High Power Thin Film Chip Terminator
■PCS Series、HPT Series
Features
・ Small high power chip terminator with aluminum nitride and aluminum oxide substrate
・ Efficient heat dissipation provides high power, anti-surge, overload protection.
・ Wrap around terminals provide easy and reliable soldering.
・ Thin film does not have any innate stress. Therefore, repeated power cycling does
not fatigue the element and cause no change in impedance.
Applications
・ Wireless base station, wireless communication devices, and high frequency power
source
◆Part numbering system
HPT 3216 - 50 - T1
Series code(PCS, HPT)
Packing quantity:
T=Tape (T1/T5), B=Bulk
6432, *6464, *9464H
Impedance
*HPT series only
◆ Electrical Specification
PCS series (Alumina substrate)
Type
PCS1005
PCS1608
PCS2012
PCS3216
PCS5025
PCS6432
Rated Power
200mW
500mW
1W
2W
5W
10W
DC ∼ 3GHz
1.2
1.2
1.2
1.2
1.3
1.2
3.1∼5GHz
1.2
1.2
1.3
1.3
1.4
1.5
5.1∼7.5GHz
1.3
1.3
1.3
1.4
1.5
ー
7.6∼10GHz
1.3
1.3
1.4
1.5
ー
ー
10.1∼12.5GHz
1.4
1.4
1.5
ー
ー
ー
12.6∼15GHz
1.5
1.5
ー
ー
ー
ー
Operating temperature
-55℃∼ +125℃
Rated operating temperature
+70℃
Packaging quantity
100pcs/bag (B) 1000pcs/reel (T1) 5000pcs/reel (T5)
HPT series (ALN substrate)
PCS Series, HPT Series
High frequency surface mount components
VSWR
Type
HPT1608
HPT2012
HPT3216
HPT5025
HPT6432
HPT6464
HPT9464H
Rated Power
2.5W
5W
10W
20W
30W
60W
100W
DC ∼ 3GHz
1.2
1.2
1.2
1.3
1.3
1.3
1.3
3.1∼5GHz
1.2
1.3
1.3
1.5
1.5
ー
ー
5.1∼7.5GHz
1.3
1.3
1.4
ー
ー
ー
ー
7.6∼10GHz
1.3
1.4
1.5
ー
ー
ー
ー
10.1∼12.5GHz
1.4
1.5
ー
ー
ー
ー
ー
12.6∼15GHz
1.5
ー
ー
ー
ー
ー
ー
VSWR
87
-40℃∼ +155℃
+100℃ at Terminal
Packaging quantity
100pcs/bag (B)
1000pcs/reel (T1)
◆ Dimension, Equivalent Circuit and pin arrangement
Equivalent circuit
PCS1005 PCS1608
PCS2012 PCS3216 PCS5025
PCS6432
Type
Size
(inch)
L
W
t
L1
L2
L3
PCS1005
0402
1.00±0.10
0.50±0.10
0.30±0.10
0.65±0.10
0.20±0.10
0.15±0.10
PCS1608
0603
1.60±0.15
0.80±0.15
0.40±0.10
1.10±0.15
0.30±0.15
0.20±0.15
PCS2012
0805
2.00±0.15
1.25±0.15
0.40±0.10
1.50±0.15
0.30±0.15
0.20±0.15
PCS3216
1206
3.20±0.20
1.60±0.20
0.40±0.10
2.70±0.20
0.30±0.15
0.20±0.15
PCS5025
2010
5.00±0.20
2.50±0.20
0.40±0.10
4.30±0.20
0.40±0.15
0.30±0.15
PCS6432
2512
6.40±0.20
3.20±0.20
0.40±0.10
5.70±0.20
0.40±0.15
0.30±0.15
HPT1608 HPT2012
HPT3216 HPT5025
HPT 6432
HPT6464 HPT9464H
L
W
t
L1
L2
L3
W1
HPT1608
0603
1.60±0.15
0.80±0.15
0.40±0.10
1.10±0.15
0.30±0.15
0.20±0.15
ー
HPT2012
0805
2.00±0.15
1.25±0.15
0.40±0.10
1.50±0.15
0.30±0.15
0.20±0.15
ー
HPT3216
1206
3.20±0.20
1.60±0.20
0.40±0.10
2.70±0.20
0.30±0.15
0.20±0.15
ー
HPT5025
2010
5.00±0.20
2.50±0.20
0.65±0.10
3.60±0.20
0.90±0.20
0.50±0.15
ー
HPT6432
2512
6.40±0.20
3.20±0.20
0.65±0.10
5.50±0.20
0.70±0.15
0.20±0.15
ー
HPT6464
2525
6.30±0.20
6.30±0.20
0.65±0.10
4.90±0.20
0.65±0.15
0.75±0.15
3.05±0.20
HPT9464H
3725
9.40±0.20
6.30±0.20
0.65±0.10
7.10±0.20
1.15±0.15
1.15±0.15
3.00±0.20
Size
(inch)
Type
(unit:mm)
88
◆Recommended land patterns (soldering footprints)
PCS / HPT
a
c
b
Type
a
b
c
Type
a
b
c
PCS1005
0.70
0.20
0.70
HPT1608
1.20
0.40
1.20
PCS1608
1.20
0.30
1.20
HPT2012
1.60
0.40
1.50
PCS2012
1.20
0.45
1.60
HPT3216
2.00
0.40
2.00
PCS3216
2.00
0.45
2.00
HPT5025
2.90
0.90
2.90
PCS5025
2.90
0.55
2.90
HPT6432
3.60
0.70
3.60
PCS6432
3.60
0.55
3.60
HPT6464
3.30
1.15
6.80
HPT9464H
3.30
1.15
(unit:mm)
6.80
(unit:mm)
◆Mounting example
Pay special care to heat dissipation when this product is used at maximum rated power.
Mounting example of these series
Resistor element
Input terminal
Ground
Thermal vias
Above diagram shows a mounting example with thermal bias dissipating
heat to the ground. Depending on the application, a heat sink might be
needed closely contacting to the bottom of the product.
◆Derating Curve
〇 PCS Series
100
50
0 50 70 100 125
Ambient tempareture(℃)
89
〇 HPT Series
155
Rated Power ratio %
Rated Power ratio(%)
Mounting
surface
100
50
Terminal temperature(℃)
155
◆ High frequency characteristics
PCS1608 VSWR
1.6
1.5
VSWR
1.4
1.3
1.2
1.1
1.0
0 2 4 6 8 10 12 14 16 18
frequency(GHz)
PCS3216 VSWR
1.6
1.5
VSWR
1.4
1.3
1.2
1.1
1.0
0 2 4 6 8 10 12
frequency(GHz)
PCS6432 VSWR
1.6
1.5
VSWR
1.4
1.3
1.2
1.1
1.0
3 4 5 6 7 8
0 1 2
frequency(GHz)
90
很抱歉,暂时无法提供与“HPT6464-50-T1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+32.68080
- 200+12.65760
- 500+12.20400
- 1000+11.98800
- 国内价格 香港价格
- 1000+37.668961000+4.86647
- 2000+36.887862000+4.76556
