0G 数据手册
TSH481 Ratio-metric Linear Hall Effect Switch TO-92S Pin Definition: 1. VCC 2. GND 3. Output Description TSH481 is a linear Hall-effect sensor which is composed of Hall sensor, linear amplifier and Totem-Pole output stage. It features low noise output, which makes it unnecessary to use external filtering. It also can provide increased temperature stability and accuracy. The linear Hall sensor has a wide operating temperature range of o o 40 C to +105 C, appropriate for commercial, consumer, and industrial environments. The high sensitivity of Hall-effect sensor accurately tracks extremely weak changes in magnetic flux density. The linear sourcing output voltage is set by the supply voltage and in proportion of variation of the magnetic flux density. Typical operation current is 2.5mA and operating voltage range is 3.0V to 6.5V Features ● ● ● ● ● ● Operating Voltage Range: 3.0V~6.5V Low-Noise Operation Linear output for circuit design flexibility Totem-Pole for a stable and accurate output Responds to either positive or negative magnetic flux density Robust ESD performance Ordering Information Part No. TSH481CT B0G Package Packing TO-92S 1kpcs / Bulk Bag Note: “G” denote for Halogen Free Product Application ● ● ● ● ● ● ● ● ● Current sensing Motor control Position sensing Magnetic code reading Rotary encoder Ferrous metal detector Vibration sensing Liquid level sensing Weight sensing Absolute Maximum Ratings (TA = 25oC unless otherwise noted) Characteristics Supply voltage Reverse voltage Magnetic flux density Output current Limit Value Unit VCC VCC 8 -0.5 Unlimited 10 V V G mA IOUT TOPR Operating Temperature Range -40 to +85 o C o -65 to +150 Storage temperature range TSTG C o 150 Maximum Junction Temp TJ C o 206 Thermal Resistance - Junction to Ambient RθJA C/W o 148 Thermal Resistance - Junction to Case RθJC C/W 606 Package Power Dissipation PD mW Note: Exceeding the absolute maximum ratings may cause permanent damage. Exposure to absolute maximumrated conditions for extended periods may affect device reliability. 1/7 Version: A14 TSH481 Ratio-metric Linear Hall Effect Switch Block Diagram Typical Application Circuit Electrical Specifications (DC Operating Parameters: TA=+25oC,VCC=5V) Parameters Test Conditions Min Typ Max Units 3.0 -- 6.5 V Supply Voltage Operating Supply Current B=0 G -- 2.5 5.0 mA Output Current VCC>3V 1.0 1.5 -- mA Null Output Voltage B=0 G 2.3 2.5 2.7 V -- 20 -- kHz Output Voltage Span 2.95 3.2 -- V Magnetic Range Gauss ±500 ±800 -- G -- 0.7 -- -- 3 -- µs 1.8 -- 2.2 mV/G 3 -- -- kV Output Bandwidth Linearity % of Span Response Time Sensitivity Electro-Static Discharge HBM Note: 1G (Gauss) = 0.1mT (millitesla) 2/7 Version: A14 TSH481 Ratio-metric Linear Hall Effect Switch Output Behavior versus Magnetic Pole o DC Operating Parameters: TA=+25 C, VCC=5V TO-92S VOUT < VNULL VOUT > VNULL 3/7 Version: A14 TSH481 Ratio-metric Linear Hall Effect Switch Characteristic Performance Figure 1. Output Voltage vs. Flux Density Figure 2. Output Voltage Offset vs. Temperature Figure 3. Vout/Vcc Ratio vs. Supply Current Figure 4. Linearity vs. Supply Voltage Figure 5. Supply Current vs. Temperature Figure 6. Supply Current vs. Supply Voltage 4/7 Version: A14 TSH481 Ratio-metric Linear Hall Effect Switch Characteristic Performance Figure 7. Sensitivity vs. Temperature Figure 8. Sensitivity vs. Supply Voltage Figure 8. Power Dissipation vs. Temperature 5/7 Version: A14 TSH481 Ratio-metric Linear Hall Effect Switch TO-92S Mechanical Drawing Unit: Millimeters Marking Diagram 481 Y WW = Device Code = Year Code (3=2013, 4=2014….) = Week Code (01~52) 6/7 Version: A14 TSH481 Ratio-metric Linear Hall Effect Switch Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 7/7 Version: A14
TSH481CT B0G 价格&库存
很抱歉,暂时无法提供与“TSH481CT B0G”相匹配的价格&库存,您可以联系我们找货
TSH481CT B0G
  • 20+6.81690
库存:40
TSH481CT B0G
  • 50000+5.1405950000+0.66632
